Tailgate assist soft open bushing breaks again and again
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockwell, Jan 9, 2026.
  1. Jan 9, 2026 at 11:58 AM
    Rockwell
    Rockwell [OP] New Member
    New Jersey
    2021 Tundra Crew Max SR5
    Hoping to find a solution to this repetitive problem on my 2021. The bushing on lower left tailgate hinge keeps cracking resulting in the tailgate just crashing down when opened.
    Dealer replaces hinge/bushing under warranty and all is great. About 50 openings, and BAM, bushing cracks again. Truck is going in tomorrow for its 3rd replacement. What is causing this repeated failure?
    Truck is in great shape, no twisted frame or body panels, and only has 70K miles on the clock. I do not subject the tailgate to overly heavy loads. Heaviest thing loaded is a quad from time to time. Failure happens without warning and without any pre-existing conditions.
    I had mentioned to dealer that maybe they should replace the strut as well, but they say no, its fine and there's no need. The hinge on right side is just a "dummy" hinge, but it appears to be fine and smooth.
    I will say the dealership has been great about it, even sending the hinge to a body shop for color match painting before installation.
    Why the repeat fails? One of my friends has a 2018 with 200K mile, he uses the truck hard, and its still on its original hinge, working just fine.
  2. Jan 9, 2026 at 3:40 PM
    sm_tundra
    sm_tundra New Member
    2018 Tundra Limited
  3. Jan 9, 2026 at 4:32 PM
    Rockwell
    New Jersey
  4. Jan 9, 2026 at 4:56 PM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
    If I still had my 2014, I would buy that and install it even if I didn't need it.:eek2::cool:
  5. Jan 9, 2026 at 5:22 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    panicman and Rockwell[OP] like this.
  6. Jan 9, 2026 at 6:04 PM
    Rockwell
    New Jersey
    Since absolutely nothing in this post contributes anything whatsoever , at least you raised your posted messages count by 1. Great Job! Thanks for your insightful response.
  7. Jan 9, 2026 at 6:16 PM
    Snert
    Snert New Member
    2021 SR5
    Lol what’s with the hostility? This is a forum, not every post in every thread is going to be a direct contribution. @blackdemon_tt was just joining in and saying thanks to @SM Tundra for the reminder about this part.
  8. Jan 9, 2026 at 6:26 PM
    Rockwell
    New Jersey
    Zero hostility. And after RE-Reading things, completely my BAD. I read it as if blackdemon_tt was asking me where I`ve been for the past 10 years. As if I've been under a rock and should have known about this part for the past 10 years.
    Looking again, I CLEARLY see my error. Its been a long day. My sincere apologies to you blackdemon_tt.
    Read it wrong, took it wrong, responded wrong.
    IM WRONG! 100% :(
  9. Jan 9, 2026 at 6:39 PM
    Snert
    Snert New Member
    2021 SR5
    Ahhh gotcha that totally makes sense, I could have easily read it like that as well. No harm no foul, cheers to the weekend!
  10. Jan 9, 2026 at 6:52 PM
    blackdemon_tt
    No offense taken. If it came out wrong my bad, but I've thought about something like this for a long time and never found it until now,
    I'm honestly tired of cooking my fingers everytime I knock the tailgate out of the hinges, especially when it's 1000 degrees out here in the summer. Already purchased it this bad boy.
  11. Jan 9, 2026 at 7:01 PM
    Snert
    Snert New Member
    2021 SR5
    +1 to the just ordered one. My tailgates fine for now but whenever I see threads like this with cheap little upgrade/replacement parts I try and order em before I forget and toss em in my stash of truck parts to eventually install.
  12. Jan 10, 2026 at 11:49 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Glad I saw this post- ordered this along with a new dampener, since my tailgate has been a slammer for about 5 years now!
    Rockwell[OP] and 1lowlife like this.
  13. Jan 11, 2026 at 9:30 AM
    blackdemon_tt
    Welp, got it and installed it... not sure if its my situation specifically, or you'll all need additional tools.
    Mallet, maybe some lubricant.
    Mine wouldn't go in, so I had to massage it in. You may need to remove the hitch, I kept tripping over itand the tailgate would slip out. I needed the mallet once more to get it all the way in. I got soft open back, but I have to oull the bumper cover out or it will knock the tailgate out, but that's a different problem.
    I'll add pics later if anyone wants them.
    HulkSmurf14 and Rockwell[OP] like this.
  14. Jan 11, 2026 at 10:02 AM
    Rockwell
    New Jersey
    Wow, how did you get yours so fast? Mine is set for delivery tomorrow. Glad to hear it worked and you got soft open back. :thumbsup:
    As a side, its best to remove your hitch when not in use, If you get hit from behind, the hitch can provide enough leverage to bend your frame where it otherwise would not have bent. That results in your truck being totaled by insurance company. This actually happened to a member on the forum, if you search long enough you'll find the thread on it.
