Stainless steel dash plugin plate for tundra - Inverter power in your dash!
Discussion in '2nd Gen Tundra Marketplace (2007-2013)' started by dv heavy duty, Jul 3, 2016.
  1. Jul 3, 2016 at 9:06 PM
    dv heavy duty
    dv heavy duty [OP] New Member
    2011 Toyota Tundra - Platinum
    1500w Inverter with a stainless steel plugin plate in the dash (see photo).
    I couldn't find this solution anywhere, so I fabricated it myself!! I can provide the stainless steel plate with the plugins for $60 CAD or $50 USD (plus shipping). I use tools remotely quite often, I hooked this up to a 1500w Samlex inverter - I can run a grinder from my dash!!!
    Contact me if you are interested...
    Law323, Nor7, Pat80608 and 3 others like this.
  2. Jul 4, 2016 at 9:12 AM
    gosolo
    gosolo If you go solo you better go prepared
    Central AZ
    2015 DC Super White Pro
    2"CB shackles, bushings and 1 shim, lockerdown console vault, rear folding seat back mod, snugtop shell with opening side windows, 48g fuel tank, SDHQ sliders and hidden winch, Decked Drawers, Icon leaf spring packs and got rid of the interior chrome
    running a blender for daiquiris and margaritas would be handier than a grinder...
  3. Jul 4, 2016 at 10:54 AM
    dv heavy duty
    It could probably handle both. At the same time!
  4. Jul 5, 2016 at 9:56 AM
    Pat80608
    Pat80608 New Member
    Patrick
    Where do you run the inverter to? Can you tap into the cigarette lighters or do you have to go somewhere else? Also, do you have a link to the inverter you are using?
  5. Jul 5, 2016 at 10:01 AM
    Spvrtan
    Spvrtan New Member
    Color me interested for now. Any more details behind the electrical components?
  6. Jul 5, 2016 at 10:08 AM
    Nor7
    Nor7 Chilton Manual Guy
    2011 Tundra 4.6L Double Cab
    You should do a build thread for this. I'd be interested in doing this.
  7. Jul 5, 2016 at 10:56 AM
    dv heavy duty
    You should not run through the cigarette lighter wires, the wire gauge is not big enough. I have the inverter under my seat and wired to the battery through a solenoid so it only draws power when the ignition is on. I have two wires plugged into the inverter and run to the back of the dash that are connected to the plugs I designed to fit the plate.
  8. Jul 5, 2016 at 10:58 AM
    dv heavy duty
  9. Jul 5, 2016 at 11:00 AM
    dv heavy duty
    I'm new to the forum, I'll look into it...
    zcarpenter92 likes this.
  10. Jul 5, 2016 at 7:34 PM
    zcarpenter92
    zcarpenter92 Yotas, Coronas and 'Merica
    Zach
    Eastern Colorado
    Desert Sand 2008 Tundra TRD
    In sig
    Definitely. I'd love to do something like this.
  11. Jul 8, 2016 at 3:05 PM
    dv heavy duty
  12. Jul 8, 2016 at 3:06 PM
    dv heavy duty
  13. Jul 8, 2016 at 3:07 PM
    dv heavy duty
  14. Jul 8, 2016 at 3:07 PM
    dv heavy duty
  15. Jul 8, 2016 at 7:14 PM
    csuviper
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    ^^^multi quote would have worked great there^^
