Tow mirror turn signals
Discussion in '2nd Gen Tundras (2007-2013)' started by NewRider, May 8, 2019.
  1. May 8, 2019 at 8:25 PM
    NewRider
    NewRider [OP] New Member
    Travis
    Roaming the Shenandoah's
    2014 Tundra Limited Crew cab w/Flatbed
    Flatbed
    I have a 2010 SR5 Off Road that I just added these tow mirrors to:
    ECCPP for Toyota Tundra Towing Mirrors Rear View Mirrors for 2007-2015 Toyota Tundra Truck with Power Heated Reflector Turn Signal Manual Extending and Black Texture Housing https://www.amazon.com/dp/B07FR59XDV/ref=cm_sw_r_cp_api_i_qR50CbKV9PH08
    When I plugged them in I expected that the backup lights wouldn’t work (and will wire that in) but did think that the front turn signal/marker lights were factory wired and they don’t seem to be?
    Anyone added tow mirrors to a truck that didn’t have them and have to re-wire things??
  2. May 8, 2019 at 8:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    To the best of my knowledge, if you have the tow package your truck should be prewired for the marker lights and blinkers on the tow mirrors.
  3. May 8, 2019 at 8:33 PM
    NewRider
    Travis
    Flatbed
    That was my thinking also @MotoTundra but they don’t work after being plugged in. The power adjust and signals in the mirror lenses work great but not the forward facing ambers
    MotoTundra likes this.
  4. May 8, 2019 at 8:50 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I did a novice write up on adding the drl to the tow mirrors (the lower led) as the platinums are for some reason not wired for this. You can use my write up tho to diagnose your problem. You need to get a 22 gauge wire up to the harness, stab it through and empty slot, plug it in and test...take a peek at my write up. Very strange though that you’re not wired for a turn signal, I hope you’ve tried both mirrors to make sure one isn’t just defective...
    https://www.tundras.com/threads/diy...power-folding-tow-mirrors.42865/#post-1096706
    NewRider[OP] and MotoTundra like this.
  5. May 9, 2019 at 4:32 AM
    NewRider
    Travis
    Flatbed
    @Jrharvey02, thank you very much!!! I’ll read through that and I’m sure I can then figure it out!
    Jrharvey02 likes this.
  6. May 9, 2019 at 4:32 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I came across this thread, which I previously commented in, and must have forgotten about.
    Seems you must have a higher trim level than SR5?
    No fixes in this thread unfortunately, but it is normal with higher trims.
    https://www.tundras.com/threads/marker-lights-on-tow-mirrors-wont-work.10661/
  7. May 15, 2019 at 5:17 AM
    NewRider
    Travis
    Flatbed
    Bump for anyone who’s had this exact issue... I’m still planning to use the above info and figure it out but if someone already has I’d rather not waste my time
  8. Dec 19, 2019 at 5:15 PM
    Meltz
    Meltz New Member
    Did you end up figuring this out? If so, how? I'm having the same issue.
