The definitive Steering Rack Thread - with solutions - Updated 10/2020 in first post
Discussion in 'General Tundra Discussion' started by papasmurf, Oct 25, 2018.
  1. Jun 21, 2020 at 2:00 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I think mine has failed as well...after 200k I'm not completely shocked, but I did find the front sub-frame stained with fluid on the driver side, doesn't appear to be engine oil, but stained non the less....... This should be way more fun than the starter, lol...
    Mountun Goat likes this.
  2. Jul 9, 2020 at 3:02 PM
    DesertGorilla
    DesertGorilla New Member
    Eric
    Tucson
    12 CM SW 4x 35s
    17" Methods 35x12.5 BFG KO2 - OME 612 Kit Dakar Rears OME Shocks & Shackles. - Nitro 5.29s and Auburn LSD
    135k but recently upgraded to 35s then installed 5.29s and swapped out a readylift leveling kit for OME 614s (612s not 614) and Dakar rear springs...about 2months into the set up so maybe 1500 miles...rack failed...sucks, but this thread will be super helpful, thanks in advance.
    Also found these two videos, not very step by step but helpful none the less.
    https://www.youtube.com/watch?v=xEZFrvaIRw0 and part 2 https://www.youtube.com/watch?v=20DVDWMoMGE
  3. Aug 21, 2020 at 3:05 PM
    meinbomb
    meinbomb New Member
    stephen
    2012 crewmax
    3" ADS w/ resi front and rear, deaver u748 leafs, spc UCAs, coach builder tie rod end, helm joint sway bar link, durobumps, TRD air filter, bullydog tuner, 295/70/17 Duratrack on rock warrior rims when not running lame skinny snow tires on stocks for winter.
    This is a great thread. Just blew out my rack doing a 3 point turn in a driveway, fluid pooled in the inner boot. I'm on vacation near Glacier, MT so can't do it myself. Shop said 20 hrs, WTF. I explained how to do fix it in 5-8 hours and they didn't believe me. After chatting with a dealership, a tech said to look up repair process for 2016+ and has new method that is 5.75hrs according to Toyota. They quotes $870 plus parts and alignment at the dealer. Told the shop to look up repair for 2016+ and all of a sudden the job went from pulling the engine and tranny (20hrs) to 6-8 hours. Thinking of saving the old one to rebuild myself to have a backup, anyone rebuild a rack before? Worth it. This thread and another saved me 12 hours of labor cost. Thanks guys.
  4. Sep 17, 2020 at 12:36 PM
    WaipioTUNDRA
    WaipioTUNDRA New Member
    2016crewmax7"BDS35x12.5
    hey brotha I have to replace steering rack bushings and I have the BDS 7" , DID YOU NEED TO DISASSEMBLE shocks , ball joint, etc to get the diff drop bracket out of the way so you could get to the steering rack bolts ???
  5. Sep 17, 2020 at 12:49 PM
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    No!
  6. Sep 17, 2020 at 3:33 PM
    WaipioTUNDRA
    cool so just unbolt diff mounts ??
    papasmurf[QUOTED][OP] likes this.
  7. Sep 17, 2020 at 4:00 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah the best way to do it now is to pull the front diff. PM me if you need some more info. The way i did it in the original post is the old method, there are ways to screw that up. So shoot me a PM and we can chat
    DesertGorilla and osidepunker like this.
  8. Sep 20, 2020 at 8:26 AM
    Twisted99
    Twisted99 New Member
    2018 Crewmax Platinum 4x4
    None, yet
    Are the OEM racks better than AM?
    I replaced mine 3 months after i bought my 2006 DC in 2017. also, changed the PS pump
    truck had 135k on it, no lift stock size tires. Now 168K same stock tires and the rack is bad.
    Goes from hard to easy to steer after turning.
    Going to replace with the same rack, because it came with lifetime warranty (Advance Auto).
    But 30k miles is BS for a stock truck
  9. Sep 20, 2020 at 8:45 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yes stock are better than reman or aftermarket
    The Patriot 1776 and osidepunker like this.
  10. Oct 5, 2020 at 7:54 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Have y'all tried doing it w/out dropping the front diff but removing the inner tie-rods? I read somewhere of guys doing it that way & it seemed the easiest/fastest. Mine shit the bed yesterday & waiting on a new OEM unit to arrive so I'll be doing this this week/weekend. I'd really prefer not to drop the diff.
    Also, if you remove the gear box from the rack, what precautions need to be taken to make sure it goes back on in the correct orientation?
    I don't know if it matters but I have 2016 w/ a ~3" OME lift.
    Thanks.
    Geo4x4 and Mountun Goat like this.
