Tail gate latch handle
Discussion in '1st Gen Tundras (2000-2006)' started by Dsoshea1, Aug 21, 2021.
  1. Aug 21, 2021 at 6:25 PM
    Dsoshea1
    Dsoshea1 [OP] New Member
    Dustin
    Blue 2005 Tundra SR5 crew cab
    Has anyone replaced there tailgate latch handle before, and where can I find one?
  2. Aug 21, 2021 at 7:42 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Buy the oem one from a dealer, it’s like $100. Trust me. I bought the stupid $27 dorman one. Thing opens on the third Pull
    Sampson likes this.
  3. Aug 21, 2021 at 7:43 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine came from Amazon but was included when I bought my truck from the PO. Just remove all torx screws around the inside cover for the tailgate then unhook the cables going to each latch, remove the two bolts that hold in the handle, and swap out the lock cylinders then do the opposite to install. Good time to lubricate anything that moves in there too.
    hammeron likes this.
  4. Aug 21, 2021 at 7:45 PM
    NickB_01TRD
    Nick
    KY
    You jumped ahead of me while I was typing lol. I used the cheap one. Think it was like $25 on Amazon when I looked it up. It came with the truck from PO. So far it's worked perfect for me everytime and it looks and feels like OEM just isn't busted up like my old one. Can't argue that OEM is probably better though.
  5. Aug 21, 2021 at 7:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got an Amazon cheapo going 2 years strong.
    Anything dorman is trash. Even if it costs more that some other beand
    SouthPaw likes this.
  6. Aug 21, 2021 at 8:34 PM
    Teutonics
    Teutonics New Member
    2005 DC SR5 4WD
    Coincidentally, I just did mine today. Easy job as described by NickB. I also used the cheap Amazon handle. While I had it apart I took out both side latches and replaced one that was damaged and the other was bent out of alignment (so I bent it back), and cleaned and lubricated both with DuPont dry film lubricant (this stuff is the bomb... I use it on everything: https://www.amazon.com/DuPont-D00110101-11OZ-Dupont-Lubricant/dp/B002HYXAOA). Now the tailgate takes almost no effort to open, and I have zero concern with breaking the cheap handle since it requires very little effort to open now.
  7. Aug 21, 2021 at 8:53 PM
    shifty` One great big festering neon distraction
    Best thing you can do is replace the plastic connectors first, unless the handle broke off. The plastic snaps on the connector rods often fail. I'll post a thread on replacing those soon. Unless the handle broke off, I don't see a reason to replace.
    Siebler and empty_lord like this.
  8. Aug 21, 2021 at 9:26 PM
    NickB_01TRD
    Nick
    KY
    On mine the handle was busted up and in two pieces so I couldn't open the gate without wedging a screw driver in there. It most likely broke due to lack of lubrication as it was really hard to open. When replacing the handle I just lubed up everything.
  9. Aug 22, 2021 at 4:50 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I went OEM as the Limited are color keyed to the truck (all after market I saw were black). Then I stuck a camera in it -
    shifty` and NewImprovedRon like this.
  10. Aug 22, 2021 at 5:34 PM
    Yup. I don't think many people treat lube in the tailgate as maintenance, but I've been screaming the same at folks. Good example here: https://www.tundras.com/threads/help-please.72456/#post-2158881
    That exact reply and the one following has some info. I need to get off my ass and do this writeup for tailgate connector replacements but overdid it after surgery last Tuesday and I'm regretting it today. Should've stayed on my ass.
