Suspension question
Discussion in 'Suspension' started by eagleguy, Jul 24, 2022.
  1. Jul 24, 2022 at 3:31 PM
    eagleguy
    eagleguy [OP] New Member
  2. Jul 24, 2022 at 4:22 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Anytime you replace suspension components on the front an alignment is needed.
  3. Jul 24, 2022 at 4:24 PM
    omer318
    omer318 New Member
    Monroe, LA
    2021 Tundra Crewmax 4WD
    trd front sway bar - trd rear sway bar - trd dual exhaust - trd smoked led headlights - amp research steps - jl stealthbox (two 10" subs) - 17” icon rebounds - 35" nitto rg’s
    Second that, you would definitely need one.
    Tripleconpanna likes this.
  4. Jul 24, 2022 at 4:29 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Yes, most definitely!
  5. Jul 24, 2022 at 5:22 PM
    eagleguy
    Still on the fence as to spacers up front or adjustable shocks.
  6. Jul 24, 2022 at 5:25 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes!
  7. Jul 24, 2022 at 5:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Adjustable always.
    bflooks and Tripleconpanna like this.
  8. Jul 24, 2022 at 6:02 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Do the alignment yourself... it's easier than installing the shocks, that's for sure!
    Are you raising the front for looks only? What shocks do you currently have and how many miles?
  9. Dec 14, 2022 at 1:59 PM
    eagleguy
    I have the SR5 factory shocks and think the ride is fine. As I was only looking to raise the front to level I was considering the pucks/spacers. Question is if there would be any issues such as ride getting stiff or things like that.
  10. Dec 14, 2022 at 3:05 PM
    rruff
    rruff New Member
    How old are your shocks? The installation and alignment are enough work/expense that you want to make sure the components you use are good.
    If you want a spacer lift... get 1" thick spacers (good for a little under 2") and install new bumpstops and you should be ok. If you don't get new bumpstops you'll bottom out your shocks instead, which might kill them... and ride like crap. I bought these, only $26/pair and you'll need 10x1.25x30mm bolts too.
    https://www.autozone.com/suspension...pension-leaf-spring-bumper-9-9135g/356511_0_0
