Tire question......sorry
Discussion in '3rd Gen Tundras (2022+)' started by cpdjfd107, Dec 13, 2021.
  1. Dec 13, 2021 at 2:40 PM
    cpdjfd107
    cpdjfd107 [OP] New Member
    2022 SR5 TRD Off road
    I'll be taking delivery of my 22 next week. SR5 Crew Max with TRD OR package. The Michelin tires are getting removed ASAP. They are 265/70/18. I want to move up a little. I'm torn between 275/70/18 or 285/70/18. If anyone has upgrade their tires please show some pics and let me know what you went with. A lift isn't available yet so they'll need to fit without a lift. It seems 285/70/18 will fit but the safer option is 275/70. More tire choices in 275/70 as well. My 2011 Rock Warrior stock size tires are 285/70/17 so assuming Toyota didn't change much in the geometry or wheel well size 285/70/18 should fit without any modifications needed. If anyone has any ideas or opinions let me know. Thanks!
    TK1979 likes this.
  2. Dec 13, 2021 at 2:43 PM
    Breathing Borla
    Northern Illinois
    your blazing a trail my man, not may people even have one of these yet, let alone tire swapping.
    the last gen info is meaningless, all new truck
    your dealer, or tire dealer should be able to test fit and see if there is rubbing lock to lock or at full suspension compression
  3. Dec 13, 2021 at 2:45 PM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    Congratulations what color are you getting? Looking forward to seeing what size tires work on the 22.
    TK1979 likes this.
  4. Dec 13, 2021 at 3:18 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    maybe some pictures of your wheel wells and with the tires turned to help indicate clearance you have when you get the truck would help. From there you could kind of gauge the rub spots and how much room you have.
    TK1979 likes this.
  5. Dec 13, 2021 at 3:47 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    There’s a bunch of lifted and moded 2022’s all ready. Search Facebook or google will probably get the info your looking for.
    I’m surprised this forum has so few actual 2022 owners yet. There’s dealers lifting trucks on the lot.
    TK1979 and Totherion like this.
  6. Dec 13, 2021 at 4:32 PM
    Totherion
    Totherion New Member
    What's wrong with Michelin LTX A/T?
  7. Dec 13, 2021 at 4:33 PM
    Totherion
    Probably tired of the trolls saying how ugly their new truck is.
  8. Dec 13, 2021 at 4:42 PM
    cpdjfd107
    They belong on a Camry lol. They are probably a half way decent tire but they look horrible IMO. I'm the original owner of my 2011 Rock Warrior and I've had BFG A/T K0/K02 for the last 11 years so I'm used to that kind of look. I'm definitely going to change just don't know if I'll go 275/70 or 285/70. I want to get it done at dealership before I take delivery so maybe they will give me a little credit for the Michelin AT towards new tires.
    NumberOfTheDay and TK1979 like this.
  9. Dec 13, 2021 at 4:58 PM
    Totherion
    Fair enough.
    Ask a dealer to throw some tires on your truck and see how big you can go.
    I'd play it safe and go 275/65
    TK1979 and cpdjfd107[QUOTED][OP] like this.
  10. Dec 13, 2021 at 5:24 PM
    biebs96
    PA
    Maybe consider finding a good private tire shop. Let them know what you are after and see if they will let you toss one on a rim and turn the wheel lock to lock once on the ground.
    Private shop will usually be more willing to work with you if they know they are getting business one way or another.
    cpdjfd107[OP], TK1979 and Totherion like this.
  11. Dec 14, 2021 at 9:16 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I'm currently looking for a local shop to help me upgrade instead of going to Discount Tire but I think I'm going to play it safe and go with 275/70/r18
  12. Dec 14, 2021 at 9:39 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    22+ tundra facebook page is your friend
  13. Dec 14, 2021 at 9:41 AM
    SLVR6
    SLVR6 New Member
    It looks like the Pro which has 285/65/18's has the wheels spaced out a little so be careful of rubbing. Is your intention to move of it tire height for ground clearance? Or just to a better tire? Asking since the stock 265/70/18's and the 285/65/18's on the Pro are basically the same diameter.
  14. Dec 14, 2021 at 9:55 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Just know that going up a size adds weight, side walls are “E” rated (rough ride) and a taller tire takes more effort to turn, will hurt mileage if you care, etc…yep, for example, the AT3s I have that are one size up from stock look really cool but that’s it. Not ideal on the street.
  15. Dec 14, 2021 at 9:59 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I don't buy tires for looks. I buy tires for function. Michelin makes street tires not aggressive off road tires. They are good street tires. For fitment turn tires full lock and measure clearance with Michelins. Then take the diameter difference and half it. Also check clearance to upper ball joint. Then look at the width difference.
    MoneyMan55 likes this.
  16. Dec 14, 2021 at 1:18 PM
    BlueMeany
    BlueMeany New Member
    Finger Lakes NY
    2018 Tacoma SR5
    https://www.tacomaworld.com/tirecalc
    this’ll let you see all the differences in size from each aspect. Including how much it’ll throw off your speedo. Generally you can change 10% without rubbing, in any dimension, on a stock vehicle. But not always. As others have said, you’re on a path few have tread yet, and your findings will influence others that get their trucks later, which is pretty cool!
    ja5er likes this.
  17. Dec 14, 2021 at 1:27 PM
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    They installed Michelin LTX trail on my 22 and it supposed to come with All terrain tires. The dealer agreed to switched them out for AT tires.
    they don’t look good to even fit the truck in my opinion. Would like to have some what aggressive looking tire until it gets lifted and wheels replaced.
  18. Dec 14, 2021 at 1:39 PM
    ja5er
    ja5er New Member
    New York
    here’s another good site with picture comparison, helps get an idea of visually the width and height
  19. Dec 14, 2021 at 11:47 PM
    Dav123
    Dav123 New Member
    David
    Dmon187 likes this.
  20. Dec 15, 2021 at 7:44 AM
    ja5er
    ja5er New Member
    New York
    Borrowed from FB, but looks like 295/70s fit alright. Hope they don’t mind me sharing
    Dmon187 and biebs96 like this.
  21. Dec 15, 2021 at 7:50 AM
    Dmon187
    Dmon187 New Member
    DFW
    Had I known this I would’ve got this tire size!! Oh well I’ll just wait until I do the whole lift and all.
  22. Dec 15, 2021 at 8:01 AM
    ja5er
    ja5er New Member
    New York
    those look slick, I’m just not keen on dropping $1500 out the gate (for something that is already brand new), but I’m kinda cheap and saving for boards and cover first. :)
    Dmon187[QUOTED] likes this.
  23. Dec 15, 2021 at 8:02 AM
    Dmon187
    Dmon187 New Member
    DFW
    Yeah boards are definitely on my list as the first purchase.
  24. Dec 15, 2021 at 9:12 AM
    Dav123
    Dav123 New Member
    David
    In the video on this truck, he says they are 295/70r17, which are 33", but the wheels look to be toyota 18" so think he meant to say 295/70r18, in that case these are 34.3".
    Bob_Loblaw likes this.
  25. Dec 15, 2021 at 10:11 AM
    Kanobi13
    Kanobi13 New Member
    I would look at price as not much difference in sizes
