taco tunes amp install help
Discussion in 'Audio & Video' started by Mad Max, Jan 2, 2021.
  1. Jan 2, 2021 at 12:39 PM
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    I was about to install my amp. looking taco tunes videos. does plug and play provide the power source or do you have to run your own power source to amp? Thanks taco tunes not responding to questions unless you wait 24 hours.
  2. Jan 2, 2021 at 1:02 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    If I remember right you have to run a battery cable, to power the amp, everything else is plug and play.
  3. Jan 2, 2021 at 1:02 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Gotta run your own
  4. Jan 2, 2021 at 1:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Installation Steps:
    1. Run power wire from battery to new amp location. (see video)
    2. Assemble the fuse block and complete under hood details. (Do not connect to battery)
    3. Run subwoofer wire to rear of vehicle per the installation video.
    4. Install amps / amp rack per video. (do not connect speaker output connections)
    5. Connect input side of amp first. (Blue molex plugs from direct connect harness)
    6. Connect battery
    7. Tune amplifiers per tuning video(s).
    8. Install front / rear speakers.
    9. Install subwoofer.
    10. Test system – ensure playing correctly.
    11. disconnect battery.
    12. Install center console.
    13. Install seats BEFORE installing door panels and door sills. (battery should be unplugged)
    14. Install door sills.
    15. Install door panels.
    16. Connect battery.
    17. Test the sound and ensure all playing properly.
    18. Open a single beverage, beat your chest and listen to your tunes for about 10 minutes.
    19. Finish cleaning up odds and ends.
    20. Be sure to save ALL stock parts.
    https://youtu.be/4IPB-SsbEsE
  5. Jan 2, 2021 at 1:10 PM
    Mad Max
    Max
    2021 Tundra Limited
    Thanks guys. I not doing that there will be a brand new txd8005 and PLUG and Play wire harness (roflmfao)in classifieds soon. I got the plug and play because i didn't want to run wires. false advertising at its best. running a power cable through firewall is not plug in play in my book. Holy hell i spent an hour trying to figure out test tunes. fk it.
    again thank for the quick responses!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    BlueRibbon4x4 and War_Wagon312 like this.
  6. Jan 2, 2021 at 4:55 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    I just ordered a taco tunes add an amp plug and play kit. I hope it is plug and play and I didn’t get button hooked hahah.
  7. Jan 2, 2021 at 5:12 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Running a 4ga wire from the battery to under that passenger seat isn't that hard.
    Run it thru the firewall grommet in front of the drivers seat.
    Down the kickplate, under the driver's seat, under the console, and there you are..
    If you went thru the trouble of ordering TTs upgrade, you're never going to get the results you want without running a line replacing the stock amp (and maybe HU).
    Anything plug and play is not going to provide enough power.
    Hell, I ran 0Gga...:thumbsup:
    0e33q5g2_zpssm0sqsag_813d798ec184e0790e7f6a565431d9931eaa976f.jpg o0tt5klg_7c3a503bb2fe582082d582eb48d67d597806cb0d.jpg gvap7jp5_zps2iu2ff0k_dbf216b8dd86d54836468820fe4aabe9cccddc0c.jpg
    AZBoatHauler likes this.
  8. Jan 2, 2021 at 5:12 PM
    JR2382
    JR2382 New Member
    Victoria, TX
    2021 tundra SR Double Cab
    Any time you are adding an actual amp you are going to be running a power wire from battery to the amp (not a hard job). The plug and play comes in when hooking up your speakers to the amps. If you were to just buy any amp to power your speakers you would have a lot of splicing to do.
    1lowlife likes this.
  9. Jan 2, 2021 at 6:04 PM
    Mad Max
    Max
    2021 Tundra Limited
    Thanks again. I agree with everyone, but truth be told i could have easily spliced the speaker wires with any amp and didn't need the "plug and play" pkg, as it doesn't save much. It was my fault looking for an easy out to install a "plug and play". I even have 4 gauge wire and fuse I removed from my boat where previous owner had amp that would work as power supply wire. 1lowlife posted pic of power supply video. i have spent no less than 3 hours on ********* website with how to set voltage etc. I never saw that video on running power supply that 1lowlife posted. I guess Apple products have made things easy.
