Switch to 17” Rims? Need advice please...
Discussion in 'Wheels & Tires' started by Silv333, Oct 26, 2018.
  1. Oct 28, 2018 at 5:00 AM
    #61
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    No shit? That sucks.
  2. Oct 28, 2018 at 12:41 PM
    #62
    Edstundra
    Edstundra New Member
    Any help tryed make ing a post sorry if it not where it goes
    OK I bought these wheels from bbwheelsonline.com I called before placing the order to verify they would fit the guy said he would call the manufacturer to make sure and call me back but she did and they said they would fit . Do you do a dry fit before put the tires on I did this on the drivers front and it fits fine. so I ordered them . Then I ordered cooper discovery Sst 315 x70 R 17‘s .... all have plenty of Clarence other than the passenger side tie rod and rubs on the rim .. I thought it may be a defective rim so this morning after talking to bbwheels they Suggested I swap one rim and see if is the wheels ... first what I did was took the passengers rear wheel off and put on the front passenger side at touched in one spot but still not enough Clarence to be comfortable with .... then I thought well the drivers side front had plenty of clearance at the tie rod and so I tried the driver side on the passenger side and it would not even fit and allow it to turn so this is puzzling to me ...I will try and post the pictures below it seems to only let me upload one and the rims are listed below any help would be greatly appreciated
    #69 #70#71 pics goes with this post couldn’t get pics to post here sorry
    And has 6” lift tires don’t rub ..it’s the the tie rod end rub on rim just on right side ?
    Method Race Wheels Double Standard Wheel Machined Clear Coat 17x8.5 5x150 0mm
  3. Oct 28, 2018 at 12:45 PM
    #63
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Rubbing at that size is pretty common. How much lift are you on?
  4. Oct 28, 2018 at 12:53 PM
    #64
    Edstundra
    I did call and it is just the tie rod end on right side
    This is the driver side with clearance
  5. Oct 28, 2018 at 1:02 PM
    #65
    Edstundra
  6. Oct 28, 2018 at 1:05 PM
    #66
    Edstundra
    equin and Rica25 like this.
  7. Oct 28, 2018 at 10:04 PM
    #67
    Silv333
    NJ-NC-MD-NC
    That is some big ass print.
    zcarpenter92 and SoCal619 like this.
  8. Oct 28, 2018 at 10:24 PM
    #68
    Vizsla
    Vizsla ☠️☠️☠️
    You have a 6” lift that replaces the spindles, and flips the tie rods from bottom to top, your wheels won’t work. Your lift kit more than likely came with wheel specs, check it out.
  9. Oct 29, 2018 at 6:42 AM
    #69
    Edstundra
    Lol not yelling when I copied what the wheels was it changed the size and mad it bold
  10. Oct 29, 2018 at 6:44 AM
    #70
    Edstundra
    Not yelling lol thought yelling was all caps
    SoCal619 likes this.
  11. Oct 29, 2018 at 8:02 AM
    #71
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    Most 6" lifts require a minimum of a 18" wheel. I have not come across a 6" lift that will actually accommodate a 17" wheel.
    equin and SoCal619 like this.
  12. Oct 30, 2018 at 1:35 PM
    #72
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    285/75/17. Basically a 34 11.5
    equin and Watt maker like this.
  13. Oct 30, 2018 at 1:38 PM
    #73
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Or pick a different wheel and keep 18s so you can run 35×11.5 285/75/18....
    Watt maker likes this.
  14. Oct 30, 2018 at 1:56 PM
    #74
    Silv333
    NJ-NC-MD-NC
    I want to try to be as least invasive as possible on the truck. I don’t want to replace the upper control arms, or do the cab mount chop. I love the look of the SCS rims, but I hate the silver bead lock shit. SCS will not do anything with it and they told me to take the bolts out myself and have them powder coated. I feel like if I am spending almost $1200 on rims they should come the way I want them. Icon will replace the bolts with color match to the rim, and Icon rims are pretty much made for Tundra’s, like SCS. Icons are easier on the purse strings, and since I like more rubbber and less rim, it just works.
    equin likes this.
  15. Oct 30, 2018 at 1:56 PM
    #75
    Silv333
    NJ-NC-MD-NC
    I would love to see pictures of the set up if anybody has any!
  16. Oct 30, 2018 at 2:01 PM
    #76
    Casper421
    In the woods
    06 DC
    Op, go with 285/75/17’s. Basically a pizza cutter 315.
  17. Oct 30, 2018 at 3:30 PM
    #77
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Have you looked at method?
  18. Nov 3, 2018 at 8:42 PM
    #78
    Silv333
    NJ-NC-MD-NC
    I haven't, they have a +25 wheel?
  19. Nov 3, 2018 at 8:47 PM
    #79
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I believe a lot of their 20inch wheels are +25
  20. Nov 3, 2018 at 8:48 PM
    #80
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I have the method NV in +25
    Silv333[OP] likes this.
  21. Nov 3, 2018 at 8:49 PM
    #81
    Silv333
    NJ-NC-MD-NC
    Oh snap, I'll go check me out, thanks for the info.
    vq35721 likes this.
  22. Nov 3, 2018 at 9:12 PM
    #82
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Yep my old NV are +25
    Rica25 likes this.
  23. Nov 3, 2018 at 9:17 PM
    #83
    Silv333
    NJ-NC-MD-NC
    Yeah I don't want 20's, I like more rubber than rim. Going to stay in the 17-18 range.
  24. Nov 3, 2018 at 9:23 PM
    #84
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Same reason I got rid of those lol
    Silv333[QUOTED][OP] likes this.
  25. Nov 3, 2018 at 9:34 PM
    #85
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I can try and take a pic tommorow I’m running method NVs 18 inch with 295/70/18s and my neighbor has a Silverado with method NVs on 17 inch rims with 35s. There def more sidewall with the 17 but 18s still look good in my opinion.
  26. Nov 3, 2018 at 9:35 PM
    #86
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Here’s a pic of my 18s.
