Strange wire coming from ignition coil harness
Discussion in '1st Gen Tundras (2000-2006)' started by haukulamae, Aug 14, 2020.
  1. Aug 14, 2020 at 1:43 AM
    haukulamae
    haukulamae [OP] New Member
    '03 Tundra TRD
    Just noticed a strange wire that’s been splices into one of the wires on an ignition coil harness. Seems to be something the previous owner did. Whatever it is. I don’t like it. I’m not good with electrical stuff so I’m scared to detach it. It goes to a group of wires that are honestly a clusterf***. One of the wires looks like a ground. I can’t figure out where they go. Any suggestions?
    FD3593A6-3283-461D-B661-B9C4A5C06B93.jpg 98792B14-6905-4132-B8AE-E0ED1BC188FA.jpg B02CC629-404F-4BFB-8948-197B2E7A2D28.jpg
  2. Aug 14, 2020 at 3:14 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Part of an alarm or remote system?
    tvpierce likes this.
  3. Aug 14, 2020 at 3:37 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Part of a remote start. That's the hood switch in the last picture, and the injector tap is for the tach signal.
    Given that there's a fucking wire nut I'd be worried about it too.
    bmf4069 likes this.
  4. Aug 14, 2020 at 3:41 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    +1
    Looks like a real hack install as evidenced by the use of a wire nut. (They're for electrical wiring of a structure, not vehicle wiring.)
    The last pic is a switch that lets the alarm and/or remote start system know the the hood is open.
  5. Aug 14, 2020 at 5:42 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Note to self.... No wire nuts on the Turd
  6. Aug 14, 2020 at 5:42 AM
    AZTundra
    Paul
    Phoenix, AZ
    Above posts are correct. That is for an aftermarket remote start. Wires were tapped for tach reading and the last is the hood pin switch which will not let someone remote start when the hood is open.
    NewImprovedRon likes this.
  7. Aug 14, 2020 at 7:44 AM
    haukulamae
    '03 Tundra TRD
    Not sure what tach reading is. Any recommendations on what to do from here? Is it safe to pull these wires? I don’t have any way to remote start so I’m not sure why it’s been rigged for that. Regardless, I don’t want that wire tapped.
  8. Aug 14, 2020 at 7:48 AM
    haukulamae
    '03 Tundra TRD
    Is it safe to remove these wires? I don’t have any way to remote start it. And I really don’t want that wire tap anyway.
  9. Aug 14, 2020 at 7:54 AM
    AZTundra
    Paul
    Phoenix, AZ
    The tach signal is provided to the remote start brain in case you have a hard starting vehicle (vehicle requiring more than six seconds of crank time to start) or if you live in an area of extreme temperatures. IN either case the Tach wire provides extra crank time.
    If you are not using the remote start there is no harm in removing the wire. Just disconnect it and cap it off or follow it the the control module under the dash and remove completely.
  10. Aug 14, 2020 at 8:02 AM
    haukulamae
    '03 Tundra TRD
    gotcha. I’m having trouble following the wire. Never messed with electrical stuff before. You say control module as in the ECM or something different?
    I do have about a 3-second crank time that’s been bugging me. Also, my obd port is not linking to any scanners. I’m wondering if this hack job has anything to do with those things.
  11. Aug 14, 2020 at 8:07 AM
    AZTundra
    Paul
    Phoenix, AZ
    The wiring for the remote start will all lead to an aftermarket control module unit similar to this:
    MrgWMp3eGO8o-HzdeHpoHK6RhuSkYWLSWv6C_CbK_0af86652a1c828aa20d026284b9c7d134f2f1947.jpg
  12. Aug 14, 2020 at 8:51 AM
    Professional Hand Model
    Hand Protectors
    Check your chassis grounding at the firewall and the over next to the battery. Clean solid connections are desirable.
    AZTundra likes this.
  13. Aug 14, 2020 at 9:13 AM
    haukulamae
    '03 Tundra TRD
    Hot damn. Alright, just detached the hood latch wire and tach wire. I’ll look for the module. I feel like I have a tapeworm in my truck. Thanks for your help!!!
  14. Aug 14, 2020 at 9:14 AM
    AZTundra
    Paul
    Phoenix, AZ
    No problem. Good luck!
  15. Aug 14, 2020 at 9:24 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Make sure the tach wire connection (where it was tapped) is insulated!!! If that wire touches any ground, your truck will not start.
