Towing with a 3" lift?
Discussion in 'Towing & Hauling' started by mlucas555, Aug 30, 2017.
  1. Aug 30, 2017 at 8:14 AM
    mlucas555
    mlucas555 [OP] New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I am looking to add a 3" lift to my truck and will change out the wheels later, staying with 18's. I have stock 18's now, that I don't like the look of, got the truck used. I got this truck to tow my travel trailer. Will the 3" lift hurt my towing?
  2. Aug 30, 2017 at 8:35 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Lift or leveling? A 3/1 leveling kit only raises the rear by 1". That's what most of us are running, and towing is fine. I don't know what affect a 3" lift in the back would have on towing. Perhaps someone with that experience can chime in. The usual rules apply with respect to trailer leveling and weight distribution.
    gosolo likes this.
  3. Aug 30, 2017 at 10:10 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Are you just looking for general impacts on towing with a 3" lift? If you stay around 3" it won't really have any noticeable impacts. The tire size will have a greater impact. The bigger you go the more you see a decline in mpgs, loss of lower end torque, etc. I'm running 35s on a 3" lift and its a little sluggish on the lower end especially when towing to compensate for the bigger heavier tires. I plan to re-gear soon which will help correct this and the mpgs. As far as towing capacity you should be fine. I added bigger shackles in the back to help with squating when towing too.
  4. Aug 30, 2017 at 11:12 AM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Thank you for the replies. I guess I don't understand the difference between the leveling and lift? I guess to me I don't notice the rake on the truck now. I don't think that I will go with tires as big as 35s, I think that I am going to stay almost stock on tire size just different wheels.
  5. Aug 30, 2017 at 12:46 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    A level kit seeks to get rid of the factory rake. Most leveling kits lift the front 3 inches and the back by 1 inch. A 2" differential is needed to "level" the tundra. Most kits add an extra inch so as to accommodate larger tires, which is why these kits tend to run 3 in front and 1 in back. It's also the case that raising the front will shift the balance point towards the rear which the rear 1" of lift probably compensates for.
    A straight 3" lift would retain the factory rake but raise the entire truck by 3".
    mlucas555[QUOTED][OP] likes this.
  6. Aug 30, 2017 at 4:59 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I am running a 3" front 2" rear kit on my truck with 35.4" tires. I tow my car trailer which with the car on it weighs about 5000 lbs for the car and trailer. I have no issues with it. I don't really know it is back there when I tow. Of course the SC helps alleviate any acceleration issues with the trailer. Also I have the TRD rear sway bar and the Sequoia front sway bar which also help.
    mlucas555[OP] likes this.
  7. Aug 31, 2017 at 11:41 AM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    How is the ride with the 3/2 lift? That seems like it would be kind of best of both lift and level.
  8. Aug 31, 2017 at 11:45 AM
    LML 3500HD
    The question I have is about the TT. How big is that and weight?
  9. Aug 31, 2017 at 12:04 PM
    Vector W8
    The ride is great the Michelin tires are road tires, not off road tires, which helps with eliminating the tire noise down the road. The sway bars have a lot to do with it also as the handling is good even through the center of gravity is increased quite a bit. I really like the way the truck rides and handles in all conditions including towing conditions.
  10. Aug 31, 2017 at 12:28 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    I have a Jayco Jay Flight, it is 33 feet long and weighs 7800 dry. I used to tow it with a Lincoln Navigator.
  11. Aug 31, 2017 at 12:31 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    I'm not sure what the sway bars do. Sorry, this is my first truck and the first time I'm trying to change things on a vehicle.
  12. Aug 31, 2017 at 12:38 PM
    LML 3500HD
    Holy crap. Well that makes a difference.
    Leveling will make it more difficult to keep a little rake, which you need ~.5" to keep the traction control from lighting up your dash like it did mine.
  13. Aug 31, 2017 at 12:43 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Just put a WDH and a sway bar and you will be fine. Try and stay away from mountains if possible lol
  14. Aug 31, 2017 at 12:49 PM
    Vector W8
    The sway bars help control roll during cornering. Get the Toyota Sequoia front sway bar and get the TRD rear sway bar and you will have vastly improved cornering with your truck. The stock truck wants to roll over and play dead in the corners.
  15. Aug 31, 2017 at 1:06 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Ok, so no leveling kit for me. I guess I will just do a 3" lift all around.
  16. Aug 31, 2017 at 1:07 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    I have the WDH and sway bar that I got when I got the trailer.
  17. Aug 31, 2017 at 1:08 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Thanks! I will start looking for them.
  18. Aug 31, 2017 at 2:31 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
  19. Aug 31, 2017 at 3:11 PM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
  20. Aug 31, 2017 at 3:27 PM
    LML 3500HD
    Is 7800 lbs the actual weight of the TT or what the factory says it is? Usually there is a big discrepancy, but really doesn't matter at this point since you will might be over the limit in payload department...but lets check.
    The numbers I know from you and the web.
    16000 GCWR (you will be good there by at least 1800 lbs)
    7800 TT
    1440 max payload on your truck, the yellow sticker inside your door frame is what it actually is.
    9800 is what you can tow, if you have a 4x4...most people do.
    980 is max tongue weight.
    So by doing the quick math in my head, 10% of your TT overall weight is tongue. So 780 lbs, before loading. I highly doubt you and the family will put in enough to get the tongue weight over, but 1000 lbs is not unheard of after water, food, camping shit everyone brings...etc. So tongue weight, worse case is 880 lbs. Your good there.
    Gross Combined is good 16K-8800-5640=1560 lbs. So I was off a little there. Close, but still good. I may have to eat some crow.
    1440 is the max payload on your truck. So this is the major unknown. Add up the wife, kids, yourself, dog and anything you put into the bed of the truck. Also verify sticker inside drivers door and adjust accordingly.
    So I am going to say you have a smoking hot wife that weighs in a 105 lbs, and you hit the gym daily and keep a slim figure 170 lbs. Not sure about kids, and lets say one 50 lbs dog. Sooooo...
    Smoking hot wife+gym rat+dog=325 lbs Not bad, and you put everything in the TT, so nothing in the bed and if you don't have kids.
    1440-325=1115 lbs
    1115-880=235 lbs left over. Shit man, your good if those weights are pretty close.
    Lifting a tow rig when you are over 80% of your tow rating can be a little sporty while towing. I have never been to San Antonio, so towing conditions are unknown. Should be good anyway, as long as the math works out and you feel comfortable and confident, enjoy the time away from the norm.
  21. Aug 31, 2017 at 3:33 PM
    be77solo
    be77solo New Member
    Run the numbers for the Lincoln Navigator he has been using ha.... He should be fine :burnrubber:
    Drive safe!
  22. Aug 31, 2017 at 4:02 PM
    LML 3500HD
    I'm assuming you don't know what is under the hood of one do you? They have the same hp as your truck and 59 lb ft tq more than you do, and it come on at low torque (damn ecoboost motors), tow rating is 8k.
    I said it would be fine, it will suck, but welcome to towing at close to max capacity with a 1/2 ton truck.
