Stainless Steel Braided Brake Lines
Discussion in '2.5 Gen Tundras (2014-2021)' started by DSTundra, Jul 5, 2019.
  1. Jul 5, 2019 at 7:58 AM
    DSTundra
    DSTundra [OP] New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I made the switch to stainless steel braided brake lines years ago on my 2001 Tundra and used Russell's stainless steel braided lines then. Now I'm thinking of switching out the brake lines on my 2017 Tundra Platinum with some stainless steel braided lines, but I don't know if I should go with lines sold by StopTech or Goodridge? Price is close -- $145 for the StopTech lines vs. $175 for the Goodridge lines. Both packages come with all 6 lines needed. The StopTech lines look like they have a plastic or rubber component on the end and I'm worried about durability. Does anyone have experience with either of these brands on a 3rd gen Tundra?
    Dave
  2. Jul 5, 2019 at 8:24 AM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    They are all stainless. Its just a rubber sleeve over the fitting. I have stop tech on my other two cars. No problems with it.
    Rex Kramer and DSTundra[OP] like this.
  3. Jul 5, 2019 at 8:58 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I've been thinking about getting some too. Was also wondering about peoples input. My old Lexus SC has Goodridge lines on Supra TT brakes. I liked them a lot.
    blackdemon_tt and DSTundra[OP] like this.
  4. Jul 5, 2019 at 9:02 AM
    jdmek998
    jdmek998 New Member
    Yea, I currently have that brake setup on my SC. Stoptech lines on that and my ISF. Good products.
  5. Jul 5, 2019 at 9:13 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Sdhq sells them as well. I installed them on my 2015. Pretty easy. So now you have 3 choices.
    DSTundra[OP] likes this.
  6. Jul 5, 2019 at 9:15 AM
    Jimes
    Jimes New Member
  7. Jul 5, 2019 at 9:32 AM
    DSTundra
    Dave
    Albuquerque, NM
  8. Jul 5, 2019 at 5:44 PM
    Jimes
    Jimes New Member
    Nope. Just 4 total. 2 in front and 2 in rear. It has metal lines then the soft lines that you will replace and back to metal in the rear. 6406641F-BB55-4CE5-A5E7-F39F1ECED45F.jpg11E4A1BA-A588-4557-BE30-783A764B1CCD.jpg
    Ducarius and RitcheyRch like this.
  9. Jul 6, 2019 at 4:06 PM
    DSTundra
    Dave
    Albuquerque, NM
    Interesting... OK, Thanks...
    Dave
  10. Jul 7, 2019 at 3:29 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    That interesting. I haven’t had the rear wheel off in a log time. Didn’t realize that the rear rubber lines were there. I assumed they would be right by caliper similar to the front
  11. Jan 21, 2020 at 8:26 AM
    Is there a brake performance difference by switching to these?
  12. Jan 21, 2020 at 3:11 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    My 2015 CM has 6 lines, 2 front, 4 rear. I used the Goodridge brand.
    andy9743 likes this.
  13. Jan 21, 2020 at 3:13 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    My 08 also. I orded custom lines but I cant remember the mfgr right now...out of cali. They has color options and length options.
  14. Jan 21, 2020 at 3:35 PM
    DSTundra
    Dave
    Albuquerque, NM
    Yeah, 6 total lines was what I was thinking as well. Most kits I see have all 6 lines.
  15. Jan 21, 2020 at 3:42 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
  16. Jan 21, 2020 at 4:15 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
  17. Feb 1, 2020 at 3:57 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
  18. Oct 25, 2020 at 6:24 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    #andy9743
    does the Crown kit have 6 hoses? It doesn't specify
  19. Oct 25, 2020 at 6:32 AM
    DSTundra
    Dave
    Albuquerque, NM
    The Crown kit description says "Four (4) hose kit includes fronts and rears."
  20. Oct 25, 2020 at 6:53 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    I got 6. Each caliper. And 2 @ the rear end.
  21. Oct 25, 2020 at 6:57 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Do they bleed like old brakes or do you have to use the ABS pump like a new Tacoma? Ive had some sitting on my work bench a while.
  22. Oct 25, 2020 at 7:03 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    I have a vacuum bleeder that I used. I did not need to cycle the abs.
    PeakIT likes this.
  23. Oct 25, 2020 at 7:16 AM
    PeakIT
    PeakIT Old Member
    Utah
    I have a vacuum bleeder as well. I just was stumped on the tacoma for a bit until I found a obscure thread about it because I had one of the first 2016 and was one of the first to heavily modify it Around here.
  24. Jan 27, 2021 at 11:40 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    For those of you that installed stainless lines, how much of an improvement (if any) did you notice in pedal feel? Any firmer with the stainless lines?
    I'm particularly interested in hearing from those that change all 6 lines.
    Jman245 and TundraLaw like this.
  25. Jan 27, 2021 at 1:11 PM
    TemujinNomad
    TemujinNomad New Member
    Not much. I had hoped with the new ss lines and some fancy Bosch fluid, that braking would improve but then again my truck is pretty heavy. New pads would probably the best bang for the buck. Although it was nice to replace my old, corroded lines.
  26. Jan 27, 2021 at 1:17 PM
    ohreary
    ohreary Party!
    2020 Platinum
    for sure. it reduces brake fade when you’re out on the track.
  27. Jan 27, 2021 at 1:36 PM
    DSTundra
    Dave
    Albuquerque, NM
    I installed the 6 line StopTech kit and the improvement is marginal, but noticeable -- at least to me. I had Russell stainless steel lines on on my '01 Tundra so I knew what to expect. If you are looking for radical change, this isn't it.
  28. Jan 27, 2021 at 4:41 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    This is what I expected to hear. I went through a ton of brake upgrades on my track car to get the feel right, so I figured the improvement from just lines would be marginal. I think the Tundra brakes are overboosted and that's why the pedal is soft. Unfortunately there is no easy to way to fix that, which is sucks since the stock 4 piston calipers are pretty decent. I'm going to hold off on lines until I need new pads and then do it all at once.
