super bump stop contacting lca
Discussion in 'Wheels & Tires' started by Tundra_power, Nov 17, 2020.
  1. Nov 17, 2020 at 7:30 PM
    Tundra_power
    Tundra_power [OP] New Member
    Nick
    Hello I have 2008 tundra and I'm having issues. I just installed 4600 bilstein's the blue and yellow ones with 2 shims on driver and 1 shim on passenger. I have a really bad shundder/poping sound under driver side only when I U-turn to the right going over a bump. Now right now they are contacting the LCA always even sitting still. Everything is tight with the suspension. Can I cut the bump stops so it's not always contacting??
  2. Nov 17, 2020 at 8:50 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Why do you think it's the bump stop causing the issue?
  3. Nov 17, 2020 at 9:08 PM
    Tundra_power
    Nick
    Would the bump stop cause the sudder problem while turning full lock?? Or is it a ball joint issue..
  4. Nov 17, 2020 at 9:10 PM
    Tundra_power
    Nick
  5. Nov 17, 2020 at 9:14 PM
    Kelvin
    Kelvin New Member
    If when you put on the new shocks you didn’t find any bad ball joints then go back over everything and retorque. The super bumps are so soft there’s no way you’d be able to feel or hear it.
  6. Nov 17, 2020 at 9:39 PM
    Tundra_power
    Nick
    One side note is that the passenger coilover is on the driver side and the driver coilover is on the passenger didn't realize their was a difference between the two after I installed them.. That can't affect anything can it. It rides good 90% of the time. It just did the sudder and popping thing only two times.
  7. Nov 17, 2020 at 9:41 PM
    Tundra_power
    Nick
    The top 4 bolts were over torque alittle around 45ftlb. I set them at the correct 33ftlb and recheck the torque of all the bolts on both sides..
  8. Nov 18, 2020 at 10:54 AM
    Tundra_power
    Nick
    I think it could be my lower ball joint. I think it's leaking. Also I have a bad vibration under driver floorboard going over 70mph it's not constant but it comes and goes every other couple seconds
