Tightened my oil filter to tight
Discussion in 'New Member Introductions' started by tiscarenon, Sep 17, 2021.
  1. Sep 17, 2021 at 1:14 AM
    tiscarenon
    tiscarenon [OP] New Member
    Nicholas
    2006 toyota tundra double cab 4.7 v8
    K n N flow master exhaust system intake/ outtake,surround sound system 2amps,3inch leveling kit with 20 inch rims.
    Hello my name is Nicholas I am new I have a 2006 Toyota tundra which I recently did an oil change en tightened the oil filter too tight and and drove about a mile set my car for about 30 minutes till I decide to drive back home and find oil in my driveway Does anybody have any clue or tips to clean my engine and undercarriage an undercarriage of 7 qt of oil
  2. Sep 17, 2021 at 1:15 AM
    tiscarenon
    Nicholas
    So I replaced the oil filter and turned it half a clockwise by hand hand and put 7 qt of oil back in my truck and now I face a shit load of oil to clean my engine was immaculate until this accident or this accident and I'm discouraged that in my harm the vehicle
  3. Sep 17, 2021 at 1:41 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Are you sure you didn't end up with 2 filter o-rings smashed together? 1 from old filter and 1 from new.
    Black Wolf and Desert Dog like this.
  4. Sep 17, 2021 at 3:50 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
    FrenchToasty likes this.
  5. Sep 17, 2021 at 3:55 AM
    timsp8
    NY
    I forgot the O ring once and had oil all over my engine just from starting the truck. I just kept washing it off until it eventually was gone. It took a few months and several times spraying it down. Not environmentally safe but at this point you can’t collect every drop of that oil.
  6. Sep 17, 2021 at 5:16 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I did something similar many years ago. I took my truck to a self car wash, sprayed two bottles of this all over the bottom of my engine, let it sit as the instructions communicated and rinsed it all off. Worked great at removing the oil.
    NewImprovedRon likes this.
  7. Sep 17, 2021 at 6:48 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Good news is you won’t have rust issues in that area.
    300BLK likes this.
  8. Sep 21, 2021 at 4:28 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Sorry for your troubles, but you likely won't make the same mistake again! :D
  9. Sep 21, 2021 at 5:57 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  10. Sep 21, 2021 at 6:04 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire:angrygirl: clean up time, with gunk!
  11. Sep 21, 2021 at 6:06 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Welcome from the Midwest! I've used engine de greasers like spray 9 to clean engine bays for years, let it sit for a bit then pressure wash but you want to try to stay away from electrical connects an your fuse box/air intake as best you can. A local detail shop should be able to do it for you really quick if you are worried about it.
