Steering Problem
Discussion in '1st Gen Tundras (2000-2006)' started by Can Can, Dec 23, 2020.
  1. Dec 23, 2020 at 7:29 AM
    Can Can
    Can Can [OP] New Member
    Happy Holidays Everyone!
    Just yesterday my steering was getting stiff when turning left, felt like I was turning without any hydraulic support at all, but turning right was smooth as glass. I looked at my power steering fluid and it was at a great level. Is my rack going out, or could it be a pump? Thanks in advance for any advice. Cheers!
  2. Dec 23, 2020 at 8:11 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Are you hearing any noises when you turn the wheel? The pump usually will make a whining noise when it begins to fail. The rack might have bad seals on one side, which would explain the ease of steering one way, and difficult the opposite way.
  3. Dec 23, 2020 at 3:26 PM
    Professional Hand Model
    Hand Protectors
    fighthedude likes this.
  4. Dec 23, 2020 at 5:48 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Check your lower ball joints...soon
  5. Dec 23, 2020 at 8:30 PM
    Can Can
    I have not heard any unusual noises. There is a very small chirp the second the engine turns over when it's cold in the morning, but it's just one chirp, and that's all. I'll be able to look into it tomorrow. @w666 can you explain why I should check the lower ball joints? Could that cause the stiffness? I had the front end looked at about 700 miles ago and I was told it was good. But obviously things change!
