Toytec Boss lift questions
Discussion in 'Suspension' started by naterwt, Nov 15, 2020.
  1. Nov 15, 2020 at 11:16 AM
    naterwt
    naterwt [OP] New Member
    Nate
    2017 crew max
    Bone stock but not for long
    3A236110-319F-4DED-8F34-7438E4587214.jpg Put my toytec boss lift of this weekend . It’s sitting a inch higher in the front even with the rear block . I’m guessing it will settle in a little over time ? Rims and tires this week and going to drive it for a week before I get it aligned . How long should I give it for the front to settle in where it’s going to be ?
    Toytec Lifts and 4x4_Angel like this.
  2. Nov 15, 2020 at 11:24 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    are you at 1" lift in the back? I felt my front sat higher also (or looked higher) after install went up to 2" in the back. That being said I do feel my front has settled since install probably about 8k on it now..
  3. Nov 15, 2020 at 11:26 AM
    naterwt
    Nate
    2017 crew max
    No I am actually sitting higher in the front at the moment
  4. Nov 15, 2020 at 11:27 AM
    naterwt
    Nate
    2017 crew max
    Yes I did the 1” in the back
  5. Nov 15, 2020 at 11:31 AM
    Johnders2586
    Well once aligned I'd give it a few weeks atleast to see what you think. I felt 1" in back just wasn't enough for my taste but I didn't do any official measurements..
  6. Nov 15, 2020 at 11:33 AM
    naterwt
    Nate
    2017 crew max
    Ok thanks . I figured if I need too I can just adjust the front coils instead of adding to the back .
  7. Nov 15, 2020 at 3:27 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Mine settled about 1/4 inch to 1/2 inch after about a week or so. If not the coilovers are adjustable and can easily be adjusted while on the truck.
    naterwt[OP] likes this.
  8. Nov 15, 2020 at 3:58 PM
    My 10 yr old said the truck looks higher than my old one. :notsure:
    toyofan87 and naterwt[OP] like this.
  9. Nov 15, 2020 at 4:01 PM
    TwistedTad
    Tad
    Canyon Lake, CA
  10. Nov 15, 2020 at 4:59 PM
  11. Nov 16, 2020 at 6:56 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Good morning Nate!!
    David from Tech here.
    Can you take a ride height measurement from center hub to edge of fender for me please in all 4 corners?
    TrashcanBand and T-Rex266 like this.
  12. Nov 16, 2020 at 6:58 AM
    naterwt
    Nate
    2017 crew max
    Thanks for reaching out ! Yes for sure I will when I get off work I will send you measurements ! Thanks
    Toytec Lifts[QUOTED] likes this.
  13. Nov 16, 2020 at 7:14 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    See, this is the type of stuff that earns business. I love to see it.
  14. Nov 16, 2020 at 4:48 PM
    naterwt
    Nate
    2017 crew max
    Ok so I measured. I am perfect 25.5 on both fronts and 24.5 on both rears .
