Toytec Eibach coilover setup question here
Discussion in 'Suspension' started by firefighteru7, Mar 9, 2019.
  1. Mar 9, 2019 at 9:09 PM
    firefighteru7
    firefighteru7 [OP] New Member
    2012 Tundra
    I’m looking at 2 setups on their site.
    This first one does a 2” to 3” lift While this second one does a 2.5” to 3” lift Other than the diff in lift height was is the diff in these 2?
    I current have Fox 2.0 in the back and I’m not really looking to lift my truck. I’d prefer to level it out. I’ve heard a lot that the Fox 2.0 in back actually raise the back of the truck 1”, is this true?
    Being that I’m going for more level than lift, which is best for me and to go along with my fox 2.0 in the back? Thanks
  2. Mar 9, 2019 at 9:16 PM
    firefighteru7
    2012 Tundra
    I did consider fat bobs garage coilover setup too, but the toytec eibach setup has progressive valving, which I feel would give me an overall smoother ride and when I do light off roading a better feel.
    OBXTundra likes this.
  3. Mar 9, 2019 at 9:24 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    A lot of people here run Toytec and have nothing but good things to say. They are also a vendor on here so you can message them or give them a call and I’m sure they’d be willing to help you out. @Toytec Lifts
    As for the Fox 2.0 you’re currently running, and really any rear shocks, they do not provide any lift. The 1” means that they are able to accommodate for 1” of lift in the rear. Usually from blocks, shackles, leafs, etc.
    15whtrd likes this.
  4. Mar 9, 2019 at 9:26 PM
    firefighteru7
    2012 Tundra
    So which height toytec would be best for me trying to keep a more stock or level height?
  5. Mar 9, 2019 at 9:34 PM
    KnuckleHD
    2” lift in the front will be pretty close to level so I’d go that route. Any higher and you’ll be nose high.
  6. Mar 10, 2019 at 5:07 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    If you want to just level why not go with the fox 2.0 in the front? That will give you a level and you will have matching gear
  7. Mar 10, 2019 at 5:42 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    The difference in the part numbers appears to be for compatibility up to 2019. Message or call @Toytec Lifts
    Toytec/eibach owner here. Love them. About 18 months on the truck.
    Black Wolf likes this.
  8. Mar 10, 2019 at 5:18 PM
    firefighteru7
    2012 Tundra
    Ni
    I wish I could get a set of Fox 2.0 coilovers. But the prices I found are $800+ for the pair. Toytec eibach is $487 shipped with the coupon. If you could find me a discount or a slightly used set of Fox 2.0 coilovers at a decent price I’d love you for it. The next best option I see is the toytec eibach setup, it is progressive valving, my fox 2.0 is linear and I’m not really looking at digressive.
  9. Mar 14, 2019 at 8:27 AM
    LiftMeUp
    LiftMeUp New Member
    Looking at going with the Toytec Eibach setup. Anyone know what labor for installation runs on this? Going to put on tires at the same time so figure while it's in the rack it shouldn't be that much to throw them on. Is there discounts from Toytec to members or what's the best way to contact to get the best price? Thanks.
  10. Mar 14, 2019 at 8:39 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Call ToyTec to place you order of you want and mention forum discount.
  11. Mar 14, 2019 at 9:44 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    I'm wondering the same thing, what is the difference between the two setups. Especially given the 1/2 inch difference. @Toytec Lifts
    The BCS19 would save me from buying shims to get 2.5", right?
  12. Mar 14, 2019 at 10:42 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Call @Toytec Lifts. They are normally on here a few times a week, but haven't answered too many posts recently. I spoke with them on the phone when I had questions, easiest way to get your answers.
  13. Mar 14, 2019 at 11:53 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    The two kits you are looking at are for the 2 different year split on the Tundras. If you have the earlier model Tundra then I would recommend going with kit to insure proper stance and ride quality and have it set at the 2'' mark for the level stance.
    These shocks will offer you a good overall ride quality and stance that you are looking for.
    Thanks
    -David
  14. Mar 14, 2019 at 2:53 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    No better way to get a response than to poke the bear.
    Toytec Lifts[QUOTED] likes this.
  15. Mar 14, 2019 at 2:54 PM
    Toytec Lifts
    Denver, CO.
  16. Mar 15, 2019 at 6:53 AM
    LiftMeUp
    LiftMeUp New Member
    Thanks.
  17. Mar 15, 2019 at 6:56 AM
    Toytec Lifts
    Denver, CO.
    GODZILLA and Black Wolf like this.
  18. Mar 15, 2019 at 7:20 AM
    Aurora CO
  19. Apr 23, 2021 at 10:03 AM
    camillethetoy
    camillethetoy New Member
    jeremy
    08 DC 4x4
    2/1 Eibach Coilovers and 1" block
    Just ordered Toytec 2" to replace whatever puck lift the PO put on here, can't wait for a better ride!