  11. Oct 5, 2020 at 8:09 PM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Yes, I've done it. It sucks. Drop the diff
    You don't need to pull the inner tie rods. Pull the input shaft and remove all the hydraulic connections from the rack and you can maneuver it out the passenger side. But that method takes twice as long as dropping the diff.
  12. Oct 6, 2020 at 1:12 AM
    WaipioTUNDRA
    I have 7" bds so I had to drop the diff .. its more time consuming than anything... match marks , fasten the steering wheel via seat belt method .... have fun
  13. Oct 6, 2020 at 7:49 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I used to advise that way, however you have to separate the steering gearbox from the rack and there is huge risk to damaging it while putting it in, just pull the diff and slam it in, way easier and faster trust me I've done 10 of these. diff drop is fastest and easiest. See original post its been updated.
  14. Oct 6, 2020 at 11:15 AM
    The Patriot 1776
    '16 TSS CM 4x4
    I’ll be doing this myself on my shop floor. Can the diff be dropped with only one person? I’m mostly worried about boogering up the drive axle diff seals sliding them back into the diff.
    Thanks.
  15. Oct 6, 2020 at 11:29 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yes it can, do you have a trans jack? you can do it with a regular jack and use a strap to hold it in place, just support the passenger side axle tube. you wont screw up the seals. its all super straightforward.
  16. Oct 6, 2020 at 12:53 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I don’t have a tranny jack but I have straps. Do I have to pull the hubs and everything at the wheels to pop the axles out of the diff?
    Also, about how low does the diff need to drop, I’m assuming about 6”?
    Thanks for all the input!
  17. Oct 6, 2020 at 12:58 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Just drop it to the floor, its 5 bolts( the diff mounts), one electrical connector and two breather hoses, you probably won't lose more than 1/4 cup of fluid if you keep it flat... i drop it down and slide it to the rear of the truck out of my way so i have plenty of room to work. and no you just disconnect the upper control arm uniballs. then bring the knuckles away from the truck, that's enough room to pull the inner cv stub out of the diff to clear.
  18. Oct 7, 2020 at 10:47 AM
    The Patriot 1776
    '16 TSS CM 4x4
    Trying to do this now. This is as far as I can get the axle out of the diff. What am I doing wrong?07D702EA-02C4-47B5-AF72-B03F8FB6EA1C.jpg
    Geo4x4 likes this.
  19. Oct 7, 2020 at 10:51 AM
    #49
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Did you disconnect the upper control arm from the spindle?
    papasmurf[OP] likes this.
  20. Oct 7, 2020 at 10:53 AM
    #50
    The Patriot 1776
    '16 TSS CM 4x4
    Yes.
  21. Oct 7, 2020 at 10:55 AM
    #51
    osidepunker
    Alex
    2013 Tundra DC 4x4
    well, if thats not enough try disconnecting the spindle from the lower control arm; two bolts. Thats how I normally do it. when you reassemble, those bolts need to be torqued to 225 ft/lbs and use red loctite
  22. Oct 7, 2020 at 10:58 AM
    #52
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    there is a lot of play with them, they should angle enough to pull completely out. worst case just drop the diff and the inner cv's will angle down and clear it. But they absolutely should pull out , are the tie rods disconnected from the knuckles?
  23. Oct 7, 2020 at 10:59 AM
    #53
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @The Patriot 1776
    id put the upper control arm back on loosely just to hold it up
    Geo4x4 and osidepunker[QUOTED] like this.
  24. Oct 7, 2020 at 11:22 AM
    #54
    The Patriot 1776
    '16 TSS CM 4x4
    I got them by removing the tie rods from the knuckles. Destroyed both diff seals in the process.
    Geo4x4 likes this.
  25. Oct 7, 2020 at 11:23 AM
    #55
    osidepunker
    Alex
    2013 Tundra DC 4x4
    how are they destroyed??
  26. Oct 7, 2020 at 11:25 AM
    #56
    The Patriot 1776
    '16 TSS CM 4x4
    Ate up from the splines binding on them and one side shit the seal spring.
  27. Oct 7, 2020 at 11:27 AM
    #57
    osidepunker
    Alex
    2013 Tundra DC 4x4
    sry man that sucks
  28. Oct 7, 2020 at 11:36 AM
    #58
    The Patriot 1776
    '16 TSS CM 4x4
    Do I have to remove the front driveshaft from the diff as well? It appears so.
  29. Oct 7, 2020 at 11:37 AM
    #59
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yes, 4 bolts
  30. Oct 7, 2020 at 11:38 AM
    #60
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    oh yeah shit.... forgot about that part... ill adjust the directions, sorry about the seals, i would have assumed the tierods were off the knuckles... that's the key piece.