    I agree that running the power supply isn't a big deal, I misunderstood plug and play and hoped to knock it out in under an hour thinking if a subwoofer was not used stock power supply wiring would be enough. Truth be told if I would have taken the time i spent throwing a temper tamper I could have had power supply installed with conduit. On flip side I could have used any amp, what's special about taco tunes amps. I definelty understand the benefits of amps.
    Thanks and if I want it installed I can easily do it if I want to lol...
    1lowlife and JR2382 like this.
  10. Jan 2, 2021 at 8:06 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Looking for a plug and play amp? This won’t power a sub, but will boost the power to your doors. A pretty nice upgrade actually. You’ll just need to source the harness from Amazon. It’s what I have in my truck. I didn’t have to run any wires with this amp. You do have to wire the harness to the amp harness. So not 100% plug and play, but no running wires, and no cutting truck wires.
    2010-2019 Toyota Tundra (w/o JBL Audio) AutoHarnessHouse.com Factory Amp Upgrade Harness AHH-4438 https://www.amazon.com/dp/B01BSEGCQW/ref=cm_sw_r_cp_api_glc_fabc_-lu8FbF034A7H?_encoding=UTF8&psc=1
    1lowlife and War_Wagon312 like this.
  11. Jan 2, 2021 at 11:26 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Certainly better than nothing.
    Especially if one has no intention of a installing sub...:thumbsup:
    BlueRibbon4x4[QUOTED] likes this.
  12. Jan 3, 2021 at 10:31 AM
    Mad Max
    Max
    2021 Tundra Limited
    OUTSTANDING!!!!!!!!!!!!!!!!!!!!!!! EXACTLY WHAT I WAS LOOKING FOR. Why isn't that offered as an option with the taco tunes?????? I am not installing a sub just a little more than stock amp. Thank you!!!!!!!!!!!!!!!!!!!!
    BlueRibbon4x4 likes this.
  13. Jan 3, 2021 at 10:34 AM
    Mad Max
    Max
    2021 Tundra Limited
    So in the end I will use one of the Taco tunes plug and play connectors and use the Amazon harness on the other connector for power and ground? I guess I can run my own ground wire.
    On a side note when trying to figure out if the amp was getting power just from the TT plug and play I turned on the radio. Amp wasn't getting any power, on flip side I heard some speakers up front that are not driven by the amp. TT indicates running the test tunes through speakers can damage them, guess I will have to disconnect them prior to tuning the amp. Why does TT require tuning the amps when other amps do not?
  14. Jan 3, 2021 at 10:39 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Is your system JBL or non-JBL?
    The AutoHarnessHouse.com harness is for non-JBL.
    @james@tech12volts makes an adapter for JBL systems.
    2014 to 2017 TOYOTA TUNDRA JBL WIRING HARNESS (tech12volts.com)
  15. Jan 3, 2021 at 10:41 AM
    BlueRibbon4x4
    Geno
    I’m unsure how the ********* harness works, but the harness I shared works great. Follow the instructions carefully included with the amp. I also had to look up the harness wiring diagram so everything got connected properly. When I first installed it, I reused the old amp bracket from under the seat, so everything stays in place. I didn’t need to take out the seat.
  16. Jan 3, 2021 at 10:48 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I wouldn't even use the TT harness if your going to install the amp @BlueRibbon4x4 suggested.
    I'd use the harness he suggested.
    That is kinda what I used for my 2014 non-JBL.
    But that was back when we had to make our own harnesses..:eek2:
    87348790-B238-44AC-A061-CA3892995C7C_zps_d6b265370c2fc3286b8a0a2be6768b372a15f3a3.jpg CD992687-9495-41B9-9F34-EC2B4AE0F7BD_zps_dd4e46dbbe7369823c9a84c5178c6124f519124a.jpg 5DEB1FDB-0568-4359-8931-792EB31B19DD_zps_f2e8d3fd29dad7f17280cac535b772c28f948510.jpg
    @Mad Max I'd just box that TT stuff up and try to return it or resell it..
  17. Jan 3, 2021 at 10:52 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    With a non-JBL the dash speakers run straight off the HU, the doors run off the underseat amp.
    Also the non-JBL HU sends only a mid and low signal to the front doors and uses the dash speakers as tweeters.
    All amps need to be tuned after installation.
    Gains need to be properly set..
    if gains are too high, speakers can be damaged..
    Have you replaced any speakers yet?
    Or what exactly have you already done?