  15. Jan 11, 2026 at 2:34 PM
    blackdemon_tt
    Here you guys go. Not sure if the female side was damaged, but it wouldn't slide in. So, I had to beat it. Ordered mine Friday got it late last night. Once I got the tip in, I had to tap the tailgate from the passrger side along with a forceful push before it slid all the way in.
    Screenshot_20260111_135220_Gallery.jpg Screenshot_20260111_135238_Gallery.jpg Screenshot_20260111_135327_Gallery.jpg Screenshot_20260111_135159_Gallery.jpg
  16. Jan 11, 2026 at 2:54 PM
    Rockwell
    New Jersey
    Great pictures, Thank you for taking the time to post. I've read where many others have had to use lube and rubber mallet to help with fitment.
    So I understand, Did you install the new aluminum bushing onto the truck side first, and then install tailgate onto new bushing? or did you put new bushing into the tailgate first and then slide entire tailgate onto truck?
  17. Jan 11, 2026 at 3:08 PM
    blackdemon_tt
    I used a mallet as well, no lube.
    I test fitted on the truck side and it cleared fine, but no luck on the tailgate side.
    I forced it on the tailgate side first then struggle slid it on the truck side. You will need the mallet to force it on to the truck side. Then either push it or hit it a couple more times on the passenger side of the tailgate to mount it on. I hit it at the bottom area just above the C fitting.
    Rockwell[OP] and HulkSmurf14 like this.
  18. Jan 12, 2026 at 11:52 AM
    Rockwell
    New Jersey
    Installed today, went super easy for me. I did use a rubber mallet to gently tap bushing into tailgate, the gate then slid on the truck with no effort at all. I applied Fluid Film to all surfaces. Tailgate works butter smooth like new.
    It amazing to think the money my dealership spends to replace this under warranty. New hinges left and right, sent out to a body shop to color match, new strut. All they had to do was this. At least now I get to go pick up all those parts for future use if ever needed. Doubt I`ll ever have the need though.
    Thank you again sm_tundra as well as everyone else.
    sm_tundra and 1lowlife like this.
  19. Jan 12, 2026 at 1:33 PM
    Tundra Rod
    Tundra Rod New Member
    Wow!
    I just logged on to find out why my tailgate still drops after a new damper!
    Thanks!
  20. Jan 13, 2026 at 4:20 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Looks like Amazon has a couple of these for sale. Not sure if one fits better than the other.
    Maybe post a link to the one you bought with how it fit so everyone can compare.
  21. Jan 13, 2026 at 6:08 AM
    Rockwell
    New Jersey
    I bought the Casrram. Worked great for me. Slight tap to get it into the tailgate, but thats a good thing, you don't want to lose it if you take the tailgate off. Slipped onto the truck with the greatest of ease.
    Look at above posts and you will find a link to the Casrram.
    Bergy24[QUOTED] likes this.
  22. Jan 14, 2026 at 7:54 AM
    panicman
    Eric
    IMG_1459.jpg Received the bushing and new dampener yesterday. I replaced the dampener first, since it's kind of the lower hanging fruit. That solved the issue for me. When I started pulling the tailgate off, I could visualize the factory bushing, and it was fine, still unbroken and intact.
    Given that the tailgate is working smoothly, it was getting late, and it was getting damn chilly, I just opted to remount the tailgate, and I'll worry about replacing the bushing later. I used the extra time to give the truck a quick wash in the garage since it was really filthy.
    Rockwell[OP] likes this.
  23. Jan 14, 2026 at 7:58 AM
    Rockwell
    New Jersey
    Great to hear its working smoothly again, no need to replace the bushing yet. Hang onto it, chances are you`ll need it in the future. At least now, you have it.
  24. Jan 14, 2026 at 8:13 AM
    Tundra Rod
    How hard is it to pull the tailgate off by yourself without scratching it?
  25. Jan 14, 2026 at 8:23 AM
    Rockwell
    New Jersey
    I didn't find it very difficult at all. Tailgate is not that heavy. I wore a pair of thick winter gloves so it was a soft grab on the tailgate. Open tailgate about 1/4 the way and pull, concentrate on pulling the passenger side off the hinge first. Once you are free from that hinge, gently move the whole gate to the right to free the other side. At this point you can set the tailgate down gently on its bottom edge right onto the bumper plastics without fear of scratching it. I then put the whole tailgate into my bed, paint side up, with lower left facing out.
    Be deliberate in your moves, go slow, and you`ll be fine.
    One word of caution, try to avoid using the tailgate handle as a holding point. Its ok to use to free one side from hinge, but don't use it to hold the entire weight of tailgate.
    And don't forget to disconnect your camera and tailgate lock harnesses before removing.
  26. Jan 14, 2026 at 8:31 AM
    blackdemon_tt
    I used the posted link quoted above.
