Toyota tundra
Discussion in 'New Member Introductions' started by Adrian1096, Sep 25, 2019.
  1. Sep 25, 2019 at 1:26 PM
    Adrian1096
    Adrian1096 [OP] New Member
    Adrian
    Tundra blue
    Hello good afternoon i have a 2008 toyota tundra it turns on and everything but the only rhing thats wrong with it its that it wont accelerate when you press the gas pedal it wants to turn off and its doesnt have no check enligth on
    Prostar 190, OR18TRD and Pinay like this.
  2. Sep 25, 2019 at 1:28 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome!!
  3. Sep 25, 2019 at 1:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
    Pinay likes this.
  4. Sep 25, 2019 at 1:34 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
    Pinay likes this.
  5. Sep 25, 2019 at 1:35 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Found this on the innerweb.
    The Number one cause for this condition that you have is related to 10 amp ETCS fuse being blown. This fuse is located in the fuse box under the hood. This is the main power supply for the drive by wire throttle motor. If the fuse is popped replace the fuse then ideally the varnish and carbon buildup around the throttle body i.e. the plate and bore needs to be cleaned with a clean rag and carburetor/choke cleaner. When this carbon buildup get excessive because of the plate the stick which over amps the motor and will pop this fuse.
    saybng, jewsNbrews and TXMiamiFan like this.
  6. Sep 25, 2019 at 6:47 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!!
  7. Sep 25, 2019 at 6:48 PM
    Welcome from NY.
  8. Sep 25, 2019 at 7:21 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  9. Sep 25, 2019 at 7:33 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. Sep 25, 2019 at 8:54 PM
    Welcome from TEXAS
  11. Sep 26, 2019 at 2:26 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Hey there from Virginia!:mudding:
  12. Sep 26, 2019 at 2:43 AM
    Welcome from Ohio.
