Tail light bulb replacement
Discussion in 'Lighting' started by Pudge, Jun 16, 2019.
  1. Jun 16, 2019 at 11:14 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I just ordered some amber 7444 front turn signal bulbs for my 2018 headlights. Also got resistors.
    I would like to do the tail lights too. I already have led reverse lights. What other bulbs do I need. In rear I need 3157, 3157k, and 921. all red I assume. Is there really that many bulbs back there?
  2. Jun 17, 2019 at 4:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Assume you're talking about converting to LEDs. You won't need resistors for in-kind bulb replacement. The headlight housings should have come with 7444NAK bulbs.
    The brake light, tail light, and rear side marker are all combined in one bulb...3157.
    The rear signal light is a single second bulb...921.
    When replacing incandescent bulbs with LEDs, the suffix letters are not relevant to LEDs. Only the numerical digits are important. Most LEDs can be used for several different bulbs. For example an LED indicated as a replacement for both 3156 (single element) and 3157 (dual element) will replace both bulbs, but be only half as bright for the single element application; e.g. tail light only without the signal.
    Review the ohms for the resistors you bought. Typically, 6 ohm resistors are needed if you only have LED signals for the fronts. If you install LEDs at all four corners, then you can use only a single 3 ohm resistor installed behind the rear light housing. Get the LEDs and try before you consider resistor changes; you may get by without hyperflash.
    Pudge[OP] likes this.
  3. Jun 17, 2019 at 4:58 AM
    War Machine
    War Machine SSEM # 5 3MW
    You have puddle lights in your mirrors, right? (Assuming all Platinums have them.) I just got some cheap LED replacements from Amazon for my wife’s Sequoia. May switch to Vleds later, but it made a huge difference. (I only did one so far. Wanted a comparison shot before doing the other.
    MOFORKIT LED Side Mirror Puddle Light Lamp Assembly Compatible with 2007-2019 Toyota Tundra Sequoia White https://www.amazon.com/dp/B07L5GF1RL/ref=cm_sw_r_cp_tai_3a4bDbETPDH2T
    2DE32CB5-FAD1-4128-9E08-008A7356408F.jpg E9A32239-26A8-49F0-A706-CE32F212EFF7.jpg
    Pudge[OP] and NewImprovedRon like this.
  4. Nov 24, 2019 at 6:46 AM
    Topherwv
    Topherwv New Member
    Taillights won't for tight now.. anyone else have issues getting your lights off and back on?
  5. Nov 24, 2019 at 7:49 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Can you try your question again.
  6. Nov 24, 2019 at 8:13 AM
    Topherwv
    Topherwv New Member
    My bad, won't *fit tight. There a gap
  7. Nov 24, 2019 at 10:54 AM
    JohnLakeman
    There are plastic grommet(s) that snap into the tail light fender opening into which a "pin" on the tail light housing SNAPS. It's difficult to remove that tail light housing because that grommet holds that pin extremely tightly. If you remove the housing for inspection, I expect you will find that plastic grommet broken from your removal, and is no longer capable of doing the great job it did before.
  8. Nov 24, 2019 at 11:00 AM
    Topherwv
    Topherwv New Member
    Right, the grommets are still there but don't feel as secure as original. One of them had the shoulder break but still allows it to snap into place. Both lights just don't feel as tight when snapped into place like it did originally and I swear there is a larger gap now but I could just be crazy. I'm due for a10k service soon, I was just going to ask them to take a look whole it was in but I know how that tends to go
  9. Nov 24, 2019 at 11:24 AM
    JohnLakeman
    Snap one out and examine it close...it'll be bunged. Replace the grommets used for the snap pins, and the tail light housings will fit like new. They're about $1.50 each.
