Sway Bars
Discussion in '2.5 Gen Tundras (2014-2021)' started by DiegoC, Nov 6, 2018.
  1. Nov 6, 2018 at 8:56 AM
    DiegoC
    DiegoC [OP] New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    Sorry guys I’m very new to the truck scene.
    Can I get some pros and cons to sway bars?
    Also if I were to get sway bars do I go front ones first, rear ones first, or just get both done at once?
    Thanks,
    Diego
    CaptSpaulding likes this.
  2. Nov 6, 2018 at 9:02 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    If your strictly driving on the street and no off-reading, a rear sway bar helps a lot with body roll and gives a more planted feeling when driving. You can get the TRD rear sway bar or I think Hellewig make one as well.
    Rex Kramer likes this.
  3. Nov 6, 2018 at 9:02 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    TRD rear ones help with body roll especially on turns.
    There’s already a front one, the TRD one is heavier (and it’s red lol) so you do notice a bit of a difference.
    Hellwig has an option for a rear sway bar, one that accommodates a high lift.
    Guys who rock crawl take them all off for more articulation.
    If anything for street, get rear ones, definite noticeable improvement.
    Stormtrooper81, leesrig and NjPro like this.
  4. Nov 6, 2018 at 9:48 AM
    DiegoC
    Diego
    Awesome. Thanks for the feed back guys! I appreciate it.
    -Diego
  5. Nov 6, 2018 at 9:49 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I have the TRD rear bar that really helps in the turns, no bar upfront. There's better articulation without the sway bars but I off road with the rear attached and it doesn't interfere with what I'm doing. I'm not talking about gravel roads either.
    leesrig likes this.
  6. Nov 6, 2018 at 11:03 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    For those that installed the TRD rear bar did the ride quality suffer at all?
  7. Nov 6, 2018 at 11:12 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Nope, without a doubt, unless you like rocking left to right like a pirate ship.
  8. Nov 6, 2018 at 11:17 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Is the rear TRD (or other) sway bar available with some sort of easy/quick release or disconnect?
    I ask because around town and for towing the travel trailer it would be nice to have. But for the weekends out on the trails I don’t want to lose articulation.
  9. Nov 6, 2018 at 11:57 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    It’s pretty easy to remove the links and zip tie them out of the way. Two nuts and bolts to undo. You can just leave the sway bar in place. Bolt em back on when you are back on the road. Pretty quick
  10. Nov 6, 2018 at 3:29 PM
    blackz151
    blackz151 New Member
    nick
    I have the front and rear sways. No difference in ride and it feels like it has tightened the truck up on corners and such
    Inquiringone and AKJ78 like this.
  11. Nov 6, 2018 at 3:49 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I had the TRD one put on my Pro and makes a big diff IMO.
    Rica25 and Inquiringone like this.
  12. Nov 7, 2018 at 10:34 AM
    ELO’s Platinum
    ELO’s Platinum New Member
    Black 2015 Tundra Platinum
    Trd pro Grill, spyder taillights, 2018 Tundra Led headlights
    Can put the trd sway on a lifted tundra-bilstein 6100 2” lift?
    Inquiringone and mountainpete like this.
  13. Nov 8, 2018 at 7:17 PM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Will the rear sway bar prevent my parent in laws from getting dizzy and puking on road trips?
  14. Nov 8, 2018 at 7:58 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra TRD Sport
    Will my front and rear sway bars prevent my dog from puking in the back seat?
  15. Nov 8, 2018 at 8:41 PM
    GlockTeam123
    GlockTeam123 New Member
    Johnson
    New Orleans
    Installed the rear TRD sway bar and it make the truck sway less on turns. Makes the whole vehicle feel planted on the ground.
    Rica25, Pigglet222 and Inquiringone like this.
  16. Nov 8, 2018 at 10:24 PM
    Zoren Tundra
    Zoren Tundra New Member
    Eric
    2012 TRD off road 4x4
    I used Hellwig sway bars on the rear at stiffest setting, truck drives well in corners and turns no sway side to side on the flip side As everyone has mentioned it will suffer suspension articulation a little.
    But with the stiffest setting it eliminates the rear bed bounce which is good. Truck feels more planted.
    For on road pavement driving and some wash board sand drives no sensation of your like in a boat, I guess that would answer the question of in laws and dogs having puking issues. :cheers:
    Rica25, leesrig, Inquiringone and 2 others like this.
  17. Nov 9, 2018 at 4:19 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    Just installed the TRD rear sway bar. Why didn't I do this two years ago when I bought this beast?
