SUPERBUMPs
Discussion in 'Wheeler's Off-Road' started by YotaDan, Jul 21, 2016.
  1. Jul 21, 2016 at 11:20 AM
    YotaDan
    YotaDan [OP] New Member
    Grants Pass, Oregon
    For those of you that haven't seen or heard of them.
    SUPERBUMPs are a replacement Poly-Foam Front Bumpstop. They are a taller than stock bumpstop with a progressive rate to help absorb the impact from hard hits while off-roading. Feed back from customers running them has been nothing but praise. They really do a great job providing some addtional dampening in the last 1-2" of up-travel.
    Check them out: https://wheelersoffroad.com/product...-24936/wheelers-front-superbump-bumpstop-set/
    ColoradoTJ, Ancient1 and matluth like this.
  2. Jul 21, 2016 at 12:43 PM
    matluth
    matluth I love RADIATION!!!
    Aurora CO
    2007 Slate Metallic 5.7L Tundra DC SR5 4X4
    18"X9" FN BFD's rims, 295/70R/18E Cooper Discoverer STT Pro's, and S/T Maxx's, upgraded to Old Man EMU coil-overs/shocks. Toytec shackles. Custom dual true dual exhaust. Next...new UCA's.
    Could have used a new pair of these last weekend. Time to replace my 9 year old OEM bump stops.
    YotaDan [OP] likes this.
  3. Jul 21, 2016 at 12:55 PM
    csuviper
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    I have them on my tundra and do recommend.
    matluth and YotaDan [OP] like this.
  4. Jul 21, 2016 at 1:53 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2017 CrewMax ProKiller
    Follow my life on IG: PLC721
    On the Tundras, do you just replace the rear bumps or the forward bumps, having dual bumps on the LCA
  5. Jul 21, 2016 at 2:19 PM
    YotaDan
    Grants Pass, Oregon
    We usually do the rear, but either works.
    Flyinryank likes this.
  6. Jul 21, 2016 at 3:09 PM
    csuviper
    Broomfield, CO
    I just did the rear bumps on the front UCAs
    Flyinryank, 415hhh and YotaDan [OP] like this.
  7. Jul 21, 2016 at 4:21 PM
    matluth
    Aurora CO
    Going to order a set tomorrow. Well worth it. Not a lot of sratch.
  8. Jul 21, 2016 at 6:49 PM
    matluth
    Aurora CO
    Rear bumps should be sufficient.
  9. Jul 21, 2016 at 7:15 PM
    csuviper
    Broomfield, CO
    Rears are good with shackles. They are taller.
    YotaDan [OP] and matluth like this.
  10. Jul 21, 2016 at 7:27 PM
    matluth
    Aurora CO
    Thanks for that pic. I might as well do the rears too. Those look like Wheelers rear bump stops too. ?
  11. Jul 21, 2016 at 8:17 PM
    csuviper
    Broomfield, CO
    Yes wheelers rear bumps on their mount
  12. Dec 22, 2016 at 4:19 PM
    YotaDan
    Grants Pass, Oregon
  13. Jan 4, 2017 at 3:44 PM
    YotaDan
    Grants Pass, Oregon
    Bump :rofl:
    joonbug likes this.
  14. Feb 5, 2017 at 5:20 PM
    Digodell
    Digodell New Member
    Shane
    These do not fit the fron on 2016 plus years, about 1/2 inch Clearence and need to disconnect arm to install.
  15. Feb 5, 2017 at 5:22 PM
    csuviper
    Broomfield, CO
    Need a lift to add them in my opinion.
    matluth likes this.
  16. Feb 5, 2017 at 7:23 PM
    Digodell
    Digodell New Member
    Shane
    Thanks, yes three plus, I have a pro with an additional 1 inch in the front. So almost 3.
  17. Feb 7, 2017 at 11:07 AM
    YotaDan
    Grants Pass, Oregon
    SuperBumps are compressible. During suspension cycling they will compress down to about the same height of the factory bump stop. So they can be used on both stock ride height and lifted vehicles.
  18. Feb 7, 2017 at 12:03 PM
    GTABurnout
    GTABurnout New Member
    I really want to order a set but your web site makes the delivery super difficult. Needs to be signed for etc. I can't sit at home waiting on bump stops.
    Motor71 and YotaDan [OP] like this.
  19. Feb 7, 2017 at 1:04 PM
    YotaDan
    Grants Pass, Oregon
    Could we ship to your work?
  20. Feb 28, 2017 at 9:48 AM
    YotaDan
    Grants Pass, Oregon
    :benchpress:SUPERBUMP
  21. Feb 28, 2017 at 9:55 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    @YotaDan just want to double check with you. The front superbumps are the same part # for the Tacoma and the Tundra? I want to reuse the ones I removed from my Tacoma. Thanks
  22. Feb 28, 2017 at 10:26 AM
    YotaDan
    Grants Pass, Oregon
    Yes, they are interchangeable on those two models.
  23. Feb 28, 2017 at 10:36 AM
    Tacotundra
    Vegas
    2017 Tundra
    Awesome. Thanks for the reply. And these work great on big g-outs out in the desert and on the road for anyone considering superbumps.
  24. Jun 6, 2017 at 1:41 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Aside from the price how do these compare to timbren?
  25. Jun 6, 2017 at 9:04 AM
    n2deep
    n2deep Overlander - Speed Glamper
    Mojave Desert
    2010 Tundra DC
    Camburg Long Travel -Front King/King Secondary Triple Bypass - McNeil Fiberglass Rear -ADS Triple Bypass Deaver K37 Method Mesh 35x12.5x18 Cooper SST Maxx
    Who needs bumps haha - i trimmed my rear bumps down for an additional inch of up travel.
  26. Jun 6, 2017 at 9:10 AM
    14burrito
    14burrito New Member
    I sent wheelers an email as I no longer see their in house branded rear setup on the site anymore. All I see if the Timbren setup. Curious if its the same as the Taco rear? Be curious what they say
  27. Jun 6, 2017 at 9:28 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    Temecula CA
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Just take em all the way off
  28. Jun 6, 2017 at 9:30 AM
    14burrito
    FYI for the rear, same as the Taco
  29. Jun 6, 2017 at 10:05 AM
    csuviper
    Broomfield, CO
    I saved my Tacoma ones and installed them on the Tundra. No problems.
  30. Oct 1, 2017 at 7:49 AM
    14burrito
    Anyone on the fence about these?...
    I am very happy with their performance with my ADS shocks! Compression is much more smooth/progressive - not as harsh and abrupt.
    Highly recommend them!
