Throttle response lost
Discussion in '2nd Gen Tundras (2007-2013)' started by Rxp, Aug 14, 2021.
  1. Aug 14, 2021 at 12:30 PM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    Hello my 5.7 tundy looses throttle for a second then comes back. Seems to me it goes to safe or limp mode for a second and releases. No codes or check engine light. I replaced the brake switch as it is used in the ecu so you can not use throttle and brake at same time. Checked pedal looked clean. Have not taken apart throttle body sensor yet.
    YardBird likes this.
  2. Aug 14, 2021 at 12:35 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Let us know what you find out . . .
  3. Aug 14, 2021 at 12:36 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Clean throttle body with carb cleaner, maf with maf cleaner
    Giskk likes this.
  4. Aug 14, 2021 at 2:08 PM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    Throttle body cleaned with slight scoring on bottom left side, maf sensor cleaned.
  5. Aug 14, 2021 at 2:10 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    it did it after cleaning, or before???
  6. Aug 14, 2021 at 2:13 PM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    Was there prior,
  7. Aug 14, 2021 at 2:14 PM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    Butterfly valve not sticking on it
  8. Aug 15, 2021 at 7:11 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    ...are people removing the MAF from the intake before cleaning? Screws were in there pretty good so I let them be.
    Just curious.
  9. Aug 15, 2021 at 8:06 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You don’t have a pedal commander or the likes do you?
  10. Aug 15, 2021 at 9:10 AM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    All stock, no pedal commander
  11. Aug 15, 2021 at 9:16 AM
    timsp8
    NY
    What year is your truck? Have you checked your vin for any recalls like the fuel pump recall recently?
  12. Aug 15, 2021 at 9:28 AM
    Rxp
    Rxp [OP] New Member
    5.7 tundra
    Tundratoofun, it is active after 40km/hr. No recalls, on my 2008 for fuel pump.
    Tundratoofun likes this.
