Stereo, Interior lights, and high beam switch not working
Discussion in '1st Gen Tundras (2000-2006)' started by Bsud, Jan 12, 2020.
  1. Jan 12, 2020 at 3:12 PM
    Bsud
    Bsud [OP] New Member
    I've checked every fuse (with volt meter) I've also checked the grounds. I am totally confused on what this could be. Today my fuel pump relay was buzzing, cranked up truck shut if off, relay hasn't buzzed since. What in the world is going on. 2000 model Tundra
  2. Jan 13, 2020 at 3:22 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Dont just look at fuses, take a test light and touch both sides while still in the socket. Key on, and light switch has to be on to see power at the fuses.
  3. Jan 13, 2020 at 3:58 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If it were I, checking grounds especially battery ground would be first thing I'd check.
  4. Jan 13, 2020 at 6:46 AM
    Bsud
    If you talking about the one going to the fender beside the battery I've checked that one. But if that were case why does everything else work? Dash lights ect
  5. Jan 13, 2020 at 7:16 AM
    Bsud
    The only thing I miss is my stereo, but now with all the streaming, I just stream my phone through a bluetooth speaker and I'm good. The truck has been like this for over a year.
  6. Jan 13, 2020 at 7:21 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Have you tried replacing the fuel pump relay? If that was buzzing and everything stopped working, I would probably start there.
    Did you recently install anything or change anything that might effect your problems? I'd also remove each fuse to physically inspect.
    Found this, may or may not be related.
    https://www.justanswer.com/toyota/bjb9o-2000-toyota-tundra-high-beams-not-work.html
    Start searching each individual problem because more than likely, you will find the issue for one and all three will start working again.
  7. Jan 13, 2020 at 7:29 AM
    Bsud
    The problems were present way before the fuel pump relay started buzzing. Also I installed the stereo some time back but everything worked fine for months. Nothing else has been changed. The steering column has been changed but way before these problems came up. All fuses have been physically checked and checked with volt meter.
  8. Jan 13, 2020 at 7:31 AM
    SouthPaw
    2000 Limited 4x4 AC
    Have you checked the fuse behind the radio? Most aftermarket stereos have a fuse right behind the assembly.
  9. Jan 13, 2020 at 7:33 AM
    Bsud
    No have not checked the stereo fuse. I will do that
  10. Jan 13, 2020 at 7:34 AM
    Bsud
    I did check voltage to stereo and I'm not getting 12v to there
  11. Jan 13, 2020 at 7:35 AM
    SouthPaw
    2000 Limited 4x4 AC
    I'd also remove each fuse under the hood and drivers side kick panel and check them out.
    Does your cig outlets still work?
    Where did you test it at?
  12. Jan 13, 2020 at 7:37 AM
    Bsud
    Cig lighter does not work.
    I checked voltage on the power wire going to stereo
    Also I have removed every fuse and relay
  13. Jan 13, 2020 at 7:43 AM
    SouthPaw
    2000 Limited 4x4 AC
    Ok I am really leaning towards you have a blown fuse some where. I found this on Tundra Solutions that kind of confirms what I was thinking that the stereo and dome lights are tied together.
    speedtre likes this.
  14. Jan 13, 2020 at 7:47 AM
    Bsud
  15. Jan 13, 2020 at 7:49 AM
    Bsud
    I'm not understanding that exactly?
  16. Jan 13, 2020 at 7:49 AM
    SouthPaw
    2000 Limited 4x4 AC
    So what it is saying is that the same circuit that powers the radio also powers the dome lights. If both aren't working, you have a bad fuse somewhere.
  17. Jan 13, 2020 at 7:51 AM
    Bsud
    But I have checked the Dome light fuses. Unless there's something behind the stereo I haven't checked
  18. Jan 13, 2020 at 7:53 AM
    Bsud
    Also at times the dome lights would randomly come on but would go right back off
  19. Jan 13, 2020 at 7:58 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    All of these items that you keep adding since first post are important in assisting. Perhaps you could take a moment and re-list everything that you are experiencing, especially other items you may have left out.
  20. Jan 13, 2020 at 8:02 AM
    Bsud
    What don't work....
    Stereo
    Dome lights
    Courtesy lights on doors
    Cig lighter
    High beam switch
    Door buzzer when opened
    The fuel pump relay started buzzing but has stopped once truck was cranked and shut off.
    At random times since these problems the Dome lights and courtesy lights have came on but went right back off.
  21. Jan 13, 2020 at 8:26 AM
    SouthPaw
    2000 Limited 4x4 AC
    This is the fuse I am referring to. Yours may look different depending on what stereo you have.
  22. Jan 13, 2020 at 8:35 AM
    SouthPaw
    2000 Limited 4x4 AC
    Could also be a victim of this:
    "HELP! dome lights and radio quit working"
  23. Jan 13, 2020 at 9:48 AM
    Bsud
    Ok when I get a chance I will check it
  24. Jan 13, 2020 at 11:03 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I wouldn't bother digging into that just yet.
    That fuse will only affect the radio. You're issue is way upstream of that.
  25. Jan 13, 2020 at 11:06 AM
    Bsud
    Way upstream as where to start?
  26. Jan 13, 2020 at 11:08 AM
    tvpierce
    Maine
    I guess I'd start at the fuse as was indicated by someone else earlier. It appears that whole circuit is out.
  27. Jan 13, 2020 at 11:12 AM
    Bsud
    Yeah that what I was talking about checking when I get chance. Checking that fuse box for moisture will be a last resort
    tvpierce[QUOTED] likes this.
  28. Jan 13, 2020 at 11:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Actually that should be the first thing you do.
    If you read thru the link @SouthPaw provided, you have the same year truck and the exact same issues.
    Pretty good chance parts of that fuse box are corroded in your truck as well.
  29. Jan 13, 2020 at 11:32 AM
    Bsud
    Well should I just take that fuse box completely out to check it. Really noway getting in behind there
  30. Jan 13, 2020 at 12:08 PM
    tvpierce
    Maine
    I misunderstood. You quoted the post with the fuse on the back of the radio, so I thought you meant that one.
