Tire help
Discussion in 'Wheels & Tires' started by Pitbull9768, Mar 7, 2018.
  1. Mar 7, 2018 at 2:44 AM
    Pitbull9768
    Pitbull9768 [OP] New Member
    2010 Toyota Tundra
    3" Sky Jacker Lift, Brute Force CAI, Glass Pack Dual Exhaust.
    I'm looking for opinions on the biggest tires I can run on my Yota without any rub and or buying new wheels. The following is my current setup:
    3" Skyjacker lift
    Alloy TRD wheels 17x8x55
    JS
  2. Mar 7, 2018 at 3:13 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have no idea what 17x8x55 means for TRD wheels.
    Is your wheel TRD Rock Warrior wheels or TRD Off-road wheels? Rock Warrior wheels are 17x8 (50 mm offset) and TRD Off-road wheels are 18x8 (60 mm offset).
    I am guessing you have Off-road wheels. In that case, 295/70/18. You may have to massage the plastic liners a little,
  3. Mar 7, 2018 at 5:01 AM
    Pitbull9768
    2010 Toyota Tundra
    Thanks for the reply! 17x8 (50 mm offset) are the size of the TRD wheels on the Tundra. What about if I added spacers or is that the biggest the wheel can handle? I would really like to move up to 35" from 33".
    JS
  4. Mar 7, 2018 at 5:19 AM
    15whtrd
    15whtrd Mr. Blonde
    Unless you’re rubbing the UCA, spacers will make it rub the fender liner worse.
  5. Mar 7, 2018 at 9:23 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    NCinCO likes this.
  6. Mar 7, 2018 at 10:05 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
  7. Mar 10, 2018 at 4:26 AM
    Pitbull9768
    2010 Toyota Tundra
    I have the TRD Rock Warrior Wheels which are 17x8 with 50mm offset. My 2010 Tundra SRS Double Cab 4x4 also has a 3-inch Skyjacker lift. I'm looking to mount the biggest tire possible on the current set-up. Thanks.
    JS
