Throttle Position Max at 82.4%
Discussion in '2.5 Gen Tundras (2014-2021)' started by lawfarm, Oct 12, 2018.
  1. Oct 12, 2018 at 11:44 AM
    lawfarm
    lawfarm [OP] New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Just installed my new Ultra-Gauge in my 18 Tundra CM with 5.7L v-8.
    At WOT (pedal to the floor), it shows the actual and commanded throttle position maxing out at 82.4%. It feels like WOT, but the throttle position sensor apparently begs to differ. Is there a calibration I need to do (either on truck or UG), is this an error, or am I missing 17.6% of throttle position, and thus not achieving full power? It ramps up to 82.4% and then holds there.
  2. Oct 23, 2018 at 5:55 PM
    lawfarm
    Any thoughts on this?
  3. Oct 23, 2018 at 6:01 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m curious for results. Maybe take the intake tube off and have someone floor it. Or Gopro?
  4. Oct 23, 2018 at 6:03 PM
    LML 3500HD
    Tow haul mode and retest...:thumbsup:
    dandailey, GNTundra and 15whtrd like this.
  5. Oct 24, 2018 at 8:54 AM
    LML 3500HD
    Well?
    15whtrd likes this.
  6. Oct 24, 2018 at 12:30 PM
    Stig
    Stig New Member
    TC applies the brakes. Shouldn't affect throttle.
    GNTundra likes this.
  7. Oct 25, 2018 at 3:34 AM
    Berettafan
    Berettafan New Member
    2017 CM
    Very interested in this. Please check with tow/haul
    RedRegCab likes this.
  8. Oct 28, 2018 at 8:19 PM
    lawfarm
    No change with tow-haul.
    ColoradoTJ likes this.
  9. Oct 28, 2018 at 8:28 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  10. Oct 28, 2018 at 8:41 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I haven’t checked throttle position, but the carpet prevents full travel of the gas pedal. There is a little more travel if modded. I’m not sure that will improve it, and doubt its worth messing with personally.
    Tc reduces engine power also.
  11. Oct 28, 2018 at 9:02 PM
    LML 3500HD
    I guess the timing is changed with tow haul mode to get better engine response than the throttle body opening.
  12. Oct 28, 2018 at 9:18 PM
    Vizsla
    Vizsla ☠️☠️☠️
    No timing changes, just increases throttle response(basically tip in), and different transmission parameters. The last thing you would do when towing or hauling would be increasing timing, and that’s where power gains would be.
    15whtrd and ColoradoTJ[QUOTED] like this.
  13. Oct 28, 2018 at 9:24 PM
    LML 3500HD
    That would make sense so the piston doesn’t magically get destroyed.
  14. Oct 28, 2018 at 9:35 PM
    LML 3500HD
    Maybe 82.4% is the optimum set value....
    Vizsla and GNTundra like this.
  15. Oct 28, 2018 at 9:41 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I think it would go higher with full pedal travel, but doubt it would make even a c hair of a difference. There is almost no scenario that our engines can even use more than 82.4% naturally aspirated, maybe with some forced air. So i agree.:D
  16. Oct 28, 2018 at 9:43 PM
    ZPMAN
    Minnesota
    Take a look at what I came up with, I think with carpet and mats you should get WOT unless you are into shag carpet.
    https://www.tundras.com/threads/urgent-help-with-ecu.33401/#post-837127
    Vizsla likes this.
  17. Oct 28, 2018 at 10:02 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Good info! Keep in mind that electronic gauges are not super accurate, and I think you guys might be looking at different parameters. Yours is throttle blade position, think he is looking at desired/commanded fuel. Been awhile so bit rusty, could be wrong.
