Too much of a lift???
Discussion in 'Suspension' started by TXRailRoadBandit73, Jul 29, 2016.
  1. Jul 29, 2016 at 7:10 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Of course we know I have a '14 Tundra CM 5.7F...my ? is...is the lift I have on the truck too much on tranny and engine??? Also tires I'm running are 35*12.50R20... Lift is a rough country 4.5 other complaints I have that I have stated before are wider turning range and CV axle angels..but my main ? was...is that lift too much work on tranny n engine with those tires??? truck came that way when I bought it
  2. Jul 29, 2016 at 8:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    A little off topic, but could you do us all a favour and stop with the vague thread titles?
    The lift and the tires are going to make everything work harder. Your truck was made for work, but wasn't designed to be lifted. So, yes and no.
  3. Jul 29, 2016 at 10:06 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    rons23, Wynnded[QUOTED] and boardude like this.
  4. Jul 29, 2016 at 10:49 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Without gearing change the 35" tires do put extra strain on the engine/tranny. Its not too much as you have 4:30 gearing in the diffs.
  5. Jul 29, 2016 at 10:49 PM
    csuviper
    Broomfield, CO
    Not far outside the range:
    Wynnded likes this.
  6. Jul 29, 2016 at 10:51 PM
    csuviper
    Broomfield, CO
    The height hurts mpg because of increased drag.
    Too much angle on the cvs and your causing premature wear of the cvs and wheel bearings.
  7. Jul 30, 2016 at 4:18 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Bad cv axle angle? Definitely a bad news.
  8. Jul 30, 2016 at 6:46 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Dang, I have the 4.6 L with the tow pkg (diff of 4.11) I'd be fine wth 34's looks like. Wouldn't be able to tow much though LOL
  9. Jul 31, 2016 at 8:22 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Usually not many people agree with me but ill throw my 2 cents in...
    If you plan to run 35s forever- invest in 4.88 gears IMHO. Yes your RPMs will be higher on the freeway but that does not directly correlate to less fuel economy, lot of people forget to also consider engine load. Just because your turning less RPM does not mean your using less fuel.
    It is a bit of an investment especially if your 4x4, worth every penny IMO. Less powertrain/driveline stress, torque curve at or starting lower than factory and fuel economy at or better than originally.
    TruckyTruck likes this.
  10. Jul 31, 2016 at 2:57 PM
    TruckyTruck
    Gary
    I don't ever plan to go lower than 35s. I just didn't think the truck needed it until you got into the 37s range. I'm not to knowledgeable on regearing though. How much higher in rps on the freeway?
