Toytec BOSS questions
Discussion in 'Toytec Lifts' started by Trey5257, Nov 15, 2016.
  1. Nov 15, 2016 at 8:14 PM
    Trey5257
    Trey5257 [OP] New Member
    Trey
    2017 Tundra Limited
    Toytec BOSS kit, SPC UCAs, Method Mesh 18x9, Cooper STT Pro 295/70R18
    Recently purchased a 2017 Crewmax MGM. Already have the itch to modify it. Pretty set on the Toytec kit. Curious on recommendations for the rear, should I go with blocks or the shackles? Also are UCAs necessary? Any opinions on the SPC arms? I think I will be going with some method wheels, not sure on tires yet. Any input is much appreciated! Thanks guys!
  2. Nov 15, 2016 at 8:20 PM
    COMiamiFan
    COMiamiFan SSEM #3. Don't forget to try the search bar. #PSL
    Jose
    Parker, CO
    2016 White Crew Max TRD
    BlueFalconActual and T-Rex266 like this.
  3. Nov 15, 2016 at 8:25 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'm headed the same way very shortly! I'd go with shackles, i currently have a 1" block but would be nice to have the adjustability.
    You don't NEED UCA's unless you go over 3" in front. But I'm going to get some anyways, supposedly it helps with alignment (but didn't have a problem aligning my 3" spacer) not to mention it helps a lot with wheel travel if you do get them.
    I'm thinking of getting the SPC just for non maintenance and I don't wheel hardcore, so I'm not worried about the TC's.
    Trey5257 [OP] likes this.
  4. Nov 15, 2016 at 8:25 PM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'm going with shackles in the rear over blocks, from going through this site I'm under the impression the ride is a bit smoother compared to blocks. Trying to decide on UCAs myself, stuck between the minimal maintenance SPCs and the increased strength of uniball TC's or Camburgs. Like @Law323, I don't do any serious wheeling. Sean will be able to give more in depth advice.
    Law323 likes this.
  5. Nov 15, 2016 at 8:28 PM
    COMiamiFan
    Jose
    Parker, CO
    I'll be watching as I'm heading in this direction too. :popcorn:
    Drop some knowledge Sean.
    Trey5257 [OP] and T-Rex266 like this.
  6. Nov 15, 2016 at 8:30 PM
    T-Rex266 Sushi, and Teslas Staff Member
    Shackles or blocks..I have the 1.25" block in the rear on my BOSS kit. @csuviper has the shackles. Ride is the same it seems.
    UCA's: I have SPC's. Fully adjustable and zero maintenance needed.
    When I ran my last setup (Old Man EMU) I had stock uppers on my 35" Toyos. At certain angles it liked to rub on them which caused my traction to freak out. Aftermarket UCA's would have solved that.
    Bob and Trey5257 [OP] like this.
  7. Nov 15, 2016 at 8:30 PM
    Trey5257
    Trey
    2017 Tundra Limited
    I figured the adjustability would be nice as well. I dont plan to wheel much either so I would go with the SPCs as well. I didn't do UCAs on my Tacoma when I did the Toytec lift but just wondering if I should pull the trigger up front this time. I love Sean's truck and already sent him a message, just already came up with more questions since
    Law323 and T-Rex266 like this.
  8. Nov 15, 2016 at 8:59 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    With any 3/1 lift I would recommend the UCAs. I had the stock ones for about 2 years with a 3/1 Bilstein lift. Changed to the Boss and Total Chaos UCAs. Smoother movement and more travel. Do it right away so your not tearing into the suspension twice and getting two alignments.
    khunk, Local46er, TheBeast and 2 others like this.
  9. Nov 15, 2016 at 9:04 PM
    csuviper
    Broomfield, CO
    Had the block first and then went to the shackle. Similar ride. Smoother movement and more movement with the shackle. Have tested at 1.5" and 1" with similar feel.
    zcarpenter92 and Law323 like this.
