TOTAL CHAOS - 2007+ Toyota Tundra Upper Control Arm (UCA)
Discussion in 'Suspension' started by TOTAL CHAOS, Jun 12, 2018.
  1. Nov 12, 2018 at 11:52 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    i mean they are long travel but love them none the less!
  2. Nov 12, 2018 at 1:09 PM
    Tundra9831
    Tundra9831 New Member
    Am I correct to assume you don't need to loosen any bolts when spraying the Dry PTFE Lube on the Heim Joints, but you do need to loosen bolts to pump the grease in the bushings? Are the heim joint UCA's set to the same position / alignment as the bushing UCA's from the factory? Any downside to using heim model on a 3" lift other than added cost? Thanks!
  3. Nov 12, 2018 at 1:24 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    No suspension close-ups, here is my Tundra with a set of TC uppers
  4. Nov 12, 2018 at 1:33 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    bwhahahaha lol not my intent... you still running 3.0's front and rear.. i dont have that! #ithinkweareeven LOL
    831Tun, 5.7TRDProm and SoCal619 like this.
  5. Nov 12, 2018 at 4:35 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    You're correct - nothing needs to be loosened when lubricating heim joint models. These are designed with added caster built-in for lifted applications. The heim joints offer an increased adjustment on top of this. We can send you alignment and install instructions for the heim joint UCA's (info@chaosfab.com). No downside other than what you've already mentioned (more $$$)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  6. Nov 12, 2018 at 4:36 PM
    TOTAL CHAOS
    Corona, CA
    :hungry:
    papasmurf[QUOTED] and SoCal619 like this.
  7. Nov 27, 2018 at 9:57 AM
    TOTAL CHAOS
    Corona, CA
    TOTAL CHAOS suspension systems & accessories are 100% Made in the USA and handcrafted by our fantastic team in Corona, CA. TC’s experienced fabricators work very hard to provide top performing products that are built to last and also look great. The best companies in the industry provide components like bushings, uniballs, and hardware (all 100% Made in the USA). Each component is hand-picked and tested over thousands of miles to give you maximum performance and durability.
    CLICK HERE to learn more about TOTAL CHAOS products and to check out our current offerings for your ride!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  8. Nov 27, 2018 at 10:02 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    id love to know what settings you are running on that Mig, and are you using 75/25 gas? Those are some good looking welds!
    Erichudgins and SoCal619 like this.
  9. Nov 27, 2018 at 1:13 PM
    TOTAL CHAOS
    Corona, CA
    It’s a special recipe that’s top secret :D
  10. Nov 30, 2018 at 10:19 AM
    TOTAL CHAOS
    Corona, CA
  11. Dec 2, 2018 at 12:15 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    My truck only has 3000 miles on it. Looking for ANY excuse to get these UCAs. I get all warm and fuzzy over hand crafted USA hardware.
  12. Dec 2, 2018 at 2:39 PM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Most of my stock components came off at about 500 miles, no excuses needed lol.
  13. Dec 3, 2018 at 7:44 AM
    TOTAL CHAOS
    Corona, CA
    Your truck will perform better with TC UCA's and look a bit nicer than the rest with some suspension bling ;)
    Let us know if you have questions, happy to help! Can place an order when you're ready as well (Info@Chaosfab.com)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    papasmurf, SoCal619 and 5.7TRDProm like this.
  14. Dec 12, 2018 at 11:42 AM
    Bailey
    CO
    Finally have close-ups worth sharing :cool:
  15. Dec 12, 2018 at 12:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    NICE!!!!!!!!!!!!!!!
  16. Dec 12, 2018 at 2:52 PM
    TOTAL CHAOS
    Corona, CA
    :yes: That's what we like to see
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    SoCal619 likes this.
  17. Dec 13, 2018 at 4:20 PM
    Bmendez1124
    Bmendez1124 New Member
    Modesto, CA
    2016 Tundra Crewmax
    ◾️Mod List: 2016 MG Tundra Crewmax ◾️Rims: @methodracewheels — Con6 18x9 ET +18 ◾️Tires: @bfgoodrichtires — KO2’s 35x12.5x18 ◾️Suspension: @kingshocks ◾️Headlights: @spyderauto ◾️Fog lights: @cali_raised_led ◾️Bed Rack: @max_modular_truck_bed_racks ◾️RTT: @tepuitents — Explorer Kukenam 3 ◾️Tanks: @rotopaxofficial ◾️Suspension/Wheels/Tires work: @88rotorsoffroad — One of the best spots for any of your truck work.
