Switch to 17” Rims? Need advice please...
Discussion in 'Wheels & Tires' started by Silv333, Oct 26, 2018.
  1. Oct 26, 2018 at 3:05 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Ok folks, since SCS won’t budge on the bright silver bead lock bolt heads on a black rim, I contacted Icon alloys. They will switch the bolt heads to match the rim.
    Now here is my original set-up forecast; I was going to do 18” rims with 295/70/18 tires, using a Bilstein 6112 in front at 2.5” and 5160’s in the read.
    If I put 17” rims from Icon on, does anyone know how that changes my tire size? I want minimal trimming with the same “fill the wheel well” look the 295s would have given me. I am still doing the Bilstein set-up.
    Thanks for your advice, and please post pics of your 17” rim setup!
  2. Oct 26, 2018 at 3:24 PM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    If you're asking the equivalent height to a 295/70/18, the closest will probably be 315/70/17. Might rub slightly more because the tire will be 20mm wider and will stick out 10mm more than the 295's.
  3. Oct 26, 2018 at 3:27 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    295/70/18 is gunna need some trimming to the front fender liner. I fully removed mine and it’s still a tight fit in there. And I’m on a 3 inch lift in the front.
  4. Oct 26, 2018 at 3:27 PM
    Silv333
    NJ-NC-MD-NC
    Ok. So maybe 305/70/17??? Yes, that is exactly what i am trying to figure out.
    Pretty much “back to the drawing board”.
  5. Oct 26, 2018 at 3:30 PM
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    Is there a difference in the rim width? That may play a part on rubbing issues. But google tire size calculator. The height of the 295 on an 18 and the 315 on a 17 are almost identical in height however just like @joonbug said. There will be a difference in the width and that is where you may have rub issues.
    joonbug likes this.
  6. Oct 26, 2018 at 3:39 PM
    joonbug
    Joon
    NorCal - Dublin
    If you're worried about rubbing and don't want to get a CMC, the 305/70/17 is probably the way to go. It's only half an inch smaller than the 295/70/18 and will only stick out 5mm more. Might still rub the front liner a bit but shouldn't be too bad.
    dcsleeper408 likes this.
  7. Oct 26, 2018 at 3:53 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    And let's not forget offset. All icons are 25mm offset. That's pretty sweet spot. I actually drove for a month with a 305/70 18 without a cab mount chop with front liners massaged a little bit with no rubbing... Granted that's a RARE occasion. Just didnt want to leave that part out
    TheBeast likes this.
  8. Oct 26, 2018 at 4:29 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Yeah I agree but I’m running 25mm offset and you definetly need to massage it I agree.
    Erichudgins likes this.
  9. Oct 26, 2018 at 4:29 PM
    TheBeast The Beach
    35"s..enough said ;)
    SoCal8654, 831Tun and Erichudgins like this.
  10. Oct 26, 2018 at 4:30 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    You know he has a point....if your gunna trim no matter what why not :bananadance:
    Erichudgins and TheBeast like this.
  11. Oct 26, 2018 at 4:31 PM
    TheBeast The Beach
  12. Oct 26, 2018 at 4:36 PM
    Silv333
    NJ-NC-MD-NC
    Hahaha...MINIMAL trimming! 35’s -?-17???
  13. Oct 26, 2018 at 4:50 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    if it makes you fell better..we finna try 37s:) aftermarket bumper and cmc of course lol
    BestGen and Grey Wolf like this.
  14. Oct 26, 2018 at 4:51 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    These are 295/70 R17, no trimming, push front liner forward a bit, little heat gun to the mudflaps and no rub. I wanted to keep the mudflaps. Any bigger and I will be trimming stuff.
  15. Oct 26, 2018 at 4:58 PM
    fatalkhaos
    Could always try to shim the bumper. Give you .5inch
  16. Oct 26, 2018 at 5:08 PM
    Silv333
    NJ-NC-MD-NC
    Hahahaha you fuckers are killin’ me. @Erichudgins 37’s!!??
    I have entered into a whole different depth of tundras.com...,
    SoCal8654 likes this.
  17. Oct 26, 2018 at 5:15 PM
    TheBeast The Beach
    you know you will want 35"s eventually on those 17's..just get it done now :)
  18. Oct 26, 2018 at 5:16 PM
    joonbug
    Joon
    NorCal - Dublin
    Yup. Or just go straight to 37’s now.
  19. Oct 26, 2018 at 5:36 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    Bro I will make you a killer deal on my 35's even have a full size spare. Hell wheels and all. Less than 10k miles on them
  20. Oct 26, 2018 at 5:38 PM
    vq35721
    vq35721 New Member
    Don’t make the same mistake I made. Go with 37’s :(4E513331-DFE6-4AE4-B1E5-4381B5719305.jpg
    BestGen, TRD15559, joonbug and 4 others like this.
  21. Oct 26, 2018 at 6:03 PM
    TheBeast The Beach
    haha..give me your setup. exactly what I'm looking for :)
  22. Oct 26, 2018 at 6:11 PM
    vq35721
    vq35721 New Member
    You need new tires? ;)
  23. Oct 26, 2018 at 6:33 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Damn so your telling me even if I go 35s in the future I’m still gunna always want 37s....it’s a never ending cycle....:bananadead:
    zcarpenter92 likes this.
  24. Oct 26, 2018 at 6:39 PM
    vq35721
    vq35721 New Member
    That’s exactly how I feel :( Worst part about it, I had a chance to get the 37s lol. I had a couple of weeks and failed to make the right call :mad:
  25. Oct 26, 2018 at 9:56 PM
    Silv333
    NJ-NC-MD-NC
    PM me the deets!
  26. Oct 26, 2018 at 9:57 PM
    Silv333
    NJ-NC-MD-NC
    Can you post some pics of both setups? I’d love to see the stance.
  27. Oct 26, 2018 at 10:16 PM
    Silv333
    NJ-NC-MD-NC
    Those with 17” rims, post a few pics of your trucks please, not just the tire. Thanks!
  28. Oct 26, 2018 at 11:02 PM
    Hunterd_22
    Hunterd_22 New Member
    Hunter
    2010 Black Tundra Rock Warrior
    Man I wish you were on 17” rims. I’ve been looking trough so many tires wanting to upgrade but I’m kind of leaning towards the BFG KM3 at this point. They’re just quite a bit heavier than the Coopers
  29. Oct 26, 2018 at 11:15 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    I’m just gonna leave this here......
  30. Oct 26, 2018 at 11:23 PM
    SoCal8654
    SoCal8654 New Member
    I put 315s on my truck a few weeks ago. I get home and my girl says,,,,. You should went 37s... Im not even shitting you.....
