To shackle or not to shackle
Discussion in '2nd Gen Tundras (2007-2013)' started by Sequoia45, Apr 8, 2019.
  1. Apr 8, 2019 at 6:03 AM
    Sequoia45
    Sequoia45 [OP] Mountain man
    Joseph
    Louisiana
    Toyota Tundra
    Afe cold air. OME 2.5" lift. Bully dog tunner.
    Alright to get to the point i am ordering a 2.5 ome suspension lift from toytech. What i am debating is should i spend the extra $219 and get the adjustable toytech shackles. So i would be adding 2.5" lift pluse another 1" of lift in the rear. Is this to much rake and would it help the suspension travel? Thanks for the input i should be ordering some time this week.
  2. Apr 8, 2019 at 6:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    IMO, 1" rake is not very much, helps keep looking like a truck. Not sure if it helps with suspension travel.
    Also with any kind of modest load or trailering, it will be less likely to have negative rake. Over time the rear leafs weaken and sag, you can adjust as needed to add rake back in.
    Sequoia45[OP] likes this.
  3. Apr 8, 2019 at 8:29 AM
    Trooper2
    JR
    FYI, There are also less expensive but adequate adjustable shackles available, about 40% less.
  4. Apr 8, 2019 at 8:36 AM
    Sequoia45
    Joseph
    Louisiana
    Toyota Tundra
    What company? The only two i have seen discussed is toytech and CB
  5. Apr 8, 2019 at 8:40 AM
    Trooper2
    JR
    Got these on Amazon. Others available.
    Beefier than stock. Pic shows adjustable, got the 1", wish I had gotten the 1-2".
  6. Apr 8, 2019 at 8:45 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Get the shackles, I’m adding some to my truck this week. I like the way my truck looks with the rear slightly higher than the front. Just a little north of level. And I agree you can find them cheaper than 200 bucks. I jumped the gun and bought CB witch are very expensive for what they are.
    TacoWuzzaTurd and Sequoia45[OP] like this.
  7. Apr 8, 2019 at 8:58 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Agree with above. I’m getting my install in a couple weeks CB 2” which give you 1.25” lift in the rear. Hopefully this will level out my front. Coach builder is a little expensive than others but it looks quality.
  8. Apr 8, 2019 at 8:59 AM
    Omohundro
    Jody
    McMinnville TN
    CB are beefy for sure
  9. Apr 11, 2019 at 7:05 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    I had Toytec shackels on my Tacoma for 10+ years with no issues. I think they look better, and supposedly increase articulation vs block/add a leaf.
