Topper Removal - help needed
Discussion in 'Tonneau Covers, Caps and Shells' started by denali302, Aug 30, 2021.
  1. Aug 30, 2021 at 4:45 PM
    denali302
    denali302 [OP] Meh...
    Michael
    2017 Crew Max
    So… I can’t get my topper off. Topper has been on for 3-3.5 years. The clamps are off, third brake light is disconnected.
    that said, it’s stuck and I’m not sure how much upward pressure is safe, or even really how to do it. Tips for ‘braking the seal’ by myself?
  2. Aug 30, 2021 at 4:49 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    If it was installed properly with some foam, it’ll take a decent amount of pressure to break that seal. You’ll need at least 2, ideally 4, people to get it off and set it down softly.
  3. Aug 30, 2021 at 4:51 PM
    denali302
    Michael
    2017 Crew Max
    I don’t actually need to take it off, I just need to pop it free so I can get a few blocks under it… I’m installing a topper lift, but gotta do the first one manually
  4. Aug 30, 2021 at 4:58 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    Best way is to get on one side and lift each corner a little at a time. It’ll gradually start to break the seal. You ought to be able to lift it enough to slide a couple of short blocks in on each side. Just don’t tilt it too far….
    15whtrd and denali302[OP] like this.
  5. Aug 30, 2021 at 5:06 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I use a small pry bar to break the seal myself,not a crowbar with a round hook but something with a broad wider prying surface and maybe stick a towel or something soft as the face between painted surfaces of the top and bed if thats what you have? Fiberglass or metal top?
    denali302[OP] likes this.
  6. Aug 30, 2021 at 5:07 PM
    denali302
    Michael
    2017 Crew Max
    Fiberglass
  7. Aug 30, 2021 at 5:32 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Just be careful and take it slow and once a small part breaks loose the rest should be easy to get going.
    I use small blocks of 2x4 then and either lift it 2 or 4 inches while rigging the lift.
  8. Aug 31, 2021 at 8:02 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    When I had to pop mine off, I crouched down in the bed and pushed up in the center of the roof with my back and it broke free.
  9. Aug 31, 2021 at 8:06 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Same
  10. Aug 31, 2021 at 9:00 AM
    denali302
    Michael
    2017 Crew Max
    OK - that makes sense and what I wonder is what I needed to do
  11. Sep 1, 2021 at 1:13 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Same here. I would just push it up with my back. To remove it, I would then walk it back till about 40% was off of the bed. I would then jump down and use a couple of friends to lift it off the rest of the way.
  12. Sep 1, 2021 at 1:23 PM
    BAMtruck
    BAMtruck New Member
    SW CO
    2015 DC SR5 5.7L MGM
    275/70/18 BFG's, ARE MX Topper
    Glad to see there isn't some amazing way of doing this that I hadn't thought of. This has always been my approach.
  13. Sep 1, 2021 at 1:27 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    ^^^^^Same here^^^^^
  14. Sep 1, 2021 at 3:03 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    +1 more here.
  15. Sep 1, 2021 at 3:12 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Took mine to a shop to get resealed about $200 "they used a forklift" vs breaking something... me or my Tundra.
  16. Sep 4, 2021 at 8:55 PM
    denali302
    Michael
    2017 Crew Max
    Well - it worked. Thanks everyone. And, got the lift / tent installed.
    Chrslefty, KK6PD, Dr Doobie and 3 others like this.
  17. Sep 5, 2021 at 6:03 AM
    ezdog
    ezdog New Member
    Gateway To The West
    So what did it take?
    Was there carnage?
  18. Sep 5, 2021 at 6:22 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Such a cool setup. Any more pictures? I really like their products but don't see them out in the wild much at all.
  19. Sep 5, 2021 at 6:24 AM
    denali302
    Michael
    2017 Crew Max
    No carnage, not really. There might an extra hole or two, but I can hide those. I did have to cut into my decked system, but it worked just fine. I’ll get some more pics up this week.
    other than testing in the driveway, I haven’t used it. I like it but think I need to make some adjustments in the tent for a better fit
    300BLK likes this.
