Starter replacement continued....home stretch questions
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Sep 1, 2020.
  1. Sep 1, 2020 at 5:38 PM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    So I tackled the monumental task of changing the starter. Broke it all down to the starter and wrestled that for awhile but finally got it off (only took 2 days w/out a garage and dodging FL T-storms). The reinstall of the new one wasn’t that bad. My few questions are does anyone put glue or RTV sealant on the new intake manifold gaskets? I feel like it’s easy for those to pop out when trying to put that back on. 2nd question... btw when I pulled the intake manifold off a dirt (Mud)dobber Nest fell down in the intake where the valves are. Anyway got it out with the shop vac and cleaned it best I possibly could. Any ideas of how to clean it better or is it probably ok? Also any advice on how to easily lower the manifold back down perfectly 1st shot?
    Thanks in advance!
    -Josh
  2. Sep 2, 2020 at 4:02 AM
    bmf4069
    bmf4069 something something something turd gen
    Beau
    TX
    02 AC sr5 4wd v8
    1: no rtv, just the gasket. This ain't an old school v8!
    2: if you decrease the size of a shop vac hose through ducktape and various smaller tubes you can get down to something a little more flexible and get it cleaned out better. I'd take a bore scope to it to make sure it's all out.
  3. Sep 2, 2020 at 10:42 AM
    Motopilot
    Josh
    NC/FL
    thanks for the tip it worked well
    RPR, YardBird, KNABORES and 4 others like this.
