The Legend of PB Blaster - an article
Discussion in '1st Gen Tundras (2000-2006)' started by standard, Jan 15, 2021.
  1. Jan 15, 2021 at 11:05 AM
    standard
    standard [OP] New Member
    Daniel
    2005 Black DC Limited 4WD
    https://jalopnik.com/the-legend-of-pb-blaster-1846039311
    Since this forum seems to really love this stuff, I thought it would be appropriate to post here.
    This is a pretty sweet article giving a brief history of Blaster. Sounds like a solid company run by solid people, giving us even more reason to support them.
  2. Jan 15, 2021 at 11:54 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I like reading Jalopnik, they have good stuff
    standard[OP] and FirstGenVol like this.
  3. Jan 16, 2021 at 7:15 AM
    Professional Hand Model
    Hand Protectors
    Awesome read.
    I was smiling the entire way through. :D
    ‘4-40 A/C’ and ‘The Cologne Smell’ :rofl:
    standard[OP] likes this.
  4. Jan 16, 2021 at 7:38 AM
    standard
    Daniel
    Total dad wisdom.
  5. Jan 16, 2021 at 8:22 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I was introduced to B'laster when I lived in Tampa back in the late 80's. I had a 73 Beetle I was resurrecting and one of the guys I worked with used it and told me to try it out. We didn't have it at Delta (wasn't on the approved chemical list) so I bought a can and have been a fan ever since. I do use Kroil, but I bring out the "Big Gun" when needed.
    Great article
  6. Jan 16, 2021 at 9:28 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Blaster came in 2nd to last on the Project Farm test for penetrants. Who knows how reliable that test is. Kroil came in dead last but I've had good luck with it.
    Either way, great article. I enjoyed reading it. Im glad they haven't sold out.
    https://youtu.be/xUEob2oAKVs
    bmc02 and Darkness like this.
  7. Jan 16, 2021 at 9:39 AM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’m a big fan of Mopar rust penetrant since it comes with a straw in a controlled spray that doesn’t get all over everything else. Liquid wrench is like this but that stuff quickly becomes unusable for some reason after 1/2 can is used.
  8. Jan 16, 2021 at 10:50 AM
    Hand Protectors
    I’ve got an old Liquid Wrench applicator bottle with the pointy tip that I’ve saved and refill with the Blaster. The bottle tip allows for precise drops in those hard to reach spots where you don’t want the over spray going everywhere. You are right in that both seem the same when comparing the two in a smell test.
  9. Jan 16, 2021 at 5:29 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Made me think back to when I first used PB...'86, iirc, doing weekends at brother's garage and the store was out of Liquid Wrench, so I grabbed the PB. Is it wrong to say I like the smell?
  10. Jan 16, 2021 at 5:31 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Testify!
  11. Jan 17, 2021 at 6:53 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Dont know about the PB stuff but I'h been using acetone and ATF fluid.. 1:1 ratio and it works great. Just put in a clear spray bottle and your are set. Just shake the bottle if its kept on the shelf for a while at it tends to separate.
    Mustanley and Lil Steve like this.
  12. Jan 17, 2021 at 7:17 AM
    Toolaholic
    Toolaholic New Member
    David
    2021 black tundra SR5 SX 4x4
    TRD rear sway bar
    I’m a kroil and Gibson guy. But pb blaster does work .
  13. Jan 18, 2021 at 4:41 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Do you mean it loses its propellant, so you have a half-full can that won't spray?
  14. Jan 18, 2021 at 6:39 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    PB for general use, I prefer it to WD. Kroil is a bit harsh, has a strong chemical odor. Don't use it for the same things I use PB for. Only for eating through really established corrosion to break something free, and only if the PB failed. Which is rare.
    Glock 40 likes this.
  15. Jan 18, 2021 at 6:46 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    PB all the way for me, can't say how many times it's saved the day... probably well into the 100s. Sometimes I'll douse fasteners days prior. :thumbsup:
  16. Jan 18, 2021 at 2:53 PM
    Jack McCarthy
    Bill
    North of Boston
    Exactly.
  17. Jan 19, 2021 at 5:03 AM
    tvpierce
    Maine
    I've had the same problem in the past with a few cans of WD-40. I recharge them with my air compressor. Remove the spray head from the can. The rubber tip of my blow gun (the black screw-on tip in the pic) fits the nozzle on the can perfectly. It takes VERY little air to recharge.
  18. Jan 19, 2021 at 3:05 PM
    Hand Protectors
    Your idea here is worth 7 Positive Vibes Credítz for extending the use of a product.
  19. Jan 19, 2021 at 5:35 PM
    tvpierce
    Maine
    I've been saving up my Positive Vibes Credítz. I'm hoping to have enough by next year to redeem them for an all-expenses-paid week at the @Professional Hand Model topical island getaway!
  20. Jan 19, 2021 at 7:25 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Same here. I made up a batch and keep it in pump oiler can with long nozzle. I found references around the net to a study done on penetrating lubricants for machinists workshop magazine back in 2007 or thereabouts.
    https://www.fifthaveinternetgarage.com/tech_tips_penetrating_oil.php
    Lil Steve likes this.
