The Land Yacht - Quicksand TRD Pro Build
Discussion in '3rd Gen Tundras (2014+)' started by the_midwesterner, Sep 7, 2017.
  1. Jan 2, 2019 at 4:28 PM
    #181
    the_midwesterner
    the_midwesterner [OP] New Member
    Luis
    None, yet....
    And.......
    Done.
  2. Jan 2, 2019 at 4:29 PM
    #182
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    Did you cycle the suspension with just the main leaf sitting on the perch or did you compensate for the rest of the pack that is normally under the main leaf with a spacer?
    zcarpenter92, Vizsla and SoCal619 like this.
  3. Jan 2, 2019 at 5:10 PM
    #183
    the_midwesterner
    Luis
    None, yet....
    Kind of did it 2 ways. When I used the main leaf, I put the centering bolts in place to make sure I had the correct placement on the axle. I then used the top of the bolt as a reference to see if it would touch anything on it's way up. It was well clear of the frame under full bump. I did this to find the location of the lower shock brackets at bump and tacked them in. Then I cycled the suspension in place, I used a 2x4s to help locate it a bit more. I did the axle at full bump and then each wheel individually and so far, it looks like I am good. Also fully cycled the leafs, best I could, after putting the truck on the ground and it also looks like I am clear.
    I'd like to think I overdid it on the checking clearances and such, but time will tell. Appreciate the input though!
    Watt maker, SoCal619 and Erichudgins like this.
  4. Jan 2, 2019 at 5:19 PM
    #184
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    looks good brother!
    the_midwesterner [OP] likes this.
  5. Jan 2, 2019 at 5:21 PM
    #185
    Erichudgins
    Eric
    Murfreesboro, TN
    im considering this kit, keep me posted on how its working for you... id like to see it in person
  6. Jan 3, 2019 at 8:34 PM
    #186
    the_midwesterner
    Luis
    None, yet....
    No truck updates since I actually had to work today and it’s dark. Once the brake lines get here from SDHQ, they’re getting replaced and the truck is getting aligned.
    In other news though, bumper and spare wheel showed up. Waiting to find out where the winch is and then getting it installed.
    5B57F3FB-02A9-415B-9328-783E4AA5EC20.jpg 3CDBF83B-14D9-421E-B2A4-D82E6909C05E.jpg
  7. Jan 8, 2019 at 6:21 PM
    #187
    the_midwesterner
    Luis
    None, yet....
    Dropped it off for an alignment today, but while there, they are going to throw on the extended brake lines I picked up from @sdhq_offroad. If my winch ever shows up, I’ll be able to throw that bumper and winch on, then adjust the coilovers to raise the nose up. May need another alignment, but the truck was just barely drivable as it was.
  8. Jan 17, 2019 at 7:34 PM
    #188
    the_midwesterner
    Luis
    None, yet....
    And it’s aligned and driving! Thus far, really digging the ride. We have a trip planned with @blackoutt next weekend to stretch it’s legs, but until then, it’s putting in road miles. Then it’s a quick nut and bolt prior to taking off for the trip.
    Also parked next to a stock quicksand at work today for contrast. Truck is seems huge next to it.
    Darkness, JDL17CM4x4, Sas and 7 others like this.
  9. Jan 18, 2019 at 7:18 AM
    #189
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    NM
    2017 TRD Pro Tundra DC Cement
    1 of 255
    Looks great!
  10. Jan 19, 2019 at 10:54 AM
    #190
    TheBeast The Beach
    need more pictures :):thumbsup::yes:
  11. Jan 27, 2019 at 5:56 PM
    #191
    the_midwesterner
    Luis
    None, yet....
    Not much of an update. Still waiting for parts. Paid a company for a winch 2 mos ago, never got said winch, asked where my winch was, they decided to keep my $1500, so now banks are involved. Yay.....
    Otherwise, been trying to put some road miles on this thing. Everything seems to be “good”. After about 500-700ish miles, I’ll put it back on stands and nut/bolt the whole suspension again to make sure I don’t end up like the Tacoma guy on IG who’s rear end ripped out from underneath it while wheeling. After that, I have to meet up with @blackoutt and it’s time for some wheeling in KY/TN.
    In other news, my buddy who bought my original TRD Pro wheels, also bought my TRD Pro Bilsteins. We had a wrenching session last weekend in 20 degree weather with the door open, to get it all on his truck. He ended up going with the Icon AAL pack, which eliminates most of the leafs minus the main and overload, and a shim each up front. He’s really happy with the ride and how it ended up settling.
    ‘‘Twas a long and cold day, with seized rusty shackles and seized rear shocks stems, but we findished it in a day.
    Darkness, sdde4n, jc153 and 4 others like this.
  12. Jan 27, 2019 at 8:14 PM
    #192
    PATTEN
    PATTEN New Member
    Neil
    Guntown MS
    2018 CM XSP MGM SR5 4X4
    Like night and day, a lil lift does the Tundra good!
  13. Jan 28, 2019 at 5:28 AM
    #193
    blackoutt
    blackoutt YEAH BUDDY!
    Southern IN
    07 Tundra SR5 DCLB 5.7 4x4
    Long truck problems. I ended up taking a cutoff wheel to the rear shock upper stem nuts to get mine off too, not looking forward to the shackle replacement either. So now it's pretty much a TRD pro right?
    Also that 4runner :thumbsup:
  14. Jan 28, 2019 at 9:48 AM
    #194
    the_midwesterner
    Luis
    None, yet....
    Preach!
    I don't know how you got a cut-off up there. I tried, but my grinder was too big. We ended up cutting off the boot and vice gripping the shit out of the upper shaft. Also coated the nut in PB blaster. It did the trick, but it definitely sucked. For the shackles, we couldn't get them out. We tried everything, minus heat. We ended up saying F it, went to my house and grabbed my leaf packs and tore the down to rebuild. Luckily, I did my suspension over winter shutdown. Otherwise, I am not sure what we would have done. We Super Lubed the hell out of those shackle bolts though...
