Tap into reverse circuit?
Discussion in 'Lighting' started by smslavin, Dec 8, 2019.
  1. Dec 8, 2019 at 2:35 PM
    smslavin
    smslavin [OP] Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    hey smart people. who knows where i can find the reverse circuit to tap into? i'd like to use the external trigger function on the switch pros 9100 to switch on my rear squadrons when i shift into reverse.
  2. Dec 8, 2019 at 3:54 PM
    smslavin
    Hudson Valley
    Some stuff
  3. Dec 8, 2019 at 5:00 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I just tapped in at the tailight
  4. Dec 8, 2019 at 5:15 PM
    smslavin
    Hudson Valley
    Some stuff
    was looking for something in the engine bay. not wanting run a wire all the back from the switch pros.
  5. Dec 8, 2019 at 9:16 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So did it work out? I’ll eventually want to do this also.
    smslavin[OP] likes this.
  6. Dec 9, 2019 at 6:25 AM
    smslavin
    Hudson Valley
    Some stuff
    didn't get to it yesterday. maybe this afternoon. will keep you posted.
  7. Dec 9, 2019 at 1:13 PM
    smslavin
    Hudson Valley
    Some stuff
    works perfectly. details here.
  8. Dec 9, 2019 at 1:45 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Thank you sir
  9. Dec 9, 2019 at 1:47 PM
    smslavin
    Hudson Valley
    Some stuff
    :cheers:
  10. Jan 5, 2020 at 10:54 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Alright Mr smarty pants I have a couple questions for you. So I see you got the reverse connected to your switch pros but why did You go with pink wire(external trigger) and not any other switch of the 1-8. Also I want to do something similar with my fogs. I want to be able to control them with my stalk and then be able to run them anytime with my switch pros any tips?
  11. Jan 6, 2020 at 6:25 AM
    smslavin
    Hudson Valley
    Some stuff
    the lights are connected to a switch so i can turn them on manually. the pink wire just picks up the signal for the trigger. the app associates the signal with a switch. you can trigger up to 4 switches from the pink wire.
    to use a second trigger, you would use the white wire then turn it on in the app.
    so, in your case. pink wire would tap into reverse circuit. in the app, associate trigger #1 with the switch for the reverse lights. the white wire would then tap into whatever circuit turns on the fogs at the stalk. in the app, turn on trigger #2, then associate the switch for your fog lights.
    does that make sense? it's also in the manual on page 8, item 9, 'External Trigger'.
