Switch pro mount.
Discussion in 'Lighting' started by fisherman951, May 5, 2021.
  1. May 5, 2021 at 5:00 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    For all the switch pro users/new buyers Powertrays has come out with a universal mount that should be able to mount to our fuse box lid with four screws. Will make things a lot cleaner and also mounts the switchpro the correct way so it won’t void your warranty. Just passing along some info. Also it’s only 85 bucks.
  2. May 18, 2021 at 3:29 PM
    heckler66
    heckler66 New Member
    2012 Tundra CM 4x4
    Icon Billet Upper CA King 2.5 Fr / Rr Deaver U748 Victory 4x4 bumper RCI Skid plates Baja Designs lights
    Cool, I had made one similar for my Gen 2 recently. Rubber mounted it on top of the fuse box too. Had to make something to hold to actual switch to my dash.
  3. May 18, 2021 at 4:24 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    What do you mean rubber mounted it?
  4. May 18, 2021 at 4:27 PM
    heckler66
    2012 Tundra CM 4x4
    I used rubber grommets underneath the plate about 5mm thick and and bolted it together. Nothing fancy but didn’t want it to sit directly on top
  5. May 18, 2021 at 5:56 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Got it. Thank you for clarifying that.
  6. May 28, 2021 at 11:13 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    where did you mount the switch panel inside the cab?
  7. May 28, 2021 at 12:20 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    :popcorn:
  8. May 30, 2021 at 1:45 AM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    love the Fabricated aluminum plate for the switch Pro, much better looking than the Aftermarket Power Trays one. Would you consider making another for my 2018 Tundra? I'm certain the Fuse box is the same for the 3rd gen Tundra. Let me know. Maybe you should have a bunch made and start selling them, just advertise it here in the forum, most would buy it. I will be using the coin holder location beneath the shifter with the SDHQ billet Aluminum recessed mount for the actual panel in the vehicle.
  9. May 30, 2021 at 3:00 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Just bought my switch pro and bought the tray. Should hopefully be in next week and might pick it up on memorial day. Will post pics for references
  10. May 30, 2021 at 3:04 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Not mine but this is how it's set up using Blue Sea Systems Bus Bars, Fuse Box, Negative Terminals and power trays negative AWG wiringIMG_20210530_040110_230.jpg IMG_20210530_040104_073.jpg IMG_20210530_040101_232.jpg IMG_20210530_040101_232.jpg
    TampaRD Pro and 619Iron like this.
  11. Jun 25, 2021 at 10:04 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Dude, I'd buy that plate if it were available. Hint Hint...