  18. Jan 3, 2021 at 11:05 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I have it. It worked great.
  19. Jan 3, 2021 at 11:14 AM
    War_Wagon312
    Rich
    Stock horse
    Perfect I am pumped to hear that haha. Did you order this one by chance? Did you run your own power? I absolutely suck when it comes to wiring and how it works. Much respect to the people who understand the in’s and out’s. Exactly why I need this forum! :rofl:
    p.s
    beautiful MGM
  20. Jan 3, 2021 at 11:19 AM
    timdske
    Fort Worth Texas.
    Yes, that's the one. I ran the wires to the JL Audio converter for more power to your amp.
  21. Jan 3, 2021 at 11:22 AM
    War_Wagon312
    Rich
    Stock horse
    Gotcha. I have a Polk audio pa 660 amp, a 10 inch woofer and this kit coming. Would I need anything else to make it work? Lol. Please forgive my ignorance. Again I am trash at the audio aspect.
  22. Jan 3, 2021 at 11:24 AM
    Mad Max
    Max
    2021 Tundra Limited
    Ok. I plan on using stock speaker and stock non JBL head unit. I noticed there is a blue and yellow wire coming off the TT plug and play. Since I will not ever install a sub, can I just use the yellow or blue wire coming off the TT harness for power? TT has it capped. I verified they both have 12 volts from toyota connector. On toyota connector one is a very small gauge wire the other looks like 16 or 18 gauge. Does anyone know what color on the stock amplifier is power to the amplifier? I would guess red but TT harness doesn't have pin in that location, shoot maybe I can switch pin locations.
    If there is any risk of me overloading the stock wiring with the amp I can run the power. I already have the 4 gauge.
    What are the odds of me damaging the speakers with the test tones that are driven straight off the head unit? I have zero desire to unhook the dash and theater speakers. Oh i have to use blue tooth for the test tones since 2021 don't have CD's.
    Thanks again!!
  23. Jan 3, 2021 at 11:28 AM
    Mad Max
    Max
    2021 Tundra Limited
    Kinda surprised the amp bracket with taxes and shipping are $100. About $1 in material. I don't want to invest any more until i see what kind of improvement I can get with amp.
    BLONGTX likes this.
  24. Jan 3, 2021 at 11:28 AM
    timdske
    Fort Worth Texas.
    As long as you can hook the wires directly to your amp you should be fine. The converter adds a little more power going into the amp. Stock head units tend to be weak. This is what I installed.
    War_Wagon312[QUOTED] likes this.
  25. Jan 3, 2021 at 11:33 AM
    War_Wagon312
    Rich
    Stock horse
    I’m running a kenwood 1057xr head unit. these are my amp connections. With what I have I won’t need to run anymore wires or splice anything?
  26. Jan 3, 2021 at 11:38 AM
    timdske
    Fort Worth Texas.
    When you get the wiring kit you'll need to hook the purple, purple/black, green, green/black wires to the amp for the speaker inputs unless you already have low level inputs from your head unit.
  27. Jan 3, 2021 at 11:48 AM
    Mad Max
    Max
    2021 Tundra Limited
    anybody have wiring diagram for stock non jbl Toyota amp connections.
  28. Jan 3, 2021 at 11:48 AM
    War_Wagon312
    Rich
    Stock horse
    Roger that. I’m running the maestro rr with the unit. That I do not know. I’ll try hooking it up without those wires first and see how it sounds maybe? The maestro was the p&p kit. Everything got louder when I changed the head unit for sure.when hooking the radio harness to the maestro harness several of the wires that I soldered were for the speakers.
    timdske[QUOTED] likes this.
  29. Jan 3, 2021 at 11:52 AM
    War_Wagon312
    Rich
    Stock horse
    This?
    BlueRibbon4x4 and 1lowlife like this.
  30. Jan 3, 2021 at 12:01 PM
    Mad Max
    Max
    2021 Tundra Limited
    i got it on the run. thank you so much again!!! i removed my yellow pin from the TT harness. I will now reinstall to marry with pin 4 on stock connector. I will take loose end and hook to amp power. Then i will ground amp to frame. If I overload power it should be protected by fuse. thank you so much for diagram.
    yellow wire on TT terminal is 12 volt power. so i just need to reinstall and use it to power amp. In other words I think before I removed the yellow connected with pin 4 on toyota harness
    timdske and War_Wagon312 like this.
