Too many miles for towing??
Discussion in '2nd Gen Tundras (2007-2013)' started by Theslickhick, Jun 3, 2020.
  1. Jun 3, 2020 at 6:12 AM
    Theslickhick
    Theslickhick [OP] New Member
    Hi!
    I am in the market for a used Tundra that would primarily be used part time for towing a 6k pound camper. I think I may have found a contender, but with some concerns.
    Its a 2012 Tundra Crewmax limited 4x4, interior looks to be in excellent condition, the body has some scuffs and scratches but nothing that doesn't look too bad or outside the norm for its age, underneath shows no sign of damage or excessive rust, and it has a clean carfax that shows regular dealer maintenance. I'm hoping to test drive today and see how it is.
    My only concern is the milage, at 152k. If I weren't towing I don't think i'd be concerned. But since the primary reason is to tow, are the miles too high? Too much risk? Any reason to think towing with this many miles is a bad idea?
    Any thoughts on the subject are appreciated!
  2. Jun 3, 2020 at 6:20 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Tune up, service the trans and driveline, probably new shocks and struts, then send it.
  3. Jun 3, 2020 at 6:31 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    ^ this, and have a mechanic check the truck BEFORE you buy it.
  4. Jun 3, 2020 at 6:34 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I wouldn't be worried about the miles at all, as long as the maintenance has been done regularly. Even then, its probably fine.
    Cpl_Punishment likes this.
  5. Jun 3, 2020 at 6:51 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Shiiiiiit that's nothing. I bought my 08 with 180k on the clock and all stock, it's now supercharged and has 230k+ on it and tows weekly.
  6. Jun 3, 2020 at 7:16 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    My husband has over 300k on his truck and we tow our 5500# camper a few times per year (2200 mile trips usually) without issue and trust it to do so. If theyre maintained properly they’ll go forever.
  7. Jun 3, 2020 at 8:22 AM
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    Yeah i wouldn't sweat that mileage at all if its been taken care of.
  8. Jun 3, 2020 at 8:28 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m on just about 300k and this my tow truck :)
  9. Jun 3, 2020 at 10:29 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That's nothing to worry about. Get the truck checked before buying it to make sure it's proper. The keep up on maintenance if you buy it.
    Mountun Goat and Cpl_Punishment like this.
  10. Jun 6, 2020 at 10:26 AM
    Nic1226
    Nic1226 New Member
    Jerome
    2013 Gun metal Gray
    Would you feel safe pulling a 8000lb travel trailer with a 2013 tundra rock warrior 5.7L
  11. Jun 6, 2020 at 2:07 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    (Tongue in Cheek) Thoughts on the subject? Aw, well, shoot yeah. You're asking us to put miles on the bottom "X" axis of "The Famous Bathtub Curve", and that's tricky.
    Nobody knows when a Tundra wears out because a Tundra "wearing out" has never been reported. A couple have lasted a million miles, and then Toyota just bought them back so they could mic the bearings and such. If you keep replacing worn out parts, a Tundra could theoretically last forever like cars in Cuba.
    The problem is that all the parts of a vehicle don't wear out at the same rate, and the failure of any single part might leave you standing beside the road. There is always risk when towing with any number of miles, and you have to decide just how much risk you can handle re the time lost, repair expense, etc.
    Know your vehicle, address every new noise, maintain the highest possible maintenance level as recommended, then you will have done all you can do to guarantee reliability outside of buying a more expensive, lower mileage tow vehicle. Reliability will be easier to achieve with a Tundra, than with any other brand with the same miles.
    I have drawn a red "X" on "The Famous Bathtub Curve" (see below) for my estimated position of 152K mile Tundra. I have also included the link to the original article if you want to play with the calculations on your own. (Just kidding you...nobody can tell you when a vehicle will fail, but you've gotten some great 300K-and-still-going-strong reports here). Good luck with your Tundra. :D
    https://ftp.automationdirect.com/pub/Product Reliability and MTBF.pdf
    XPTUNDRA likes this.