  15. Jan 28, 2019 at 10:14 AM
    #195
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    An air hammer really helps with removing the stock shackles :thumbsup:
  16. Jan 28, 2019 at 12:55 PM
    #196
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Ditto... Put mine in back in June and by October, the paint was totally jacked and showing rust spots. No rain, no river crossings. Just hot-dry SoCal Summer.
    :frusty:
  17. Jan 28, 2019 at 1:29 PM
    #197
    the_midwesterner
    Luis
    None, yet....
    I would of been impressed if you put them in the front.... ;)
  18. Jan 28, 2019 at 3:08 PM
    #198
    DividedSky
    Jeff
    LOL... ok, I'll try again. BACK in June, I put in a set of u748's... By October yada yada yada...
  19. Jan 31, 2019 at 7:31 AM
    #199
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CM TRD-OR (6-seater)
    Leitner Designs ACS
    Haha, I knew what you meant, Jeff.
    Hey, so can anything be done to Deavers to prevent rust, like say painting or otherwise treating them with something before mounting them?
  20. Jan 31, 2019 at 8:05 AM
    #200
    SoCal619
    SoCal619 New Member
    I’ll jump in here since I have had 4 sets of Deavers.
    Deaver only sprays a cursory black coat on the outside and not a good coat. They never do any prep and you will see rust when shipped. Repainting with some good product after some prep would not be hard; just take some time.
  21. Feb 3, 2019 at 7:43 AM
    #201
    the_midwesterner
    Luis
    None, yet....
    Not much to update.
    However, it’s been colder than a gold digger’s heart on account of some polar bears breaking or something along those lines...
    I have been rinsing off the salt off the Kings though, since I don’t want them to rust. Should have splurged on the coated versions, but hindsight is 20/20. I generally don’t drive the truck much, since I have a daily, but I’ve been putting miles on it to make sure everything is gtg.
    Otherwise, all the @Baja Designs lights came. Literally, these dudes are the best to deal with and have top notch stuff. Can not recommend you guys enough.
    It’s supposed to be warm today, so the camburg bumper and warn winch should be going on.
  22. Feb 4, 2019 at 8:36 AM
    #202
    Baja Designs
    Baja Designs ENTER: "BDForums" coupon for your forum discount! Vendor
    San Marcos, CA
    That's a lot of light! :cool:
    Thanks for the support
    Baja Designs
    www.bajadesigns.com
  23. Feb 5, 2019 at 6:16 PM
    #203
    the_midwesterner
    Luis
    None, yet....
    I joined the bandwagon..... smh.
    Doggo reluctantly approves.
  24. Feb 5, 2019 at 7:34 PM
    #204
    SoCal619
    SoCal619 New Member
    Good choice. Did you get the skid plate/mount?
  25. Feb 6, 2019 at 7:25 AM
    #205
    the_midwesterner
    Luis
    None, yet....
    To mount it in my truck? Nah, I have a hi-lift on the Datinfab rack. This is just for shop use and because I was tired of stacking wood blocks to raise my crawler. And now my truck, since it sits much higher after the lift.
    SoCal619 likes this.
  26. Feb 15, 2019 at 11:00 AM
    #206
    kidim
    kidim New Member
    Hey there! I've noticed that your DRL is running both the amber lights and the LED, which looks AMAZING! From what I've read is that you have to give up the Amber lights when upgrading to the new headlights. Is that true? If it is, how did you run both the LED and Amber, is there some hack to the wiring?
    Thanks!
  27. Feb 17, 2019 at 9:12 PM
    #207
    the_midwesterner
    Luis
    None, yet....
    That would not be true. I’m running the conversion harness from @iHacker and there are a couple ways you can run them, which are listed in his thread. Let me see if I can find it and I’ll post it up.
    I chose to do the white and orange DRL because I thought I’d look pretty cool.
  28. Feb 18, 2019 at 8:51 PM
    #208
    the_midwesterner
    Luis
    None, yet....
    This thing has been a giant bitch to put on, but it’s getting there. I consider myself pretty competent, but this thing has just kicked my ass the whole way onto the truck.
    Here’s a pic for a sneak peak before it’s done. Huge shoutout to Joey from @sdhq_offroad for putting up with my dumb comments and my questions. His motivation to get things resolved is just badass! Appreciate the help!
  29. Feb 19, 2019 at 2:42 AM
    #209
    bradleykd
    bradleykd New Member
    Brad
    2016 Limited-BLACK
    I'm excited to see this bumper installed! Definitely my favorite out there.
  30. Mar 1, 2019 at 9:13 AM
    #210
    the_midwesterner
    Luis
    None, yet....
    Did a little wheeling this past weekend. Really glad I ended up getting the bumper and winch setup. It pissed rain for 2 days straight and made the rivers flood and everything else was mud soup. Got bound up and stuck a couple times due to the mud bogs that were river banks and had to give myself a yank or two.
    Couple takeaways from the trip:
    - I need bigger tires . I do have a set of 37s in my garage. Hmmm...........
    - Those tires need to be MTs, so the KO2s will be up for sale.
    DFA3AF00-6717-4186-8A20-0524A246DD94.jpg BEEEC06F-9247-403F-8C1C-E67A1AFE6A16.jpg D26DDC15-0153-4488-9491-942A3BC53DA5.jpg E36BE8F2-6E8D-4FF3-8F38-ADBD659003F0.jpg 3B87331E-B543-46C7-813E-97F4EA45D6CE.jpg 10363D6D-8F84-487E-9844-4F05A5BA9C79.jpg
