Toyota truck guy
Discussion in 'New Member Introductions' started by mercman, Apr 30, 2021.
  1. Apr 30, 2021 at 9:09 AM
    mercman
    mercman [OP] New Member
    Greetings. Proud owner of Toyota trucks since the late 70's. I currently own and drive a 1996 T100 SR5 that I bought new and, my reason for being here, a 2006 Tundra crew cab SR5 that I bought new, also.
    Of course, as is my usual protocol I only join forums when I have an issue. In this case my low beams don't function on my '06 Tundra and I'll be perusing the forums looking for some clues.
  2. Apr 30, 2021 at 9:21 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Apr 30, 2021 at 9:21 AM
    Welcome from NY.
  4. Apr 30, 2021 at 9:32 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  5. Apr 30, 2021 at 9:32 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Welcome from CT
  6. Apr 30, 2021 at 9:48 AM
    Welcome
    Pics of said T100
    Toyotanantion.com has a great T100 forum section
  7. Apr 30, 2021 at 10:44 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  8. Apr 30, 2021 at 11:51 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  9. Apr 30, 2021 at 7:29 PM
    Welcome from Ohio
  10. Apr 30, 2021 at 8:50 PM
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    Welcome from Colorado
  11. May 1, 2021 at 1:47 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
  12. May 1, 2021 at 2:01 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I believe each headlight has a separate fuse for left hi, left lo, right lo and right hi. 4 in total. If both lows are out and the highs are staying on, I would start at the relay that switches between pairs, may be stuck. Find it and tap it with pliers, see if they flash on. Seems like the easiest spot besides the fuses but a double fuse loss is probably not likely. I would start there since hi and lo share a feed but split at this point. If tapping the relay does nothing, check voltage in and out of relay for the headlight feed (R-B), We know 4 to 3 should be good because you have Hi but check it anyway, then check 4 to 1. If voltage is not leaving 4 to 1 for the low beams (when on low beam setting), check voltage to the relay coil. Operate the high and low beams and see if the coil is receiving the control voltage (2) to energize and switch the coil. Follow accordingly
  13. May 13, 2022 at 3:24 PM
    mercman
  14. May 13, 2022 at 8:26 PM
    Sick looking T
  15. May 13, 2022 at 8:33 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Welcome to the forum. A double bulb failure is possible. Most won’t notice the first bulb go out. When the second one goes, no headlight output. Check the bulbs first. Then the fuses. Then the switch. Grounds are also a possible culprit. Any other info on the truck in relation to mods that may affect the lights? The later 05-06 models are finicky with voltage for the lights. Not happy with LED’s in some locations.
