Tall/high truck bed
Discussion in 'General Tundra Discussion' started by dling, Jan 9, 2026.
  1. Jan 9, 2026 at 2:44 PM
    dling
    dling [OP] New Member
    What can I add to my 2026 tundra to help me get into the truck bed. Im short and getting into the bed is a pain. Im 69 yrs old.
    Corndog123 likes this.
  2. Jan 9, 2026 at 4:09 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    A bumper step? One that lowers when you use it and you push it back up when your done.
  3. Jan 9, 2026 at 4:12 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
  4. Jan 9, 2026 at 4:13 PM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
  5. Jan 9, 2026 at 4:14 PM
    Adamace1
    Adamace1 New Member
    None....
  6. Jan 9, 2026 at 4:14 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
  7. Jan 9, 2026 at 4:17 PM
    1lowlife
    DADA
    I used to grab the tailgate cable or the bedside on my lifted 2014.
    Sometimes my swingcase.
    The 2026 is stock level and easier to climb up on.
    A grab handle would certainly be a great idea.:thumbsup:
    joseph_womack[QUOTED] likes this.
  8. Jan 10, 2026 at 7:00 AM
    Adamace1
    Adamace1 New Member
    None....
    1lowlife likes this.
  9. Jan 10, 2026 at 7:18 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
    Do you currently have oversized tires or a lift installed?
    One of my friends bought a brand new truck about 4 years ago. One of the first things he did was lower it 2". I questioned his decision at first, but it make it awesome for easily loading up dirt bikes in the bed.
    joseph_womack likes this.
  10. Jan 10, 2026 at 8:13 AM
    dling
    The truck is stock with 18'' wheels
  11. Jan 10, 2026 at 8:17 AM
    dling
  12. Jan 10, 2026 at 8:19 AM
    dling
    I want to be clear. The problem is when the tailgate is in the down position that I have problems getting in.
  13. Jan 10, 2026 at 8:26 AM
    dling
    1lowlife[QUOTED] likes this.
  14. Jan 10, 2026 at 8:42 AM
    dling
    I plan on getting the bed step. Thanks.
  15. Jan 10, 2026 at 8:51 AM
    dling
  16. Jan 10, 2026 at 8:53 AM
    Adamace1
    Adamace1 New Member
    None....
    Right this plus the step the other guy posted. Both together makes it safer. The step alone is tricky with out a handle. I would think you either remove a cover or cut a hole to mount the handle.
  17. Jan 10, 2026 at 9:00 AM
    dling
    I did order the step. I would like the handle as well but dont want to cut any holes in a new truck bed cover.
  18. Jan 10, 2026 at 9:10 AM
    Adamace1
    Adamace1 New Member
    None....
    I looked around it seems the new Tundras don't have steak pockets built into the bed sides. So yeah you would have to alter the plastics to attach a handle. The step will make things easier so you should be goid. I love mine.
  19. Jan 10, 2026 at 9:11 AM
    whodatschrome
    I’m not trying to be a smart aleck, but are you at some point planning on getting younger, more limber, and stronger? If not, you only have so many options on ingress and egress of a pickup bed.
    A mild lowering kit would significantly make it easier to get into the bed. Then add in an Amp step. Both of those mods together might just get you another 7 years of comfortable and safe bed mobility.
    I have a lot of friends at the gym who i go to who are much older than me. They don’t complain about it, but they do talk to me about their trials of aches, pains, and limitations that automatically come with getting older.
    https://sosperformance.com/collecti...kit-2022-2025-tundra-2-front-drop-3-rear-drop
  20. Jan 10, 2026 at 9:32 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    If you can reach the rear end of the bed track you might be able to use the cleat to grab on to or even tie a loop of line to it. I DIY light duty loops for my use. Pics of those to illustrate what I'm talking about.
    joseph_womack and 1lowlife like this.
  21. Jan 12, 2026 at 11:04 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I installed the tailgate ladder. Works great but 200 lbs is it's real world limit.