    IMO Sway bar should be the first purchase for the 90% of us road warriors. Simple to install.
  18. Nov 9, 2018 at 4:32 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Front and rear TRD bars... Awesome.
    95% on road driving.
    Sways and off road do not go together.
    I have +3" front and +3 CB shackles out back (~1.7" lift) and it is within range. The front TRD bar is 20% stiffer over stock. ...and you do notice the improvement. Do them at the same time, and you'll be blown away.
    Krewcial and Inquiringone like this.
  19. Nov 9, 2018 at 4:39 PM
    doggiecareman
    Eric
    North Central CT
    I got the rear TRD on my Pro and really like it. Noticed a huge difference right off the bat. I won't be doing the type of off-roading that would interfere with it. Mud, gravel and creek beds. Large rocks and stumps I will be staying away from. It's easy enough to detach them, as was posted in a recent thread as well, and leave them suspended in place if necessary. Gives you the best of both worlds.
    Zoren Tundra and Inquiringone like this.
  20. Nov 9, 2018 at 4:46 PM
    Like others have said once I did it wonder why I waited so long.
    Inquiringone likes this.
  21. Nov 9, 2018 at 5:02 PM
    Professional Hand Model
    Hand Protectors
    Just reattached my OEM front TRD sway a few months back with new beefier links as the original thin links had rusted off. Makes a huge positive difference. I ordered a Hellwig 7700 for the rear and its on backorder. Looking forward to install and feedback. The reviews all seem very encouraging.
    Zoren Tundra likes this.
  22. Nov 9, 2018 at 5:17 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Yes you can
    Have 3/1 lift no issues
    Rica25 likes this.
  23. Nov 9, 2018 at 5:20 PM
    justfortun
    James
    Boston
    2016 SR5
    I watched a YouTube video of how to put it on, the guy recommend smearing Loctitie Anti-Seize all over the bolts. I did. Hopefully this will make them last a bit longer.
    JeremyGSU, Degausser and Inquiringone like this.
  24. Nov 9, 2018 at 5:39 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2017 Limited MGM CrewMax 4x4
    See sig for mods
    Haha just got done watching the same video as I plan on installing this in the near future. Seemed like a pretty simple process.
    justfortun[QUOTED] likes this.
  25. Nov 9, 2018 at 6:38 PM
    justfortun
    James
    Boston
    2016 SR5
    Haha ya, YouTube is amazing. Very simple. 19mm wrench, 19mm and a 22mm ratchet. One video says the bolts won’t fit and you have to go buy some with the proper threatening. They do fit. My Amazon order said the sway bar wasn’t a match for my 2016. It was.
    My only 2cents for the install : The two U bolts should be positioned and the sway bar should come and be bolted at the same time. I did the driver-side first, and then went to the passenger side and realized I had to get crosspiece clamp thingie between the axle and the sway bar. It works both ways but I think it would be easier if you can get them bolted up together. Either way works, but might be easier with a second set of hands.
  26. Nov 12, 2018 at 4:38 AM
    jagged155
    jagged155 New Member
    2018 Platinum Pro
    I have the TRD front and rear with Icon shocks. You will think your truck can handle better than it actually can. Def helps with abrupt turns at all speeds
    justfortun likes this.
  27. Nov 12, 2018 at 5:01 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Front bars are standard, and I always add one to the rear of my trucks.
  28. Nov 12, 2018 at 5:37 AM
    Zoren Tundra
    Eric
    I believe the OEM front sway are good enough no need to change save you money. That is just me.
    Invest on the rear sway bars is a better option.
    Stormtrooper81 and Rex Kramer like this.
  29. Nov 12, 2018 at 5:50 AM
    tundras00
    tundras00 New Member
    Yeah, if you are doing normal driving you might just feel very little difference compared to the rear sway bar. I say save your money also, as I did it.
    Maybe it's just me, but the steering also feels a tad heavier now with the front TRD. Not a problem, and just an observation. Feels like a tank now, or maybe that's how it was and don't remember as I don't drive mine enough.
  30. Nov 12, 2018 at 5:57 AM
    justfortun
    James
    Boston
    2016 SR5
    While we are talking about ride improvement, and I know this isn’t about sway bars, but how much of a ride improvement on the road would I see with the bilstien 6112’s and 5160’s. The front set on the 1.3”. I like the rake of my truck, and maybe just a tad bit of height but I don’t want to change the geometry too much.
    Aesthetics be damned, just talking ride improvement. Opinions? Save my money? o_O Thanks
