Steering rack leak
Discussion in '1st Gen Tundras (2000-2006)' started by RVAtruck, Aug 27, 2022.
  1. Aug 27, 2022 at 9:58 AM
    RVAtruck
    RVAtruck [OP] New Member
    Richmond, VA
    2005 Tundra double cab Limited 4wd
    I was under my truck installing running boards on my 05 DC this morning, and noticed some fluid leaking from the steering rack. It seems like it’s just a bad washer on the flange bolt pictured here. Anybody out there ever replaced one of these? It’s only $20 in parts if that’s the only problem, but I’ve read some old posts that say steering racks are harder than they seem. Wondering if I’m better off just taking this to a mechanic
  2. Aug 27, 2022 at 10:04 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Your leak looks like it might be coming from the top of the rack since I see fluid on the top as well.
    My steering rack is seeping fluid from this point.
    upload_2022-8-27_10-2-48.jpg.
    In your picture are you referring to this part? This is a mounting point and it won't leak there. The destroyed part is the steering rack bushing and it needs replacing.
    Jack McCarthy likes this.
  3. Aug 27, 2022 at 10:09 AM
    RVAtruck
    Richmond, VA
    Yes that’s what I’m referring to. Thanks for the explanation. I’m a bit of a novice.
    Is that bushing easy to replace? Is this leak something that needs to be addressed if I’m not having any steering problems?
  4. Aug 27, 2022 at 10:16 AM
    des2mtn
    Tonto cover
    The leak, I'd determine how much it's leaking over a period of time. The proper way to fix it is going to buy a brand new OEM rack from a dealer. Mine is at the point where it's just seeping and I have to top it off with PS fluid/ ATF every so often. Just don't let the PS fluid get too low otherwise it will fry the bearings in the pump. Trans fluid is much cheaper than a steering rack, if you're not experiencing any steering problems.
    The bushings can be replaced in your driveway without even lifting the truck off the ground. There are three bushings/ mounting points. The center mount takes a bit more effort. People often go with Total Chaos or Energy Suspension polyurethane bushings (like myself).
    This is a straightforward video on how to change the bushings:
    https://www.youtube.com/watch?v=JafzubwihDM
  5. Sep 2, 2022 at 1:56 PM
    RVAtruck
    Richmond, VA
    The bushings are on. I thought the rough steering was just cause the truck was a bit old, but it’s buttery smooth now most of the time. Thanks for the tip!
    Steering is still is a bit rough for a few blocks when the truck is cold but it gets better quickly. I also noticed there’s some shaking in the front end when I drive from a dead stop while turning either way. It is smooth if I start straight ahead. Any suggestions on what that can be? I don’t want to start taking things apart if it’s not some that’s gonna get worse or cause other problems
