Stereo upgrade
Discussion in 'Audio & Video' started by Zthomas1188, Nov 26, 2021.
  1. Nov 26, 2021 at 3:50 AM
    Zthomas1188
    Zthomas1188 [OP] New Member
    Zach
    2016 SR5 with trd
    I just purchased a 16 SR5 with the trd package. The stereo screen is cracked and the touch screen doesn’t work. I’m curious if I can install an upgraded head unit with navigation maybe out of a limited or platinum without any issues. Thanks in advance
  2. Nov 26, 2021 at 4:28 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome for your first post, also look in the Tundra Garage sub category audio/video and research what other members here posted.. Lots of good info and feedback..Good luck..
  3. Nov 26, 2021 at 9:28 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The stock toyota stereo systems, regardless of trim, are pretty subpar. Personally I would look into an aftermarket head unit- will sound much better, more power and you can pick one with the features or NAV that you want.
  4. Nov 26, 2021 at 11:47 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    OEM works best when paired with anything from James at 12volt. His setups are plug and play and make your OEM head unit worth keeping. To answer your question, yes, you could swap in another OEM head unit no newer than 2018.
  5. Nov 26, 2021 at 1:49 PM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    Zach,
    In 2 weeks I’m pulling my entire factory setup from my 2017 Platinum. Speakers, JBL subwoofer, Amp, JBL head unit.
    I’m limited with garage space and I’ve spent 18 months saving up and acquiring the parts for my 1st audio build. I would prefer it go to a forum member in need of it.
    If you are interested feel free to pm me.
    HulkSmurf14 likes this.
  6. Nov 27, 2021 at 2:47 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Unfortunately, the wiring harnesses between the SR5 and Platinum/1795 head units are different. Not impossible to overcome, BUT, you will be having to decode the wire colors and bypassing OEM connectors to make it all work. Personally (and I speak from experience), I think you will be much MUCH happier with an aftermarket H/U as the factory H/U's are total crap. I yanked my entire system and replaced everything, including all of the wiring. As a result, my aftermarket system sounds incredible.
    2010bigdog likes this.
  7. Nov 27, 2021 at 5:40 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    do you happen to have pictures of your system ? Im going today shopping for a head unit finally
