Towing and Payload Platinum 4x4 vs 4x2
Discussion in '3rd Gen Tundras (2022+)' started by BigArt, Nov 30, 2021.
  1. Nov 30, 2021 at 8:02 PM
    BigArt
    BigArt [OP] New Member
    2008 Tundra Crewmax Limited
    Platinum 4x2 CrewMax 6.5-Ft. Vs.Platinum 4x4 CrewMax 6.5-Ft. Bed
    Screen Shot 2021-11-30 at 7.58.32 PM.jpg Screen Shot 2021-11-30 at 7.58.48 PM.jpg
  2. Nov 30, 2021 at 8:13 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    5800lbs is pretty dang heavy, plus we all know how under stated the current model tundra weight is. Real life they weigh a lot more than curb weight
  3. Nov 30, 2021 at 8:59 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    BigArt, where can I find the payload ratings for the other models?
  4. Nov 30, 2021 at 9:00 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Well dang, TIL. I found a thread you commented in from around April pointing out the calculated difference in curb weight using GVWR and payload on the sticker. Then the guy went and weighed the truck on 3rd party scales to confirm his mostly stock truck is weighing in over 6000lbs...
    https://www.tundras.com/threads/actual-specs-of-my-tundra.87603/
  5. Nov 30, 2021 at 9:02 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I thought they said the new model was gonna be lighter
  6. Dec 1, 2021 at 7:08 AM
    BigArt
    Mattedfred likes this.
  7. Dec 1, 2021 at 7:57 AM
    UATundra
    UATundra New Member
    It only lists "maximum payload", not actual configured payload.
    I built two identical SR5, DC, LB - one with the minimum package and one with the highest available package, both are specified as a "maximum payload" of 1,885 lbs.
    The payload would obviously be several hundred pounds different between the two trucks.
  8. Dec 1, 2021 at 8:05 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I think it was more of a move weight around than make the truck lighter. They used aluminum on certain panels and composite bed, but then they added weight in other areas. Especially with the hybrid. Personally, I am fine with a heavier truck as I think it will tow better.
