Strange electrical problem
Discussion in 'Electrical' started by CraigB, Aug 4, 2021.
  1. Aug 4, 2021 at 9:17 AM
    CraigB
    CraigB [OP] New Member
    Craig
    2007 Tundra 5.7
    None
    Hi I’m a new member. And I am looking for an answer to an electrical problem that I’m having. My 2007 tundra acts like the battery is dead, won’t start, solenoid just clicks. Headlights worked fine. Even with emergency start battery charger it will turn over a few times and then that’s it. Please advise. Thank you CraigB
  2. Aug 4, 2021 at 11:07 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome! Wish I could help.
  3. Aug 4, 2021 at 11:11 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    With an '07, I would start by checking ground wire connections.
  4. Aug 4, 2021 at 11:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    check your battery. If it is weak and going it it can cause all sorts of weirdness. Check it even if has been recently replaced, new ones can have bad cells.
  5. Aug 4, 2021 at 12:03 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    https://www.tundratalk.net/threads/5-7-liter-starter-replacement.453962/
    We had a similar issue on a V-6 Lexus. The contacts in the starter solenoid were burned to a crisp.
    I replaced the contacts and put it all back together again ~ problem solved.
    The R&R of a starter is quite easy on the Lexus but the Tundra V-8 ~ not so much.
    Smart money would have you replacing the starter and solenoid at the same time.
    However, Toyota starters are rarely the issue ~ it's typically the contacts in the solenoid.
    CraigB
  6. Aug 4, 2021 at 12:08 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Start easy & cheap & take a wire brush to the battery terminals and inside the battery clamps. I've seen that be an issue before. Actually happened on my '16.
  7. Aug 4, 2021 at 1:10 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Does it do more if you connect jumper cables from a vehicle (same size vehicle) and try to crank it with the other vehicle running? That might determine whether it's the battery or the solenoid/starter.
