Sup
Discussion in '2.5 Gen Tundras (2014-2021)' started by tkhert, May 1, 2021.
  1. May 1, 2021 at 7:01 PM
    tkhert
    tkhert [OP] New Member
    I’m new. What’s up with these tundras and their reliability bs
  2. May 1, 2021 at 7:12 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    What do you want to know?
    Cpl_Punishment likes this.
  3. May 1, 2021 at 7:13 PM
    tkhert
    Just knowing toyota for their reliability, I’m curious as to what the most problematic issues arise from the tundra
  4. May 1, 2021 at 7:22 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    216k and tow my 8k camper regularly, and I don't drive my truck lightly at all. Zero problems here. At the end of every toyota assembly line, they have a voodoo witch from the swamps of Louisiana casting reliability spells on all the vehicles. @hagrid could tell you more about this phenomenon if you're interested.
    R65, tttrdpro, hagrid and 3 others like this.
  5. May 1, 2021 at 7:24 PM
    tkhert
    I’m here and listening lol
    Sumo91[QUOTED] likes this.
  6. May 1, 2021 at 7:37 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Tundra's are far from reliable, not sure where you heard that at.
  7. May 1, 2021 at 7:39 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    jeremyd[QUOTED] likes this.
  8. May 1, 2021 at 7:39 PM
    Sumo91
    TN
    About the only things I've seen that is a problem that's not all that common, is the weeping cam towers, not enough to even leak on the ground, and won't hurt anything to run it like that, alot of people just leave it weeping if they are out of warranty. Other than that you'll have problems here and there with a vehicle from any model, some will give you problems from the start, some will never give you problems. The tundra has a great track record for being reliable, and if you read through this forum you'll see if someone does have a problem, its usually a one time kind of thing.
  9. May 1, 2021 at 7:41 PM
    tkhert
    considering you’re here with a tundra, ill test me luck
  10. May 1, 2021 at 7:41 PM
    tkhert
    Thanks
  11. May 1, 2021 at 8:00 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    https://youtu.be/l2OAHImTgA8
  12. May 26, 2021 at 4:21 PM
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    I have a 2017 TRD off road Crewmax with 54000 miles and cringe about the cam tower leak issue. I found myself checking the rear valve covers, underneath them at the cam cradles to see if I had a leak, or any residue. Even went underneath the truck to ensure there was no oil leak on the manifold. So far both passenger and driver side look dry. Ugh, I left my Ford F-150 to get away from the paranoia. Hope this leak doesn’t appear in the future.
