Steering wheel is possesed. HELP
Discussion in '1st Gen Tundras (2000-2006)' started by CodyFolmar, Jan 1, 2020.
  1. Jan 1, 2020 at 6:12 PM
    CodyFolmar
    CodyFolmar [OP] New Member
    Cody
    2002 tundra 4×4 4.7 v8
    Hi, I've recently replaced the rack and pinion and power steering pump on my 2002 tundra 4×4.
    This issue I'm having is weird. When I start it. The steering wheel is fine. But as soon as I touch it. It jumps back and fourth HARD like it is possesed. if you grab the steering while it's doing it. It will literally break your wrist. Any idea how to fix this? Anybody ever ran into this issue? Please help
    OR18TRD likes this.
  2. Jan 1, 2020 at 6:31 PM
    CodyFolmar
    Cody
    Everything's new. New all new lines except for the reservoir line. Everything has fluid
  3. Jan 1, 2020 at 6:32 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  4. Jan 1, 2020 at 6:40 PM
    CodyFolmar
    Cody
    Yes just like that.
  5. Jan 1, 2020 at 6:41 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    That's crazy
  6. Jan 1, 2020 at 6:45 PM
    Aerindel
    Aerindel New Member
    Montana
    2000 Tundra AC, SR5, 4.7 V8 4WD, 340k'ish miles, 2008 Sequoia, 220k Miles
    A quick search suggests that you get this problem from having the hoses mixed up.
  7. Jan 1, 2020 at 6:46 PM
    CodyFolmar
    Cody
    Cant mix the hoses up. Because the connections are different. Pretty fool proof
  8. Jan 1, 2020 at 6:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  9. Jan 1, 2020 at 6:49 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Steering controller. HiD lights?
  10. Jan 1, 2020 at 6:55 PM
    CodyFolmar
    Cody
    Truck is bone stock
  11. Jan 1, 2020 at 6:56 PM
    CodyFolmar
    Cody
    Yeaa. I'm thinking some holy water in the power steering reservoir would help
    Njmike13 and Darkness like this.
  12. Jan 1, 2020 at 8:51 PM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    Are you certain the fluid is correct? Have you cycled the rack back and forth to purge it of all air?
    After that, I’d be most suspicious of the new rack. Especially if it’s a rebuilt rack, and all the more so if it’s the likes of a cardone rebuilt rack.
  13. Jan 1, 2020 at 10:13 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You have air trapped in the rack. Raise the front wheels off the ground, and turn the steering wheel back and forth from stop to stop 10 or 12 times. Top up the fluid as needed, then start the engine and repeat.
    rockmup, Kerch71, Outbound and 3 others like this.
  14. Jan 2, 2020 at 5:43 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Makes sense.
    @CodyFolmar I used this video to "flush" my power steering fluid. Just keep in mind it may make a huge mess.
    https://www.youtube.com/watch?v=ywRzmvWVMqw
    bmf4069 and TX-TRD1stGEN like this.
  15. Jan 2, 2020 at 6:44 AM
    CodyFolmar
    Cody
    Could air being trapped really make it go crazy like that? Should I throw in some holy water with it?
    bmf4069 likes this.
  16. Jan 2, 2020 at 6:56 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well think about what the pump (compressor) is going thru. Tries to squeeze a liquid (doesn't compress much) then tries to squeeze air (compresses tremondously compared to liquids) then back and forth. Yeah that would like to a "possession" of something wicked.
    Luck and enjoy those Toyotas. : ^ )))
  17. Jan 2, 2020 at 7:02 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Odd, typically electric power steering has this issue. Never seen it happen on hydraulic systems. In the electric power steering systems it’s typically a bad steering rack
  18. Jan 2, 2020 at 7:20 AM
    foxtrapper
    2003 SR5
    If the lines between the rack and the spool valves are crossed, it will vibrate violently. If the spool valves are damaged or installed incorrectly, it can do this. If there is air in the system it can kick and buck. If the pump is bad (broken/missing vane), the steering will be buzzy and/or lurchy.
  19. Jan 2, 2020 at 9:24 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Let us know and post here once you find the solution - and maybe edit the thread title to make it easier to search in case someone else has the problem. Good luck!
    Aerindel and landphil like this.
  20. Jan 2, 2020 at 10:27 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    My first thought was air.
    Aerindel likes this.
  21. Jan 2, 2020 at 10:56 AM
    Professional Hand Model
    Hand Protectors
    Since everyone is in the prediction/guessing business, I’ll say its all three. Bad (new rack), bad install (air trapped), bad install (lines kinked messed up somewhere). The trifecta!
  22. Jan 2, 2020 at 10:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I still stand by my first post. Spiritual exorcism is needed.
  23. Jan 2, 2020 at 12:29 PM
    Outbound
    Aaron
    Northern Alberta
    2022 CrewMax Third Gen, 2005 DoubleCab Best Gen
    Yup, this is my conclusion as well. Could be a hydraulic problem with air trapped in the lines but that's boring. You definitely have an evil spirit in there. Find a priest, a cross and some holy water.
    bmf4069 and Aerindel like this.
