Stakehole Ham Radio Antenna Mount?
Discussion in 'Recovery & Gear' started by Cement, Mar 4, 2019.
  1. Mar 4, 2019 at 10:02 AM
    Cement
    Cement [OP] ...
    2019 Cement Trundra TRD
    What's everyone using? I see a few on Amazon (Firestick stuff) but they look pretty flimsy and aren't well reviewed. Suggestions?
  2. Mar 4, 2019 at 10:08 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I used a Breedlove stake pocket mount on my last truck and it worked great. I can't use it this time, since I have a bed rack.
    https://www.breedlovemounts.com/ezn-stake-pocket-bracket.html
    Specifically model 917 with the NMO mount.
    MyFj08 and Cement [OP] like this.
  3. Mar 4, 2019 at 10:21 AM
    Cement
    Cement [OP] ...
    Wow that's some great looking hardware. Thanks for the tip!
    One concern that I should have mentioned in my first post is I'm running the OEM tri fold tonneau cover, and want to keep doing so. Looks to me like the Breedlove plate would probably interfere. Agree?
    If so, I wonder if they'd grind down one of the two longer sides so the cover would clear. Hmm...
  4. Mar 4, 2019 at 10:25 AM
    GodlessPro
    Matthew
    NorCal
    Bed covers always seem to screw up all of the cool things that people want to do :p. I've never used one or paid much attention to them, so I can't talk to any potential interference.
  5. Mar 4, 2019 at 10:26 AM
    Cement
    Cement [OP] ...
    Hah fair enough. I'll reach out to them and see what they think. Also open to other ideas. Thanks again.
  6. Mar 4, 2019 at 10:32 AM
    GodlessPro
    Matthew
    NorCal
    @Lars has more antennas than anyone else, so he might have some ideas for you.
    Sunnier, Lars and Cement [OP] like this.
  7. Mar 8, 2019 at 4:11 AM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    This is on my truck which has a ReTrax roll up tonneau.
    Sunnier and GodlessPro like this.
  8. Mar 8, 2019 at 4:12 AM
    Lars
    Lars
    Cedar Creek Texas
  9. Mar 8, 2019 at 4:13 AM
    Lars
    Lars
    Cedar Creek Texas
    at one point I had the same firestik mount in all four stake holes....
  10. Mar 8, 2019 at 4:17 AM
    Lars
    Lars
    Cedar Creek Texas
    These come ready to accept a 3/8x24 CB Antenna Stud.
    On the passenger's side I drilled it out to accept an NMO mount. The two that were previously up by the cab were both drilled to accept UHF antenna mounts.
  11. Mar 19, 2019 at 1:59 PM
    Cement
    Cement [OP] ...
    Thanks for all the help guys. I ended up with a Breedlove #917, no modification required. Super high quality piece and the envy of all the hams at the local Ham Radio Outlet. Fits with just a hair of clearance for the weatherstripping of the cover, and with a hair of overhang on the outboard side due to the curve of the fender. Works for me!
    (I painted mine black, 'cause I'm vain like that :p)
    In retrospect I should have grabbed the #918 (with SO-239 connection) rather than the ring terminal version (917). Easy enough to handle with an SO-239 to ring adapter (or by making my own) but would have been even easier just to screw the cable directly on.
    KarmaKannon, MyFj08, prtzel and 4 others like this.
  12. Mar 19, 2019 at 7:42 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Can you use a magnetic mount for ham? I have a Wilson for my CB. Would eliminate any holes..
    MyFj08 likes this.
  13. Mar 19, 2019 at 7:44 PM
    Cement
    Cement [OP] ...
    You bet. Just do your research. Some mag mounts are better suited (from a transmit/receive perspective) than others. I chose not to so I didn't have a cable visible. I prefer a cleaner look.
    GodlessPro likes this.
  14. Dec 3, 2019 at 8:06 AM
    Matthewkort
    Matthewkort New Member
    I’m curious on where y’all run the wires out of the truck and to the bed. More or less out of the truck lol. Thanks for future pics and info.
  15. Dec 3, 2019 at 8:32 AM
    GodlessPro
    Matthew
    NorCal
    There is a rubber plug under the driver seat. Cut a slit or hole in it and it works well for running the antenna wire to the bed. I probably have a picture on here somewhere.
    Hillbilly Taz and Matthewkort like this.
  16. Dec 3, 2019 at 2:06 PM
    Matthewkort
    Oh snap!! Never even knew about this said hole, only knew about the firewall ones!
  17. Dec 18, 2019 at 8:10 PM
    Lars
    Lars
    Cedar Creek Texas
    Most of my Coax is between the roof and headliner (5 antennas drilled through the roof.)
    The coax for the two antennas at the tail of the bed, both go through a grommet behind the drivers seat (just ahead of the gas tank.) (about lined up with the lever for the E-Brake)
