Tire rub help!
Discussion in 'Wheels & Tires' started by CHRISTINAJV88, Jun 4, 2018.
  1. Jun 4, 2018 at 9:47 AM
    CHRISTINAJV88
    CHRISTINAJV88 [OP] New Member
    Christina
    2014 grey Tundra TRD 4x4
    inch lift 35 inch tires running boards
    I just installed this 4 inch ready lift kit and 35 inch tires on my truck the ready lift kit said that it would fit 35s I have also installed some wheel spacers which has helped not rubbing on the frame but I am now having rubbing on the body? any suggestions I am not in a position to go down to a smaller tire I dont have the funds for that at this moment.
  2. Jun 4, 2018 at 10:00 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Body mount chop?
  3. Jun 4, 2018 at 1:00 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    What offset are the wheels and how big is the spacer?
  4. Jun 4, 2018 at 1:43 PM
    chphilo
    chphilo Tundra addict
    Western PA
    If tires are rubbing on the body mount (I assume), then the wheels/tires are pushed out too far. Specs that parker mentioned will be helpful. Can you also tell us how wide the wheels are?
  5. Jun 5, 2018 at 10:01 PM
    CHRISTINAJV88
    Christina
    They are 35×10 20 inch wheels -24 offset
  6. Jun 5, 2018 at 10:24 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    -24 and spacer? Seems like too much. Have you tired just the wheels and tires without the spacers?
    joonbug and monaco730 like this.
  7. Jun 5, 2018 at 10:34 PM
    CHRISTINAJV88
    Christina
    Yes only put spacer on yesterday took them off today it looks as if im gonna have to modify my truck a little bit I didnt want to but that or go bigger to a six inch lift which i cant afford at the moment
    jewsNbrews likes this.
  8. Jun 5, 2018 at 10:42 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Have you looked into a CMC? That could save you your troubles. Check this out and see if it could help areas of your rubbing.
    https://www.tundras.com/threads/front-body-mount-chop-bmc.2414/
  9. Jun 6, 2018 at 12:42 AM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    Looks awesome! This concerns me because I just got the RC 3" lift level kit , 18x9 with +18 offset and Nitto Trail Grappler 35x12:50x18's. Im gonna be super pissed if mine rub! I told every single person if its gonna rub Im not buying it! I. Not chopping jack shit on my truck! They all said over and over and over it will not rub Sir. Im gonna ask you 1 more time ARE YOU ABSO FUCKING LUTELY SURE?????? NO SIR THEY WILL NOT. I'm about to find out.
    jewsNbrews, monaco730 and Prostar 190 like this.
  10. Jun 6, 2018 at 4:37 AM
    parker44
    parker44 New Member
    You are going to probably be close with the true 35's. Hopefully all yours may be is just removing mud flaps, bending skid plate and moving the front fender liner.
  11. Jun 6, 2018 at 5:21 AM
    Welcome from Texas @CHRISTINAJV88 and welcome to THE MGM CRÜE sweet rig !
  12. Jun 6, 2018 at 5:39 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    the OP has a -24 and you have a +18, you'll be fine
  13. Jun 6, 2018 at 5:57 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have the ready lift 3/1 kit and just got 295/70/18 tires with +20 offset wheels and i rubbed the front mud flaps so i had to remove those. I rub in reverse at almost full turn but i can live with that. 35's, you're gonna get some rub. My kit is "supposed to fit 35's" as well and mine are like 34.5".
    4x4_Angel and jewsNbrews like this.
  14. Jun 6, 2018 at 6:19 AM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Well if I rub I will will update you and the people misinforming the hell out of all of us!
  15. Jun 6, 2018 at 6:57 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Let us know. Cause I've been told opposite. No chop, no trim to truck need 6" of lift. Can be done with 3 but CMC needed.
  16. Jun 6, 2018 at 9:21 AM
    ZPMAN
    Minnesota
    I did as 4" lift with 35s (34.8 as i remember) 20 offset. Did not have to do the body mount chop, you can during alignment offset the lower a-arm foward just enough to clear with no rub. Had to bend the Fwd plastic wheel well mounts (1/4") then add a little heat to the plastic for another 3/16 or so for no rub, easy to do. Then a rubber mallet on the skid plate. As i remember.
  17. Jun 6, 2018 at 9:29 AM
    Rextinkleton93
    Rextinkleton93 New Member
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    It’s still going to rub at full lock
  18. Jun 6, 2018 at 9:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It's gonna rub
  19. Jun 6, 2018 at 12:24 PM
    Tundradrenalin
    Virginia Beach, VA
    I am running king coilovers with tc ucas (4 deg caster) on method standards 18x9 +18 wrapped in 285/75/18 Toyo RT's and I did NOT do the CMC because it does not rub. Trimmed the front fender liner a bit and removed the mud guards. Front lift height is right at or just below 3 inches.
  20. Jun 6, 2018 at 12:43 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    285/75 isn't a true 35 either. True 35's will need the CMC. Or that's my understanding. Kinda like stock can fit 285/65 but a 33" will need trimming.
  21. Jun 6, 2018 at 12:49 PM
    Tundradrenalin
    Virginia Beach, VA
    both 285/75/18 and 35x12.5x18 are specified as 34.8 diameter by Toyo.
  22. Jun 6, 2018 at 12:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Interesting. I know some say that the tires are certain size. And then the tire calculator says it should be this tall, but the different company websites say smaller or taller than that. Guess it's like cloths...close enough. I am 3 different size shirts depending on brand bought. Tires no different then? :notsure:
    joonbug and TheBeast like this.
  23. Jun 6, 2018 at 1:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They just round it to the closest tire size. Otherwise there will be too many different sizes. But the major difference between the 285 and 35x12.5 is the width. That extra 1.3” will make a huge difference in rubbing.
    TheBeast and jewsNbrews[QUOTED] like this.
  24. Jun 6, 2018 at 1:20 PM
    TheBeast The Beach
    don't we all wish..:D
  25. Jun 6, 2018 at 1:22 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    :popcorn:
    TheBeast likes this.
  26. Jun 6, 2018 at 2:56 PM
    ZPMAN
    Minnesota
    Rubbing is good as long as someone elese is doing it.:boink:
  27. Jun 6, 2018 at 3:02 PM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Rasied hell today! Sure as shit I was informed incorrectly. I do need a 4-6" at a cost of $1,050 and is a massive undertaking according to RC and TPM. There is no way in hell I am going through all that right now. My shop is full throttle hell right now and Im short staffed and under the gun. Calling tomorrow to say swap them for 33x1250x18 slap in the 3inch RC lift and throw in the towel. Not gonna give myself a stroke over this shit. I dont chop chop my vehicles. I will do a 6" lift and go bananas on my new Dodge Ram 3500 Big Horn Turbo Diesel next year when I get it and take that truck to my grave. LoL
  28. Jun 6, 2018 at 4:12 PM
    ZPMAN
    Minnesota
    Did i mention stroking good as long as lade da da?