    D5509A9F-83F9-46ED-9566-5EF4647F2BBF.jpg 7F1620F6-E893-4861-8D04-96B4F2885F2B.jpg I need these in my life!!!!
  18. Dec 14, 2018 at 7:36 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    I feel like... those pictures are at 88 Rotors.
    TundraDDS likes this.
  19. Dec 14, 2018 at 8:13 PM
    #49
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    That would be correct sir
  20. Dec 16, 2018 at 7:23 PM
    #50
    TOTAL CHAOS
    Corona, CA
    We can help with that :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  21. Dec 16, 2018 at 7:31 PM
    #51
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Is Santa sending a set my way? lol jk in time there will be a set to go along with everything I know the quality of the product is worth it
  22. Dec 27, 2018 at 1:10 PM
    #52
    TOTAL CHAOS
    Corona, CA
    : @mademan⁣925
    48406919_2609170362456829_28934093787134_c86ea116c56bc514716b444a603fbd26e7ccfdf1.jpg
    Hope everyone is enjoying the holidays! We are grateful for our extended family of TC customers and the amazing companies that represent our brand across the globe. THANK YOU for a wonderful 2018.⁣
    Did you get a set of TOTAL CHAOS Upper Control Arms under the Xmas tree?
    If not, give one of our Authorized Dealers a shout to place an order!
    Note: We'll be back in the shop 1/7 if you need anything directly. Give us a ring!
    See YOU in the NEW YEAR!!!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  23. Jan 15, 2019 at 12:52 PM
    #53
    TOTAL CHAOS
    Corona, CA
    Often Imitated. Never Duplicated.
    Made in the USA - Hand Crafted
    • Custom Hi-Misalignment Spacers
    • 100% Stainless Steel Uniball's w/ PTFE Liners
    • 4130 Chromoly Tubing
    • 100% Bolt-On
    • 3 Stage Powder Coat
    2007-2019 Tundra UCA's + King 3.0" Coil Over Shocks = Lift - Wheel Travel - Ride Quality - Off Road Durability.
    Upgrade option: TC Stock Length Lower Control Arms that retain the Sway Bar.
    HERE
    49914673_2660315010675697_28186052261041_4d087912933ba0bf345fcbe4c75c913ddb2e6cb9.jpg
    49938309_2660314977342367_11780464791728_3cce748e440e5e6864caf613f7a6c338132d1962.jpg
    49900500_2660315090675689_48738896229097_46955b54eb4c04920d6950e800953de6765b37e2.jpg
    50077689_2660315117342353_54189296228363_dea25e8ad6e5d0840c961c5632e89570d3089305.jpg
  24. Jan 15, 2019 at 1:39 PM
    #54
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    such a killer setup
  25. Jan 15, 2019 at 5:01 PM
    #55
    Varmit
    Varmit New Member
    Bill
    Black tundra
    All
    Nice doing same setup
  26. Jan 17, 2019 at 4:25 PM
    #56
    TOTAL CHAOS
    Corona, CA
    :hattip:
    :cool: Sweet!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  27. Jan 17, 2019 at 4:26 PM
    #57
    TOTAL CHAOS
    Corona, CA
  28. Feb 19, 2019 at 12:17 PM
    #58
    TOTAL CHAOS
    Corona, CA
  29. Feb 25, 2019 at 6:23 PM
    #59
    TOTAL CHAOS
    Corona, CA
    TC FUN FACT⁣⁣
    Not all things are created equal. ⁣⁣
    - 1 1/4 x .120 4130 chromoly tubing.⁣⁣
    - Custom machined uniball cups.⁣⁣
    - Production stamp coded.⁣⁣
    Did you know that all TOTAL CHAOS suspension components are part number stamped and production stamp coded?⁣⁣
    UCA's are stamped on the pivot gussets. ⁣⁣
    This information is very helpful to our tech support staff when they are helping customers that have purchased used TC equipment.⁣⁣
    https://www.instagram.com/p/BuT-q_OBQHl/
    tundra_20 and 5.7TRDProm like this.
  30. Mar 26, 2019 at 3:35 PM
    #60
    TOTAL CHAOS
    Corona, CA
    We know this isn't a Toyota but what do you think?!
    New Ranger parts coming SOON!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Kerch71 likes this.
