Thread for Documenting Warranty Work?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Aug 9, 2017.
Make a thread specifically for documenting warranty work
  1. Yes
    100.0%
  2. No
    0 vote(s)
    0.0%
  3. Yes, but include all repair work
    0 vote(s)
    0.0%
  1. Aug 9, 2017 at 7:55 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I'm one of those people that is OC and likes a perfect truck. Because of that, I really try to maximize my warranties (bumper-to-bumper and powertrain) even for small stuff. From experience, dealerships can be resistant about warranty work, and I've had to be persistent a few times. Sometimes you even have to open a case with Corporate. However I push harder when I know someone else has had the same issue and was able to get it fixed.
    Do you think it'd helpful if there was a thread specifically for documenting warranty work? The idea would be to make it easier for people to learn about 1) potential issues, no matter how small, their truck could have, and 2) possible solutions from Toyota.
    Posts might look something like this:
    Mileage when repaired
    Problem
    Did Toyota Fix Under Warranty?
    Solution (or reason Toyota would not acknowledge problem/repair)
    Corporate Required?
    TSB#?
    For example, my posts would include:
    26,494
    Minor (no dripping) fluid seeping from rear differential.
    Yes, seal (and fluid) replaced.
    No
    No
    27,022 Entune display bubbly and acting strange (freezing resetting etc).
    Yes, radio headunit replaced with refurbished unit.
    Yes
    No
    What do yal think? Should the scope be limited to warranty work, or should it include all repairs? Is this redundant effort? Would you contribute to it and/or reference it? Or just dumb idea?
    I put a poll up to see if there is interest. Thanks yal
  2. Aug 9, 2017 at 8:13 AM
    gosolo
    Ray
    NW Oregon
    It sounds like a good idea, so I voted yes. But in reality, I don't think it will work. There's not going to be enough participation to keep it active.
    Now, if you were talking Ford, Chevy, or fiat, you'd have so many participating it would require a full time mod just to keep organized!
    T-Rex266 and RussellVaughan[OP] like this.
  3. Aug 9, 2017 at 8:21 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I think it's a great idea on instances where there was dealer push back on not wanting to do the work. If they did it with no questions asked, then no harm, no foul. But if a member had an issue that required management or corporate involvement, then it would be good to see how someone else solved it. Routine stuff probably doesn't need to go on here, just special circumstance repairs IMO. Hope that helps.
    gosolo likes this.
  4. Aug 9, 2017 at 8:33 AM
    I think a TSB thread would be more ideal. Warranty work is going to vary for the most part. (some dealers won't honor it where others would) Extended warranty plans, circumstances, etc. etc.
    gosolo likes this.
  5. Aug 10, 2017 at 8:40 AM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    6112/5100 Go Rhino RB20s
    I recommend a thread sticky for each major TSB.
  6. Aug 10, 2017 at 8:43 AM
    RussellVaughan
    Houston
    Yeah I'm thinking stickies for TSBs and other more common issues is a better idea.
  7. Aug 10, 2017 at 8:49 AM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    I came from Tacoma world and they had it pretty well organized.
