Suggestion on Timing Belt replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Davidwoodis, Jun 8, 2025.
  1. Jun 8, 2025 at 8:32 PM
    Davidwoodis
    Davidwoodis [OP] New Member
    David
    2006 tundra limited
    What's Best to do while you replacing a Timing Belt ? 4.7 L with 200k miles
    1 water pump
    2 crankshaft seal
    3 cam shaft seals
    4 valve cover gaskets
    5 Serpentine belt
    6 ?
  2. Jun 8, 2025 at 8:34 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Thermostat
    Tensioners & pulleys
    Get the Aisin kit from Rockauto, it has a lot of that stuff.
    G_unit3000 and FrenchToasty like this.
  3. Jun 8, 2025 at 8:34 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    G_unit3000 likes this.
  4. Jun 8, 2025 at 8:39 PM
    Fragman
    Fragman New Member
    TX
    And not timing belt related, but lower ball joints with OEM only if those have not been done.
  5. Jun 9, 2025 at 3:53 AM
    Test your fan clutch and bearing. If either are suspect, replace during the TB swap. Plugs during the valve cover job if they’re close to being due. Clean the MAF and throttle body while you’re in there.
    Jack McCarthy, G_unit3000 and Fragman like this.
  6. Jun 9, 2025 at 7:46 AM
    shifty` We call it “riding the gravy train”
    Understand: 2005-2006 you have the VVTi engine, ad the camshaft seals are considerably more difficult than with the previous non-VVTi trucks.
    I had a small camshaft seal leak and was able to shore it up using a seal refresher (AT-205).
    That said, if it ain't leaking, I would wait until next timing belt chang to reassess.
    Redoak likes this.
  7. Jun 9, 2025 at 10:39 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I was burned once by not checking and/or replacing the radiator fan bracket assembly during TB & water pump replacement job.
    87warrior likes this.
  8. Jun 9, 2025 at 10:53 AM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I just got finished with mine.
    All new aisin parts for timing.
    Belt drive: Add tensioners,(get an Aisin, or Toyota. Bought a moog and had to return it cause it had half the tension of the original) and pulleys, a good QUALITY serpentine belt
    Thought I could get away with using old fan bracket, and idler pulley, but ended up taking it apart again to replace them.
    First New fan belt caused me grief looking for a noise until figured out it was belt. Got a gates belt noise went away.
    Radiator, hoses, and replace any vacuum lines that are looking rough.
    shifty` and G_unit3000 like this.
