Tell me why this doesn't work?
Discussion in 'Lighting' started by NWHmoob, Nov 14, 2018.
  1. Nov 14, 2018 at 7:40 PM
    NWHmoob
    NWHmoob [OP] New Member
    2014 Tundra SR5 DC TRD Offroad
    So I have 2 led pods hook up as additional reverse lights. They work as intended but when I try to add in a switch from the cabin it doesn't. All of the power to the switch in the cabin is powered by the switch next to it. Essentially, all I need to do is trigger the relay and that in turn will switch the power to the leds, so current draw shouldn't be an issue? This has me scratching my head. See the diagram below. What am I doing wrong here?
  2. Nov 14, 2018 at 8:22 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Are you diodes facing the right direction??
  3. Nov 14, 2018 at 8:46 PM
    NWHmoob
    It should be. I solder both diodes at the same time. They are side-by-side under the relay. Plus, with a dmm read out it's .4vdc. If the leads are reverse it's "OL". So the diode orientation is correct.
  4. Nov 14, 2018 at 8:57 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Do the lights come on with the reverse lights and the switch just doesn't work?? Or do they not come on at all?
  5. Nov 14, 2018 at 9:28 PM
    NWHmoob
    Yes, when put into reverse it works. It's just when using the switch. FYI, the switch works just fine.
  6. Nov 14, 2018 at 9:42 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Your going to have to try bypassing the switch and then bypassing the diode in the load side of the switch.
    landphil likes this.
  7. Nov 14, 2018 at 10:18 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    ^^^ my brain cell hurts!!!! short bus crash test dummy and glass licker.. it almost sounded like i was reading in english..
    TXRailRoadBandit73 likes this.