  10. Nov 16, 2016 at 6:33 PM
    Trey5257
    Trey
    2017 Tundra Limited
    So after a lot of research and looking at pictures I may just only lift the front. Really not wanting to do the CMC on my new truck. Considering running a 295/70R18 with just a lift/level for the front. Opinions or recommendations? I think this truck sits/looks perfect.
  11. Nov 16, 2016 at 6:58 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    A 2.5 or lower and none in back would level it out although, a 3" lift in front would be nose high without at least 1" in back.
    You'd only need a CMC with a certain offset range even with 295/70's. Has nothing to do with suspension.
    zcarpenter92 and Trey5257 [OP] like this.
  12. Nov 16, 2016 at 7:01 PM
    Just do the cmc. Just have it done professionally. What difference will it make next year? You can get the setup you want the first time around. :thumbsup:
    TheBeast and Trey5257 [OP] like this.
  13. Nov 16, 2016 at 7:02 PM
    Trey5257
    Trey
    2017 Tundra Limited
    I really like the Method mesh wheels which are +18. Im just afraid that if I go with the BOSS kit but the 295 tire that they will look too small
  14. Nov 16, 2016 at 7:10 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Only way they'd look small is with height. I have 275/70's on my 3/1 and they do look somewhat small but a 34" tire wouldn't. Besides that, I have a 2nd gen and their wheel wells are a little smaller than the 3rd gens so, I think you'd be golden.
  15. Nov 16, 2016 at 7:12 PM
    Trey5257
    Trey
    2017 Tundra Limited
    Hmmmm, decisions decisions
    Law323 likes this.
  16. Nov 16, 2016 at 7:22 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Get shackles and do the CMC. Like mentioned, just get it all done with early on.
    I wouldn't do just a front lift. At least lift the rear 1".
  17. Nov 16, 2016 at 7:25 PM
    Trey5257
    Trey
    2017 Tundra Limited
    Any reason you recommend not just doing the front?
  18. Nov 16, 2016 at 7:26 PM
    Trey5257
    Trey
    2017 Tundra Limited
    Know of any local or maybe shops in Denver that can do the CMC?
  19. Nov 16, 2016 at 7:30 PM
    Toycrawlers
  20. Nov 16, 2016 at 8:02 PM
    CaptTyler
    Tyler
    The front will be nose high and adding shackles also improves right and tightens everything up. It's a win-win.
    And the shackles from toytec are a great value.
  21. Nov 16, 2016 at 8:31 PM
    Trey5257
    Trey
    2017 Tundra Limited
    Alright, I think I'm set on the BOSS kit. Heard many good things about it and seems to be the best bang for your buck. Going with silver coils and the rear shackles. Still not sure on control arms yet. Appreciate everyone's input, helped me decide!
    CaptTyler, csuviper, T-Rex266 and 2 others like this.
  22. Nov 16, 2016 at 8:54 PM
    Trey5257
    Trey
    2017 Tundra Limited
    Well, that was fast. Just completed my order; BOSS kit, SPC UCAs, Silver coils and rear adjustable shackles. The fun begins!
  23. Nov 17, 2016 at 8:21 AM
    Nice!!
  24. Nov 17, 2016 at 8:35 AM
    csuviper
    Broomfield, CO
    Awesome!!
  25. Nov 17, 2016 at 8:40 AM
    TheBeast The Beach
    nice setup, you will be happy !
  26. Nov 17, 2016 at 9:26 AM
    CaptTyler
    Tyler
    Can't wait to see it all done!!! Keep us posted.
    T-Rex266 and Trey5257 [OP] like this.
  27. Nov 17, 2016 at 10:13 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    This is literally the exact setup I want to pull the trigger on. Pleaseeeeee post pics when done.
    csuviper, PapaGrizz and zcarpenter92 like this.
  28. Nov 17, 2016 at 11:19 AM
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
  29. Nov 17, 2016 at 1:05 PM
    I have all of that except the shackles.
  30. Nov 17, 2016 at 2:57 PM
    joem1cha3l
    Albany, NY
    I cant look at your truck anymore. Wife is gonna think I'm looking at porn when she sees my face lol
    zcarpenter92, TheBeast and T-Rex266 like this.
